Question about DeLonghi Prima Donna Avante ESAM6700 Automatic Coffee Coffee Maker
Hello We have a prima donna machine and
Hello We have a prima donna machine and the coffe is never hot enough. Is there a way to make it hotter ?
    Genius:
  • 1,739 Answers
Check your programmed temperature setting; perhaps your machine has been set at low or medium.
Following are the instruction for Setting the Temperature from the manual for the ESAM6700.
1. Press the P button to enter the menu;
2. Press the < or > until "Set Temperature" is displayed;
3. Press the OK icon;
4. Turn < or > until the required temperature (high, medium, low) is displayed;
5. Press the OK icon to confirm (or the ESC icon to cancel the operation);
6. Press the button to exit the menu.
For a hotter coffee, before delivery rinse the appliance through by pressing the Rinse icon and confirming with the OK icon. Hot water
flows out of the coffee spouts and heats the internal circuit of the machine so that the coffee delivered will be hotter.
For an even hotter coffee, heat the cups by rinsing them with the hot water.
Posted on Mar 22, 2011
My primadonna has started to make very loud noises when preparing coffe and also when it returns aften the coffee has run through! Like a squeeking noise and very loud. Anyone who knobs What to do? The...
Possible cause is the vertical 'screw' shaft that the brew unit moves up & down on. Best have it checked out by a repair shop as there is little you can do unless you have had one of these apart before - not recommended.
Feb 07, 2015 | DeLonghi Prima Donna Avante ESAM6700...
Prima donna coffee machine hot water spout not working
does it get past the waiting part if not try resetting coffee maker by disconnecting from power point for 24hr the try unit again.
Sep 06, 2014 | DeLonghi Coffee Makers & Espresso Machines
Our Delonghi Prima Donna always made hot coffee up until 2 weeks ago
Try first to heat the cups ,and then make the coffee.
Becouse the water for coffee and for hot water comes from the same way.
Apr 25, 2017 | DeLonghi Prima Donna Avante ESAM6700...
Have a delonghi Prima Donna 6700 coffee machine and get this message
Hi there coffee person.
Have you tried disconnecting the machine from the power supply. As well as that check if there are enough coffee beans in the bean in the compartment and enough fresh water in the water tank. Not only this but is the compartment with the coffee "tablets" - full or empty. Fill or empty accordingly. Connect to power again, if the machine does not work the only advice have from here is "to clean the machine" as described in the manual or as you are used to.
Good luck
kolbrun
Mar 03, 2012 | DeLonghi Prima Donna Avante ESAM6700...
Recently descaled delonghi prima donna not frothing
milk unit pipe s blocked needs strip down...07779933829 uk we repaire
Jan 15, 2011 | DeLonghi Prima Donna Avante ESAM6700...
No hot water coming out of the water spout - yet makes coffee ok.
There is a blockage in the milk/steam circuit. Most likely one of the solenoid valves or possibly the boiler. Would advise you take it to an expert repairer unless you are very handy with such things and have access to spare parts and cleaning chemicals.
Nov 14, 2010 | DeLonghi Prima Donna Avante ESAM6700...
DeLonghi Prima Donna Avante ESAM6700 Automatic Coffee Coffee Maker Logo
687 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
83bj60
Level 1 Expert
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
