My rca tv was working okay but now I can't get a satelite signal just shows fuzzy screen as far as I know nothing has changed since we last used it, although when I look at the channel it is suppose to be on- it shows the channel 4 as A4 is this the problem.
  • 11,361 Answers
Did you try CH3?
How is the satellite box connected to the TV? Coaxial cable or video/audio cable?
Do you get satellite on screen setup menu?
Posted on Mar 22, 2011
How to get the right input for a conventional rca tv
Channel 3 is what you want anyways if you use the co-axial for the input. You can't have any other channels until you do a scan and there are no other channels anyways when you are using the tv as a monitor. So all your problems exist before that. Since the tuner is analogue and the satellite receiver is digital you may need a modern brown box.
Nov 28, 2013 | RCA F27242GY 27" TV
I have a RCA XS Stero TV. I don't have remote. I connected DVD player right connections. But I am not getting any picture in the Screen. Actully it is showing Blue screen all the time. No TV picture also....
Sounds like you're stuck on..... Video 1 or Video 2 (whichever). If you can access your TV's menu at the front panel, you should be able to switch over fairly easy. Hit MENU. Using your VOLUME UP & DOWN buttons, Go to CABLE/SATELITE/ANTENNA, hit VOLUME UP or DOWN 'til it switches back to TV picture then hit ENTER. If you do not have an access panel in front but possibly have any other remote (cable or satelite or home theater, etc...) that can be paired with this TV and has an INPUT button, you can change the setting that way.
Hope this info was helpful. Good Luck!
Jan 29, 2010 | RCA Televison & Video
The trouble started with losing the signal briefly and then gradually got worse until no signal and search for satillite came on. trouble shooting chart used.No signal strenth .the high def system was...
If the screen says searching for satelite the prblem is with the satelite receiver not the TV. (not familiar with Direct TV problems - usually signal strength alignment issues)
Sep 22, 2009 | Televison & Video
If I tap the rca jacks in the back the screen gets distorted
You need a hdmi connector from your tv source to the TV. RCA connectors don't have the capability for HD signal transmission. You can use them for a connection but the picture will be fuzzy if trying to watch HD signal. Check your cable/dish box to see if there is a hdmi output. If so, buy a hdmi cable & that should solve your problems.
Mar 19, 2009 | Akai LCT4216 42 in. LCD Television
No freaking signal
Double check ALL your ant wire connections. Then reprogram the converter to check for stations again. If that doesn't work then reposition your antenna and reprogram again.
May 21, 2008 | Insignia Digital-to-Analog Converter for...
RCA 40 in
Are you using just one box on this set. I suspect a bad set-top box...accordianman
Jan 08, 2008 | RCA Scenium D40W20 40" Rear Projection...
Won't tune in all channels
Do you mean the channels from the internal tuner which would be channels 22 to 68, or do you mean satelite channels, as I do not know whether this set has a built in satelite receiver? Satelite broadcasters are often changing frequencies or satelites.- Programs come and go!
Oct 20, 2006 | RCA F27440 27" TV
Televison & Video Logo
Top Televison & Video Experts
