Televison & Video Logo
Posted on Mar 22, 2011
2006 legend lcd tv model lec3719 turns on but there is no picture or sound
5 Related Answers
A
Anonymous
  • Posted on Jan 07, 2008
SOURCE: lcd tv no picture
hdfghdfhdfnd
littlebug1
  • Posted on Jan 12, 2008
I took mine back and they replaced it! Problem solved!
A
Anonymous
SOURCE: lcd tv
i have the same problem which im guessing is the tv itself because i tried both hdmi ports with two cords and the composite cables but still same prob. so i have no idea what could be causing this
A
Anonymous
  • Posted on Mar 12, 2008
SOURCE: Legend LCD LC1916L TV Picture
try contacting this e-mail at legend i have the same prolem
[email protected] <[email protected]>
freetek
Steve Allison
  • 5569 Answers
  • Posted on Sep 01, 2008
SOURCE: No picture on a Westinghouse lcd tv model ltv-20v4
The simplest problem would be the failure of the backlight.
In case you don't already know it, there is one, and they may or may not last forever.
Also, there is an extra power supply to produce the high voltage the lamp needs to fire that may have failed.
Sometimes, you can look at the screen from an angle to see if there is any sign of movement.
If you can see program material causing a change in the faint image, then you can be pretty sure it is one of the two problems mentioned.
Is T-con Board in Legend TV MOdel LE3233B THe cause for no picture just vertical Lines Have good sound
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Legend lec3719 has horizontal lines
It sounds to be a main digital board fault. If you wish to get more, http://electronicshelponline.blogspot.com/ Pull up previous posts there, either by type in the Brand name to your set in its search box, or view it in Mosaic / Timeslide / Flipcard option.
On my 26" legend TV,
Go into your user menu and turn off closed captioning. Sounds like it got turned on by accident.
2006 plamsa 42 in has sound no picture was
its a 2006 LCD tv its supposed to that.
3answers
Turn on tv blue light comes on.screen stays dark .nothing happens .tv would come on after 10 minutes thenit started taking longer. now not at all.
Well first of all you can tell us the Brand and the Model number of your TV? and tell how old is your TV?
Anyway you can try to reset your TV first unplug (switch off) your TV for 24 hours and then turn it again........... let us know if further you have the same problem.......
Good Luck!!
Thanks
3helpful
Why does it take 10 minutes for my LCD Legend tv
Sounds like you have a faulty capacitor on your invertor..Gently press on the screen when there is no picture.is there light on the screen? If so, there is backlight but no video..hence a mainboard or power supply problem..If there is no backlight then the problem is the invertors or the power supply not supplying 24volts. The invertor is located on left or right hand side of screen..Check that all connections are secured and not loose.Check that the power supply capacitor tops on the power supply do not have bulging tops..If not, and voltage is reaching the invertor, then remove the invertor and check for bad solder joints and leaking capacitors.
1helpful
Legend LCD tv power issue
the problem is inside th vga hdmi board ,i have repaired 2 of these units the 37 inch version and found a bad 100 mf 10 v capacitor . little bit of soldering/de soldering skill is needed . cost of cap 0 dollars got it from old radio. ernie
1helpful
Need TV Code for a Legend TV
legend tv bought in 0507. No picture just sound
It's the power supply gone bad, just had the same problem. The repair guy charged $195.
2helpful
4answers
If you unplug the unit from wall plug for ten minutes, it should reset the picture. I would unplug the a/v cables also in case of a ground loop
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
