Can a tv channel memory get corrupted, and if so what can be done about it. I have a Toshiba flatpanel intergrated LCD tv.
    Genius:
  • 1,622 Answers
Hi Recently i've been trying to fix a really annoying problem with streaming live tv to clients (stuttering and discontinuities). After a lot of tinkering I think i've finally nailed it
I submitted a patch a few months ago that alleviated the problem but didn't completely fix it. See here Fix for streaming discontinuity errors
The root of the problem is that tswriter, tsreader and streamingserver make a lot of unnecessary and an excessive number of read & write disk operations with live tv. Viewing a HD channel on my setup caused MP and tvserver to perform over 11,000 disk IO operations per second (very high for even a fast disk). This patch removes the unnecessary read/write calls and also reduces the frequency that packets are written to disk (every 43 packets instead of 10 - see below). These optimisations reduce the disk IOs by about 90% to ~1,200 per second on a HD channel.
The second cause of the problem is the precise timings that streamingserver seems to require to reliably stream live tv. In this patch i've modified tswriter to dump 43 packets at a time instead of 10. 43 packets equals 8084 bytes which exactly matches the buffer size that streamingserver uses. This, coupled with the reduced number of disk IOs means that the strict timing of streamingserver is matched almost perfectly. The difference has been massive on my setup.
I realise that MP1 is pretty much finished but I think this patch is extremely worthwhile for people who stream to clients for live tv. Give me a shout if you need any more in depth detail.
***** Version 2 *****
I have attached the patch and binaries for version 2. This version reduces disk IO's by a further 75% and adds the enhancements to MPFileWriter. I have no way to test MPFileWriter so it'd be appreciated if theres anyone who can test this - please post if so.
Due to the extra methods used to pass in the channel type, there are a few more binaries included that must be replaced. They are built over 1.2.0 Alpha tag.
Changes:
TSWriter now writes 172 packets for TV and 10 for radio at a time (reduces disk IOs by a further 75%)
Streaming server changed to use a variable buffer size to match the write frequency (1880 bytes for radio, 32336 for tv)
MPFileWriter patched and matches TSWriter by writing 172 packets for TV and 10 for radio
***** Version 3 ***** (11th January 2011)
I have now attached version 3 of the patch and binaries for the latest SVN 27238. Binaries for earlier versions will be posted tomorrow (Wednesday 12th January).
Please do not use the latest SVN 27238 binaries with any version earlier than 27231, they will not work due to changes made in this and earlier revisions.
Changes:
Buffer is now throttled in TsWriter and MpFileWriter. When a new channel is tuned, it starts by writing 2, 3, 5 ... packets which increments in 20 steps up to 172 packets for TV and 10 for radio - (Thanks to arion_p for this suggestion)
Several bug fixes in StreamingServer for discontinuity and stream corruption handling (Thanks to davidf for these fixes)
There should be a slight improvement in channel zapping times compared to version 2 (not massively noticeable, probably an improvement of around 0.1 - 0.2 seconds).
The fixes by davidf should help improve RTSP streaming when you have a bad signal or corruptions in a transport stream.
If anyone can test MpFileWriter (analog cards) and post their results, it would be much appreciated
Issues:
Reported that live TV can sometimes go into slow motion. Please post logs if you see this.
There seems to be a problem when timeshifting on a network drive when the tsbuffer switches to the next file (file not found error - some weird caching problem I believe). An additional fix may be needed for this. Again please post logs if this applies to you.
Radio RTSP streaming performs a huge number of disk read IOs (~20,000) for some bizarre reason. It seems this issue has always been in MP. Additional fix required for this.
File Type: zip StreamingDiskIOFix-V3-Binaries (SVN 27238).zip (1,000.0 KB, 106 views)
File Type: patch DiscontinuityFixV3 (for 1.2.0 Alpha).patch (65.2 KB, 79 views)
File Type: zip StreamingDiskIOFix-V3-Binaries (1.1.2).zip (996.1 KB, 452 views)
File Type: zip StreamingDiskIOFix-V3-Binaries (1.2.0 Alpha).zip (994.4 KB, 227 views)
Posted on Mar 22, 2011
What is the code for I can no what channel im on and for my letters and numbers to show on my 7"wide screen lcd tv with atsc tuner tv
      Select and highlight INPUT CONFIGURATION and press ENTER. Using the left/right arrow buttons, select Antenna or Cable as desired, then select DONE. Press the CH RTN button to go back to the TERRESTRIAL menu. Select START SCAN to begin the Channel Program.Aug 7, 2013
      How To: TV Auto Program / Channel Scan - TOSHIBA FORUMS
      forums.toshiba.com/t5/Televisions...To-TV...Program-Channel.../345660
    Feedback
    LG LED TV won't show program information or channel name ...
Jan 13, 2016 | Televison & Video
My 90 year old mother cannot step through the channels using the up and down arrows, or display a guide. Can you help me help her? Toshiba CT-90302
Hello; You did not give much info here. If you are on cable TV and are running it directly to the TV with NO boxes between the cable from the street and the TV, You must do a channel search or active channel memory. Read/ download the owners manual to perform the channel memory search. When done you can just key in the channel you want on the remote control. John
Jul 07, 2011 | Televison & Video
In just bought new Toshiba regza 40" Lcd tv and auto tuned it, but the picture is terible , snowy and colours are not good, what to do...
Hello
First of all reset the TV. for that
press and hold the POWER button
on the TV control panel for 5 or more seconds to reset the TV.
Then connect the TV tt any source like outdoor areiel or cable box etc, select the appropriate input, and retune the TV. First of all, connect it to an external antenna, and set it to autotune.
You must configure the ANT/CABLE input source before
programming channels (-left-hand column).
If the ANT/CABLE input signal type is set to Cable, the
automatic channel programming process erases channels
that were previously programmed into the TV's memory.
If the ANT/CABLE input signal type is set to Antenna, the
automatic channel programming process adds newly found
channels to the existing set of programmed channels (and
does NOT erase channels that were previously
programmed into the TV's memory.) To remove an Antenna
source channel from the memory, you must manually delete
it.
To tune the TV to a channel not programmed in the channel
memory, you must use the Channel Number buttons on the
remote control.
Programming channels when the ANT/CABLE input is
configured for Cable will take substantially longer than when
the antenna input is configured for Antenna. This is normal;
however, once channel programming is finished, you should
not have to repeat the programming process again unless
your Cable TV service lineup changes significantly.
Find out the received channels are clear or not. If they are clear, your TV is perfect, and the input device you connects ot the TV is faulty. OK.
Feb 16, 2011 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
My girlfriend has a toshiba 32rv530u TV. when she first connected it to her time warner cable everything worked fine. since then time warner has added free hd channels for the local commercial stations...
After u deleted all the HD channels u don't want.Tries unplug,replug the cable box back like about an hour.For the box to upgrade it softwares,should be deleted all the HD channels u deleted.
Feb 06, 2011 | Toshiba REGZA 32RV530U LCD TV
How do i get my toshiba regza lcd tv to work via the antenna/cable input
Change video source by pressing Input button and select TV, make sure antenna is connected in RF In jack in tv then go to Tuning menu and select Auto Tuning/ Auto Scan option, tv will tune and store all available channels in memory.
Let me know model number of tv if you have additional question.
Thanks.
Jan 08, 2011 | Toshiba Televison & Video
I cant program any channels on my tv. Toshiba 42'' plasma. Do i need the remote or can i do it directly from the tv?
Which specific model from Toshiba do you have? There are several 42" TVs released with the Regza name. Most of the manuals can be found on the Toshiba support web site. http://www.tacp.toshiba.com/customersupport/
The one that I have allows for the channels to be set from the On-Screen Menu. In the TV mode, press Menu (there is a Menu button on the side of the TV). Navigate with the arrow keys (CH+, CH-, Vol+, Vol-) to the Setup menu and highlight Installation and press Enter (the Menu button is also the Enter key when using the buttons on the TV). Then highlight Channel Program and then Start and press Enter. When the search is done, press Ch+ or Ch- to view a station. To add or delete channels, use the Channel Add/Delete that is one line below Channel Program. Use the enter key to change the check mark status next to a channel. If adding a digital sub-channel not previously found, enter the number manually on the remote using the 100 key to add the dash. If the channel isn't found, an error message will result.
I hope this helps.
Jul 28, 2010 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
My TV Sharp 26 SB1 LCD PBS channel breaks up
Do any other OTA channels break up on this TV? Look through your setup options menu for a TV reset (memory or restore default or a similar command) . Do the reset and exit the menus (save the action on most TVs); then return and rescan the OTA channels.
On a different brand of TV this worked. The channel had broken up for several weeks; the reset was used when the channel finally became totally corrupted (no video on one sub-channel, no audio on the other).
Some tuners need a stronger signal to be stable; you may need an amplifier on your antenna.
I hope one of these ideas helps.
May 01, 2010 | Sharp Televison & Video
Intergrated freeview not working
It's a corrupted firmware, dude. As you may have "automatic firmware update" activated, your tv auto-updated itself at night and, when you tried to turn on next day, you realised the screen is blank and the menu is inaccessible. The only thing you could do now is go to a Toshiba technician and ask for a firmware update. It will solve your problem, as far as it solved mine too. If you don't have guarantee, they'll probably charge you for the update... but don't worry: it mustn't be very expensive.
Good luck.
Mar 06, 2010 | Televison & Video
I just got a Toshiba HDTV 40RV525R and don't have a remote or owners manual. I have it set on channel 3, but don't know how to get any other channels? Can I move to another channel without a remote? ...
Yes you can if you have a signal hooked directly to the tvs antenna input. On the side of the tv you have some buttons including menu, volume which act as left and right while you're in a menu, channel which are up and down while in a menu. So, press menu and you should see a menu on the screen.Open the terrestial menu then input configuration and choose either cable or antenna to match what you connected to the tv. then select done to put that in memory. Open the menu aagin, go to set up then installation, then terrestial, then channel program and select start. The tv will start changing channels and will put in memory any channel it finds while searching. After this is done you can use the channel up and down buttons to scroll through all the channels.
Dec 05, 2009 | Toshiba 19LV505 DVD Player
I have a 32" Toshiba 32AV500U 32-Inch 720p LCD HDTV along with a HDTVi VHF/UHF HDTV Indoor Antenna. I purchased the TV and antenna about a year ago. I am unable to get any digital TV, only analog. I was...
Look in your manual for a channel scan entry. It should be an item in your setup menu. What this does is re-scan for all the signals it can receive.
Once the scan is done, it should display all the channels that are viewable in your area
Jun 20, 2009 | Toshiba 32AV500U 32 in. LCD HDTV
Televison & Video Logo
Top Televison & Video Experts
