Hi, I have a samsung HL-R508W DLP TV that of late has the following problem. When I turn it on, it tries to start up. I can hear the channel but no video. It shuts itself off and tries to start again about 3 times and then displays the lamp replacement symbol. I have replaced the lamp but the problem persists. The problem was gradual in the sense that it used to turn on after a few tries and now it never succeeds to fully turn on. Is this a problem with the ballast or color wheel or is there no hope???
  • 3 more comments
  • kgovin Mar 22, 2011
    can you give me some instructions on how to get to the ballast board and the supply voltage??
    is it the board to the right of the lamp housing?
    located and removed the ballast card. Everything seems fine on inspection. Where is the power suply section on the HL-R5087W unit. Is it part of the lighting engine unit. Your replies are lacking any detailed information.
  • kgovin Mar 25, 2011
    I replaced with a new ballast. Te\he problem did not go away. Its the same situation. Someone else suggested that I reset the lamp counter. How do I do that for this unit?
    Thanks
    kg
    I replaced the ballast and the problem remains. I saw online that to reset the lamp counter you had to get into the service menu by pressing Mute + 1 + 8 + 2 + Power buttons in sequence. I tried this and there was no effect. The TV did not go into the service menu. I have also replaced the bulb. What else could be wrong?
    Thanks
    President:
  • 1,768 Answers
1. you possibly replaced the lamp but didn't reset the counter for the lamp.
2. there is in some models a counter to that counts the hours of use to the lamp then a controller relay that to a program that counts the hours of use for the lamp
3. your lamp will need a service tech to reset this or contact the manufacturers tech depart to get the instruction set to reset the lamp counter.
Posted on Mar 22, 2011
  • 2,098 Answers
Hi kgovin,
You have to check the ballast board for faulty parts, bad solder joints. Also check the supply voltage for bad filter capacitor and bad solder joints in the power supply section. Bad solder joints/dry joints is hard to spot I would advice you to work in the brightest area or used table lamp/portable lamps to locate it in the board.
Jdvillanueva
  • Jdvillanueva
    Jdvillanueva Mar 22, 2011
    open the back panel of your unit, you will see the entire board. If you're not familiar where the ballast board you have to trace the cable from the lamp going to that board. Once located the board trace the line also going to the power supply where the power cord is connected.
I HAVE A DLP SAMSUNG 52" T.V. IT TURNS OFF BY ITSELF EVERY THIRTY MINUTES. CAN YOU TELL ME WHAT THE PROBLEM IS?
Has it been getting loader lately? (fan noise)
if so check link it could be the common fault described below
Samsung Color Wheel
http://www.jangro.com/electronics/samsung-dlp-replace-color-wheel/
Nov 24, 2009 | Samsung DLP HL-P5663W 56" TV
I have a HL-T5687S DLP TV. Since yesterday, my tv
right side push button stick ...check and open stick button
Nov 07, 2009 | Samsung HL-T5687S Television
I have a Samsung HL-S6186W 61" DLP HDTV I could get the hd channels over the air with an antenna before but now I can't get any thru cable without going thru my dvd recorder tuner first which degrades the...
Select TV input, Press Menu, Select Channel, in menu Antenna=Cable (for you), (then perhaps, Auto Program with Cable or Air+Cable), tweak Channel List, turn on LNA if needed, shouldn't be.
Somewhere there may be different modulations, some offset the channel a fraction and are important for channels above 13. I'm basing this on my non-cable Samsung HL-T5687.
BTW, I had an HLS until it gave trouble, paid for an upgrade to LED from bulb when I got HLT. Very pleased, until it fails. -Ken
Jul 15, 2009 | Samsung DLP HL-P5663W 56" TV
Our Samsung HL-P4663W DLP is makes noise and shuts off
It is the color wheel, inside the light engine. The bearings get dirty and makes it harder for the wheel to spin causing that whin.
Jan 06, 2009 | Samsung DLP HL-P5663W 56" TV
Samsung DLP HL-P5674W Screen is stretched at the top and bottom...
did you ever find out the problem , mine is doing the same thing,
please email highltv3@aol.com if you can help
thank you so much
debi
Mar 05, 2008 | Samsung DLP HL-P5663W 56" TV
Problem turning On
Same exact problem started 01-08. Any suggestions yet>?
Dec 07, 2007 | Samsung HL-P5063W 50" Rear Projection HDTV
Televison & Video Logo
43 people viewed this question
Top Televison & Video Experts
