Question about Kenmore Washing Machines
Kenmore elite oasis models - 110.2706* 2707* 2708* 2709*---= thats off the cove of the manual w10115602a machine doesnot go into rinse or spin on normale wash about 50 mim it counts down to 28 min stays for a long time and then the (sd) code shows up even when you just use plain water at this time waterseems to go in machine and pumps right back out
  • 1 more comment
  • redsmaintena Mar 23, 2011
    Hello MacMarks
    well after following your advise your average went down
    after useing 62oz. of vineger in three a temps no workee
    ran normal wash 50min. just water cold cold 27min stop sd showed up again an again
    ran rines an spin 24min stoped at 13min. again an again
    ran clean cycle 60min stoped again an again
    see a pat. yet
    also used affresh twice
    at least 6Hrs. later still SD Sd SD
    any other sujections will be taken gladle
    I did not try puting vineger in soap dispenser just in tub
  • redsmaintena Mar 24, 2011
    Hello Macmarkus
    OK---- your rating just went back up
    their was a pair of shorts in between the tubs
    thank you
    and yes I would like a manual if it has parts an schematics
    e-mail redsmaintenance @yahoo. com
    again I thank you and hope to work together again
    have a good night
    macmarkus was very helpfull he stayed with me the hole way gave me the info in the order I needed it. his patiens was well appreciative I hope he didn't pull all his hair out
    I do look forwared to working with him again soon
    thanks so much Macmarkus
    Red
  • Kenmore Master
  • 2,605 Answers
Welcome to FixYa.
The "sd" code on your machine indicates the control has detected an excessive amount of detergent/suds, as you may or may not know. The draining sequence is an automatic "recovery routine" ( fills and drains to try and purge ) the control has initiated by design.
Here's what you can do...
Try selecting a normal cycle without any items added or detergent and selecting cold wash only. Run it through it's entire cycle...if it will. If it will not, try it again.
If this condition continues after several attempts, you can try adding two or three cups of "white" vinegar to the tub before filling it with cold water for another recovery attempt.
There are also products you can purchase to help this process such as "WasherFresh" or "Affresh" at many local grocers or hardware stores ranging from $5 - $10.
i.e.
kenmore elite oasis
The purpose is to help purge the inner tub and hoses of any excessive detergent built up, thus causing the "sd" error that is being detected by the control. Even though this is by appearance a "topload" washer, it still rquires the use of "He" detergents only, the container of detergent must show this label/symbol...
i.e.
The recovery/purge may take some repeated attempts, but it will prove worth it in the end as it typically will resolve the problem.
Let me know how you make out or if I can assist you moving forward from there in any manner. Good luck and Thank you for choosing FixYa today.
Regards,
Macmarkus :)
Posted on Mar 22, 2011
  • 2 more comments
  • Mark MacDonald
    Mark MacDonald Mar 23, 2011
    Hello again,
    That is unfortunate, it is always the first step to rule out the simple solution. The issue certainly has nothing to do with how the vinegar was added, but for the record...adding it directly into the tub is the correct manner.
    Since that did not remedy the problem it means it is much more involved and can mean something obstructing the drive system, i.e. a sock or small item of clothing between the inner & outer basket or under the agitator not alowing the basket to engage during the rinse/drain commands.
    i.e.
    **Unplug the washer from its AC outlet before proceeding...safety first**
    The easiest place to start now is by removing the agitator. To do this first remove the small cap on top, then the 7/16" bolt, pull straight up (you may need to wiggle it back and forth until it lets loose.
    i.e.
    Then you'll need to pull up on the agitator to remove it, this may take some "wiggling" as well, but it will come.
    Once removed, you'll see the "hub" assembly. i.e.
    Remove it and check for any debris under there. ( that what can prevent the basket from engaging, thus initiating the "sd" error ) If none present let me know and we can move forward from there.
    **If you are up to it I can try and instruct you on how to pull the unit apart further to search for obstructions or you may opt to call in a pro.**
    Keep me posted and I'll help in any manner I can of course. I can also provide you with a service manual for more detailed info if you want to provide an email address...It's your call.
    Good luck again.
    Regards,
    Macmarkus :)
  • Mark MacDonald
    I noticed one of my images did not show in my last post. This is what it should have been.
    Macmarkus :)
  • Mark MacDonald
    Mark MacDonald Mar 24, 2011
    So glad to hear my suggestion resolved your washer issue.
    I am attempting to send the service manual via the email address posted, however it appears to not be a good email address or at least according to my windows live account.
    If you'd like to try again or email me at macmarkus@live.ca I'll just send it via a reply to your message, insuring it will be received.
    Thanks again for choosing FixYa. I hope you'll remember to rate the assistance I provided as very helpful and a short testimony is also appreciated.
    Thanks again and good luck.
    Regards,
    Macmarkus :)
  • Mark MacDonald
    Hey Red,
    I'm glad I could help as I said. Hope you will rate my solution four thumbs up as a conclussion to your post here at FixYa.
    Thanks again and please come visit for any future enquiries...hopefully not too soon right, ha ha !
    Regards,
    Macmarkus :)
How can I reset Kenmore elite oasis he washing machine
You can download the manual at the link below but you need the model number. The site can also tell you where to find the model number. User Manual Downloads
Aug 03, 2014 | Kenmore Oasis HT 4.7 cu. ft. Top-Load...
Kenore Elite Oasis top loading washer wont spin during the spin cycle, but will rotate during wash and rinse cycles
Since the motor turns regadless of the direction it turns itself is good and theirfore the problem with your washer i believe is going to be the control board,it is what tells the motor what direction and what speed to turn.
GENE
Sep 23, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
My Kenmore Elite Oasis washer unbalanced signal seems to be very sensitive. Only after several tries of readjusting the load to get it really even that the washer will spin without stopping. I made sure...
If the washer throws an UL error code with out any clothes in the washer then the issue must be concerned with the mechanical alignment inside the machine or a bad CCU.
The most common problem which can cause this is some sort of mechanical hinderance which does not allow the basket to move freely.
The suspension system which holds the basket in its place might be faulty and causing the unbalancing. In this model i think there are plastic ring at the bottom of the basket . Even if they are worn out or moved out of position it may cause the UL error code you are facing
Nov 09, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
F51 error
Hello, the F51 code is a motor rotor position sensor failure. It's best to call in the warranty service as there is a bunch of tests that need to be run to determine if it's the sensor or control board. If the tech wasn't any help, contact the store for a replacement.
Thanks
May 20, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Washer wont spin
Here is a tip that will help you with the not spinning or agitating problems....
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
heatman101
May 16, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Washer is skiping rinse and don't spin has code ol
be sure that both water sources are connected and turned on.
Sep 14, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Machine doesnot agitate or drain once filled with water
it sounds like a bad lid switch if it will not drain or spin,the switch controls that-mike
Apr 24, 2009 | Washing Machines
Washing Machines Logo
564 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
