Black & Decker 3/8" Variable Speed Reversing Drill Kit" [Misc.] Logo
Posted on Mar 22, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My DR201 works great in the LEFT (clockwise) setting but NOT in the RIGHT (counter clockwise) position. It will occasionally work in the RIGHT position, but is intermittent. It has always functioned this way in my years of ownership.
Charles Huckeba
Level 2:
Genius:
  • Expert 1,114 Answers
  • Posted on Mar 22, 2011
Charles Huckeba
Expert
Level 2:
Genius:
Answers
1114
Questions
0
Helped
322186
Points
316
All you have to do is take the model number and go to Sears to order a trigger switch. Take the cover off of the drill, take the wires off the old switch, and put the new one in. It is super simple.
2answers
Why does my top load whirpool washer restart on its own after it finishes the last rinse and spin cycle. It does this on all settings, delicate, normal or heavy.
  1. Turn the washer off.
  2. Set the mode selector dial to NORMAL.
  3. Turn the dial counter clockwise ONE click (LEFT), clockwise THREE clicks (RIGHT), counter clockwise ONE click (LEFT) then clockwise ONE click (RIGHT).
  4. Now press the start button.
  5. All the cycle indicating lights should be illuminated.
  6. Press the Start Stop button once.
  7. Rotate the dial until Rinse, Wash, and Stop light illuminate.
  8. Turn the washer off and unplug it for 10 seconds.
  9. Finally, turn on the washer and it should now be reset.
  10. Run a test load empty to be sure the reset worked. If not perform the reset procedure one more time.
8helpful
Cae2743bq will not turn on all lights on and lid lock is lit up
Try this, worked for me! :)
New WHIRLPOOL Top Load Washer
Model #'s CAE2743BQ, CAE2763BQ
Cycle Selector Knob key dance: [CCW=Counter Clockwise and CW = Clockwise]
Start On "NORMAL"
1 step CCW (Left)
2 steps CW (Right, Right)
1 step CCW (Left)
1 step CW (Right)
Stay on "HEAVY DUTY"
(If unsuccessful LEDs will not flash, and you must return the selector to the Normal Cycle position and
wait 4-5 seconds before retrying. )
If you are successful in the process, all LEDs will be flashing
Toggle between HEAVY DUTY and NORMAL until ONLY the RINSE light is on, then press the
START button for about 30 seconds. Machine will then enter CALIBRATION mode for about 2 - 4
minutes. DO NOT RAISE THE LID
2answers
How do you remove the pulley off of the tensioner on a Buick Le Sabre
That is the right way, spray the bolt with some wd40 or liquid wrench.
I purchased a Wilton 6 in grinder, model 17203. It spins in a counter clockwise direction. Is this normal? In other words the wheel is turning down on the material being worked. Thanks Jim Price
Counter-clockwise as viewed from which end? The correct direction as viewed from the right end would be counter-clockwise. As viewed from the left end it would be clockwise. In other words, when using the grinder from the front, the surface of both wheels should be going down. If this is not the direction it turns, take it back. Good luck, Al K
On my ziess conquest, what turning knobs do what? which one makes it go up and down and which one makes it go left and right?
The top knob should be marked with a "U" and an arrow pointing clockwise. Turning this knob clockwise should adjust point of impact Up, and turning it counter-clockwise should move it Down.
The knob on the side should be marked with a "R" and an arrow pointing clockwise. Turning this knob clockwise should adjust the point of impact Right, and counter-clockwise is Left.
We have a Viewsonic VX2235wm Black 22" Widescreen We have been experiencing a Grey shadow to the right - damn annoying. Can you please help.
There are "on-screen controls" (electronic) on the monitor and can adjust the screen "position" up-down, left-right, wider-narrower and perhaps twist; clockwise-counter clockwise).
Try that and see if it removes the grey (empty?) area.
Brock
3helpful
Left park lights stay on car off
190e light switch turned counter clockwise all the way to the left is for left front and rear parking light.turn switch clockwise 1 position and the right parking and tail light will be on,turn 1 more position clockwise and all lights will be off. if lights continue to be on replace light switch
21helpful
2answers
Know combination, but cannot open sentry safe 1250
If you know the combination:
1) Turn the dial to the left a few complete rounds, then stop on 1st number.
2) Turning the dial to the right, pass up the 2nd number once, then stop on it on the next round.
3) Turn the dial to the left directly to the 3rd number then stop.
The handle should open now.
24helpful
Setting instruction for Accurist world time wrist watch
Same just happened to me, performthe following:
The analogue hands are not precisely synchronised with
the digital time?
1. Press the lower right button to move the mode indicator
hand to CHR.
2. Pull the lower right button out one click. The hour, minute
and UTC hands will retract towards the straight up 12 O’clock
position. You will see UTC on the top half of the digital display.
3. Press the upper right button to advance the hands to the
straight up 24-hour position. Use the lower left button to go in
reverse.
4. Press the upper left button. You will see HR on the top half
of the digital display. Press the upper right button to advance
the hour and 24-hour hand clockwise until they both point
straight up at the 24-hour position. Use the lower left button to
move the hand anti-clockwise.
5. Press the upper left button. You will see MIN on the top half
the minute hand clockwise or the lower left button to move
anti-clockwise until it is pointing straight up at the 12 O’clock
position.
6. Push the lower right button back in one click.
The watch malfunctions in some way and the above
procedures do not work.
1. Press the lower right button until the mode indicator hand
points to TME.
2. Pull the lower right button out one click. Press the other
three buttons down simultaneously for three seconds and
release. You will see 8’s on the digital display.
3. Press the upper left button. You will see UTC on the top half
the hands of the top dial to the straight up 24-hour position.
Use the lower left button to go in reverse.
position.
Jul 06, 2008 • Watches
Top Black & Decker Drills Experts
Sean Wright
Sean Wright
ADMIN Andrew
ADMIN Andrew
Paul Carew
Are you a Black & Decker Drill Expert? Answer questions, earn points and help others
