Question about Oster Golden A5 2-Speed Universal Motor Clipper 78005-140
Hi I bought Oster golden A5 clippers from ebay and I am not sure if they are fixable. I tried to use them to groom my dog and the blades wont cut the only solution was to tape the blade flush to the unit, as they are loose and the plastic tongue bar wasnt reaching far enough. I have inspected it and the latch is fine, but the plastic tongue bar thing has a tiny chip out of either side, is this the problem? The blades also seem very loose on the metal tongue.
  • 38 Answers
It's seem that your clipper blade are out of adjustment and also dull, The Lever from what you stated your Lever is worn out also. The only way I can help is to send your clipper and blades to us so we can make all the necessary adjustment, replace the worn out part and sharpen your clipper blades.
I don't know how many blade you have, but we can work some thing out to help you solve your problem. You can e-mail at ask@mannyssharpening.com
We have been in sharpening business since 1990 You can check out my rating on Yahoo.com Manny's Sharpening
Posted on May 14, 2011
The brand new gear lever on my oster a5 isnt moving the clipper blade
make sure the blade is clicked into place fully, secondly check to see if the blade is sitting further away from the clipper than usual, it could also be a stripped gear inside the clipper does the lever move when the blade is engaged?
Jun 21, 2014 | Oster Turbo A5 2-speed Dog Pet Clipper...
Oster clipper
It sounds like a faulty motor if they are under a year old send then back who you purchased them from otherwise it could be a costly repair.
Dog Clippers
Jan 15, 2013 | Oster Grooming Golden A5 2 Speed Clipper &...
Oster A5 clippers work briefly then "pull" hair
Lever arm worn, blade blunt, or loss of movement inside the gearbox. It is possible to have a 'bad' sharpen.
Aug 03, 2012 | Oster Golden A5 Single-Speed Clippers
I have a brand new set of Oster A5 model #78005 clippers. We own two large dogs--we cliipped the first one and it worked beautifully--we were about half finished with the second one and all of a sudden...
I'm sorry if this sounds academic, but regardless of whether or not the problem lies with the clipper or the blade set itself, since it is brand new, return it to the seller.
Apr 09, 2011 | Oster Golden A5 2-Speed Universal Motor...
My oster A5 2 speed will cut for short time and than won't go though my dogs fur. It's like the blade lifts up and is not tight on the clippers. I have had these clippers for three years and have had no...
make sure the blade clicks into place and cannot be removed without depressing the release latch, secondly check the two screws are tight either side of the hinge assembly, faults in either can cause this fault.
Dec 30, 2010 | Oster Golden A5 2-Speed Universal Motor...
Blades fell off oster dog clippers but can't fit them back on. Please help !!
With the hinge of the clipper facing you:
Make sure hinge is open, if it is not, prize it open with a flat head screwdriver.
Slide the blade on with the blade siz/number faceing you.
Snap shut.
If this fails, try again, but push the latch in as you snap them shut.
If this fails, you may need repair!
www.sheareaseltd.com
May 15, 2010 | Oster Golden A5 2-Speed Universal Motor...
A5 dog clipper or blades may need tune up or
some times the link and gear inside the front part of the clipper wears out and the blades just wont cut. try this, remove the clipper blade on the front of the clipper their is a lever color red grab this part with your 2 fingers and move it side to side if it moves and feel sloppy your gears and link are worn out. you need to replace, also check the hinge for spring tension. if you need help Contact mannyssharpening@yahoo.com
Feb 22, 2010 | Oster Golden A5 2-Speed Universal Motor...
Oster Golden A5 Clippers will not cut
If the clippers are new, it is not likely that the problem is internal. Sometimes, when the blade is put on the clipper, it needs an extra little push to clip firmly behind the blade catch (you can hear a little click). Try that.
Aug 23, 2009 | Oster Golden A5 1-Speed Universal Motor...
Newbie Clipper needing advice
This is from the Oster book:
Changing Blades
To Remove: IMPORTANT- stop motor; push latch with thumb while lifting blade away from clipper and slide off tongue.
To Replace: turn motor on; insert blade on tongue fully and then snap blade into place.
Note: if the hinge is flush against clipper, lift it up with a screwdriver.
From me - Never take your blades apart to clean them. You can slide them one side to the other to get the hair out. (One little hair, can stop them from cutting.) You need to buy a can of clipper blade cool from oster or andis both are good, and it really helps to lubricate the blade and keep them cool while clipping. If you live near a dog groomer, petsmart or something of the like. Ask them to show you how to remove the blade and I know they will be happy to show you. I tried to submit an image from the book, but I don't know if it will get here or not.
Mar 31, 2009 | Oster Golden A5 2-Speed Universal Motor...
Oster Golden A5 2-Speed Universal Motor Clipper 78005-140 Logo
166 people viewed this question
Top Oster Health & Beauty Experts
Anglia Clipper...
shaveroutlet.com
shaveroutlet.com
Chuck
Are you an Oster Health and Beauty Expert? Answer questions, earn points and help others
