Question about Cub Cadet Lawn Mower Electric PTO Clutch Replaces CUB CADET 7173385A
How do I remove the PTO clutch on my Cub Cadet Model LT1040?
5 Suggested Answers
  • 146 Answers
SOURCE: cub cadet pto won,t stay engaged
Sounds more like a PTO clutch failure, rather than the switch. The clutch is mounted on the engine shaft, between the hydrostatic drive pulley (nearest the chassis) and the mower deck belt pulley (farther from the chassis).
Since it's an expensive part, make sure the problem isn't in the switch or wiring first. You could do that by probing the wires to the PTO clutch with an automotive test light - they are inexpensive and handy. Clip the ground wire of the test light to the chassis, and probe the hot wire to the clutch (it's the one that doesn't connect to ground) when the engine is running and the PTO switch is engaged. Obviously a helper has to be in the seat, and you should be careful doing this. If the light glows brightly, and the clutch doesn't engage, you definitely have a bad clutch. Good luck! Please rate my answer if helpful, thanks.
Posted on Jul 07, 2010
highspeedsan
  • 61 Answers
SOURCE: cub cadet dead as a door nail
I have the same mower. The wires do need to be connected. It is a safety feature on the cubs. The engine will not start if the electric PTO is engaged. I just went into the garage, pulled the pto lever out to engage, pushed down brake, tried to start and it would not start. I suggest reattatching the wires and trying it. Hope this helps.
Posted on Apr 25, 2009
panilling9
  • 284 Answers
SOURCE: engine stalls when electric PTO clutch is engaged
check your spacers to be sure you havent locked the clutch assembly directly to the motor shaft
you should be able to turn it fairly free less some clutch drag
Posted on May 26, 2009
  • 110 Answers
SOURCE: Cub Cadet LT1042 PTO won't disengage
If its an electric PTO then the switch on the dash is bad, Its a lever type ungagement then the little break shoes that rub on the blade spindles are either worn out or mis adjusted.If it started when you changed the blade drive belt its possibly the wrong belt??
Posted on Nov 01, 2009
Need to know the pitch 8m for pto clutch
if your talking about the bolt that goes through the center of the pulley your model number shows it as a 3/8-24x1.75 long. everything I see on the pto is standard not metric. this link will show you the pto breakdown for your model
Parts and Diagrams for Cub Cadet 144 653 100
May 16, 2014 | Cub Cadet Garden
Keeps blowing fuse
There are several things that can cause the fuse to blow. PTO stands for Power Take Off and most likely this will not be the problem unless it blows the fuse when it is turned on. What you are saying is the fuse is blowing by just turning on the switch will be a short which can be anything from a pinched wire, shorted diode, short in the stator. bad voltage regulator.etc
Apr 17, 2014 | Cub Cadet Lawn Mower Electric PTO Clutch...
I need part no. for manufacture date 2005 cub cadet lt 1045 modle ps-sv600 0009 pto clutch
I have a 2005 Cub Cadet LT1042, Spec. No. PS-SV590-0003, but my parts manual also lists part numbers for the LT1045. The clutch part no. given for your model is 717-04174.
Hope this is helpful.
Paul
May 10, 2013 | Oregon Scientific Electric PTO Clutch for...
1806 cub cadet PTO blows fuse when engaged
check the pto switch..un hook it if thats it then replace
Nov 19, 2012 | Cub Cadet Lawn Mower Electric PTO Clutch...
How do you remove the pto on Cub cadet LT 1046?
it should pull off after removing the center bolt
Aug 05, 2012 | Garden
My cub cadet tractor starts but the pto clutch stays engeged and i cant shut it off(pto)
The clutch has it's own brearings in it. You have to replace the hole PTO.Sometimes you can find a Aftermarket PTO clutch. There usually A little cheaper.
Jul 10, 2012 | Cub Cadet Lawn Mower Electric PTO Clutch...
How to remove pto clutch on cub cadet model 2186
unplug it remove the center bolt and remove the bolt that stops the clutch from rotating
Apr 23, 2012 | Oregon Scientific Electric PTO Clutch for...
Cub Cadet Lawn Mower Electric PTO Clutch Replaces CUB CADET 7173385A Logo
841 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
DarkfireVA
Level 1 Expert
Matt Olenzek
Matt Olenzek
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
