Question about Samsung Televison & Video
LCD TV will not turn on, not with the remote or with the on/off button on the TV? Switched to different wall outlet, still nothing??
  • 1 more comment
  • wfrantzen Mar 22, 2011
    LED is on standby!
    The LED is on and as usual in standby mode!
    So I would be able to put in a new power board by myself without any help of a repairman?
    At the moment don't have the time to open up the tv and look for the board, can I get back to you on this?
    Thanks for the help and the quick response, very much appreciated!
  • 4,889 Answers
What is the status of the LED at the front? Is it on or blinking or in standby?
Posted on Mar 22, 2011
  • eagle338
    eagle338 Mar 22, 2011
    In that case this is definitely an issue with the power board. THere is a short or open circuit on the board which is impeding the unit from powering up. the easiest way to fix this would be to replace the board(costs about 75-100$). I can find you a replacement if you can get me the part number off the board. To do this you must remove the back cover and look for the part number on the board. If its a Samsung tv then the part number usually starts with BP-xxxxxxx . If you are unsure then get me the make and model of the tv so that I can give you an idea as to what the part number will be like.
  • eagle338
    Yes you can there are a few connectors that have to be unplugged from this board and plugged in into the replacement. All you have to be careful about are
    1)ESD which can damage the board
    2)Residual votages that may hurt you.
    I will give you detailed instructions on replacement while avoiding these pitfalls once you get me the part number. And don't worry this thread will never close so you can take your time
My LG55LE5500 suddenly stopped working this morning. Last night, we switched it off in proper working condition. This morning, when we switched in ON, only the initial LG logo screen comes and stays there...
Check whether the product is turned on. I Try another channel. The problem may be with the broadcast. I Is the power cord inserted into wall power outlet? I Check your antenna direction and/or location. I Test the wall power outlet, plug another product's power cord into the outlet where the product's power cord was plugged in. From the LG manual kolbrun
Sep 18, 2013 | LG 55LE5500 55 in. HDTV LED
Vizio VL470M won't turn on
see this instruction: God bless you
  1. Check if the power cord has been properly connected to the power outlet.
  2. Check if the main power has been switched on.
    (DVD player's power supply transformer could be burned out)
3. test the power outlet wall see the diagram
4. do not use the r.control use the power button directly from TV.
Jul 20, 2013 | Vizio 47"" vl470m 1080p 120hz widescreen...
My 32inch lcd tv keeps flickering it started all the sudden
TRY THIS
    • 1 Turn the TV off with the front-mounted power button, not the remote. Unplug the TV's power cord from the wall outlet. Let an hour pass before plugging the cord back into the wall outlet. Turn the TV back on with the front-mounted power button and wait until it has fully restarted. Bring up a TV channel to see if the image being presented on the LCD screen is no longer flickering. A momentary power surge can cause the circuitry inside the LG-brand LCD TV to function erratically.
    • 2 Unplug the video cable from the video connection on the back or side panel of the LG TV. If more than one video cable is connected to the TV, disconnect all of them. Disconnect the other end of the video cable from the video source device that it's attached to -- a DVD or Blu-ray player, or a satellite receiver or cable box. Blow off the connections on the video source device and on the back or side panel of the TV with bursts of compressed air. Reinsert one end of the video cable into the video source device and the other end into the video input that it was connected to. Turn the TV back on with is remote to see if the picture is now free of flickering. A loose or partially connected video cable can cause the LCD TV's screen to flicker when presenting an image.
    • 3 Turn the TV off and unplug its power cord from the wall outlet. Place a power conditioner next to the wall outlet. Plug the power conditioner's power cord into the wall outlet. Plug the TV's power cord into one of the AC sockets on the power conditioner. Turn the power conditioner on. Turn the TV on to see if the picture is now free of flickering. The RF signals in the electric line that the LG TV is drawing power from can cause flicking through interference patterns being generated.
Oct 20, 2012 | Computers & Internet
Why does our TV go through the channell setup everytime we turn it on?
Hi Mary -
The first thing you should do is consult the set up procedures on Page 8 / Section 4 of the manual. This will assure that you have completed and exited this important section properly.
If the TV should lose power (power outage, blown fuse or circuit breaker, cord removed from the outlet, etc.) the TV will likely need to have the setup performed when powered again for the first time. Likewise, a TV that is plugged into an outlet controlled by a switch, will lose power when the switch position is changed. Since switched and un-switched wall outlets look the same, you will need to unplug the TV and plug in a table lamp or similar and operate switches to see if it goes out. You will need to try both the upper and lower outlets as they can be operated independently of each other. If you find that the outlet is switched, you will either have to stop using the switch or find another un-switched outlet to power the TV.
I didn't see it mentioned in the manual, but some TVs have a dedicated power and a dedicated on / off button. If the power button is set to off, the TV will shut off and the remote will not be able to turn the TV back on until the power button is turned back on. The on / off button on the TV allows the TV to be turned on and off with the remote - or the on / off button on the TV. Again, this will only work if the dedicated power button is on. If the power button is set to off, it may be causing the TV to lose the set up information - requiring that it be done again. Make sure that you are using the remote to turn the TV on and off - or the correct button on the TV if you do not have a remote.
If all fails, you might want to contact Sanyo directly. According to the manual, they can be reached at 800-877-5032. I hope this helps & good luck!
Jul 31, 2012 | Sanyo 52" Class LCD 1080p 120Hz HDTV,...
I just bought a new 40 in. philips LCD television. I plugged the power cord into the tv then into the wall outlet. the tv will not turn on or make any sounds when trying to turn it on with remote and...
Hello, make sure power cord is pushed in all the way in to the tv. Also make sure you have power at your outlet. I know it sounds dumb, but I've seen people chase their tail for hours before coming to the conclusion that a circuit breaker was tripped. Make sure you have good batteries in the remote. If the TV has a power button on the tv, try turning it on there instead of the remote. You can check to see if there is an on/off switch in the back. Besides this it should be pretty straight forward. You might have a defective tv
Hope this helps
Thank you in advance for your feedback
Mar 04, 2011 | Philips 19PFL3403D/27 19 in. LCD TV
I pressed the power button, but the tv wont turn on
Please check if the power cord is connected properly in the wall outlet and in the TV. Check the wall outlet. Has it got power? Check if there is red light when the power is switched on at the wall outlet. If there is red light then press the power button. Does the TV turn on? If not then your power button is defective and requires replacement as it is not making contact. Also please try to start your TV WITH THE REMOTE CONTROL. At times it helps.
Feb 12, 2011 | Sanyo Televison & Video
The list button doesn't work and I am unable to
turn off your cable box
turn off the dvr
disconnect cable box from wall outlet
disconnect dvr from wall outlet
unplug e-sata cable from dvr
replug e-sata cable back in to dvr
plug dvr into wall outlet
turn on dvr
plug in cable box to wall outlet
turn on cable box
wait for cable box to go completely thru startup procedure
...then try your list button again.
Mar 01, 2010 | Televison & Video
Tv won't turn on
Try a different outlet or power strip. Try different ways to turn TV on such as power button on TV or by remote. If nothing else works and no led lights on you may need to have Service Tech look at it.
Oct 27, 2009 | Philips 32PFL7332D 32 in. LCD HDTV
LCD TV is hooked thru cable box. When you use the
Try this (may not work):
1. UNPLUG power from TV at wall outlet.
2. Turn ON the TV (with no power cable plugged in).
3. Plug power cable back in (at wall outlet)
4. Turn ON TV (don't use remote this time).
Hope this works!
Sep 03, 2009 | Televison & Video
No Picture (power indicator does not light up)
I have a Protron 37: LCD TV. The power indicator does not change to green (the red light is showing) and the TV will not turn on, either by remote or using the power button on the TV. The TV is about a year and a half old. Can you please help me?
Thanks
Mar 31, 2008 | Protron PLTV-37 37 in. LCD Television
Open Questions:
samsung pn64f8500 boot loop with evoulution kit 3000za installed I had perfectly working Samsung plasma ph64f8500 working fine with Samsung evolution kit 3000 ZA installed. Then we moved I took off the evolution kits so the movers would not knock them off. I powered up without the evolution kit installed accidently. Now both plasma are stuck in boot loop. They power up but go to the smart tv logo and cannot find the evolution kit. I read somewhere a long time ago that I needed to reset the evolution kit to a state where it had not been installed. The current issue is the Main Logic Board eeprom instructs the unit to boot correctly but it cannot find the evolution kit. If you boot without the evolution kit the system halts and indicates on the screen the evolution kit has been uninstalled and you must install it if you wish to view. If it could find the evolution kit one could go thru the menu to uninstall it correctly. One option is to manually reset the eeprom to remove the install instruction that boots looking for the evolution kit. I have been looking for the eeprom on the Samsung main logic board but I cannot download the logic board schematic. I cannot find the logic board number. The main logic board is BN94-0625C. The logic board has tow other part number references.• MFR Part Number 1: Samsung BN94-06205C • Board Number(s): BN41-01998A, BN97-06633G i have been researching the logic board IC Numbers and belive that IC 1701 is the eeprom that requires reset. The youtube videos for similar models indicate a eeprom that is listed as a part nmber for this samsung pn64f8500 unit as 24C512 and shows how to jumber 2 IC locations that will force the eeprom to reset to standard starup without the Evoution Kit 3000
Jul 16, 2018 | Samsung Televison & Video
Televison & Video Logo
50 people viewed this question
Jerry Greenberg
Jerry Greenberg
