Question about Cameras
My camera wont turn on. I didnt drop it, or get it wet, and the battery is fully charged. Is there a way to reset it or something?
  • Cameras Master
  • 4,924 Answers
Unfortunately ...I don't think a reset will help even if it has one ...cause all reset buttons works only when the camera is on ...and for unlocking when they are stuck in an action ...In this case it is either a loose contact ..or you inserted the batteries in the wrong way ..or the batteries are not holding the right charge ....My advice is to see if you inserted the batteries right ..and look careful not to have a second button related with power...or ...change the batteries with new ones and see if this will bring it back ...If not ..it means that it has a physical issue and there is nothing to do ..but getting it to a professional and see whats wrong with it ..
Posted on Mar 22, 2011
How do you reset a Cannon Power Shot A560 camera
Lens errors are usually caused when there is something interfering with the extension mechanism , or your camera been dropped with the lens extended, or your batteries ran down . try the ff. procedures hope this helps
  • replace a fully charged batteries / battery pack
  • check out this link
Do It Yourself Digital Camera Repair
Aug 27, 2014 | Cannon Cameras
Camera wont turn on
Very odd that both cameras would stop working at the same time, has someone else abused them?
Removeing the batterys for a while is a good enought reset, check the battery connectors and contact your dealer if they both have warranty you will get them repaired or replaced for free. other than that I can recommend you a repair man if you provide me the city you live in.
Jun 12, 2008 | Sony Cyber-shot DSC-T10 Digital Camera
I can't turn on the camera, even with a fully charged battery.
The battery contacts are like little springs, as the camera gets jostled these can stop making good contact. Open the battery case and try force holding the battery against the contacts (You may need to hold a piece of metal across the bottom of the battery as you push) Then see if the camera comes on.
If it does, you may have to stuff, pull, or rig the battery to fit more securely.
Mar 17, 2010 | Canon PowerShot SD950 IS Digital Camera
Camera wont power up
The problem you describe is frequently due to corrosion on the battery contacts inside the camera. Remove the batteries and wipe the inside contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sand paper). Remove any residue that may have fallen into the battery compartment during cleaning, wipe the ends of the batteries, and replace them in the camera. This cleaning process works about 90% of the time, and I hope that it cures your problem.
Sep 11, 2009 | Sony Cybershot DSCW80 7.2MP Digital Camera...
I left my Sony DSLR our in then .. it didnt rain for a long time. When I finally remembered and went to pick it up it was completely dry .. we didnt turn it on and we took the battery out immediately .....
Hi!
You may keep it turned off until all the external parts and the battery compartments get dry. Furthermore, since the Camera has got wet in rain so there is possibility that rain water may have imbibed inside the Camera thus causing mechanical failure.
So, if the Camera doesn't turn ON even after drying it completely and charging the Battery fully. In that case, service will be required.
Aug 24, 2009 | Sony Cameras
One day camera just stopped turning on.
Try the following:
1). Check batteries whether they are fully charged.
2). Check with Battery terminal are clean. You can clean them with a ear bud using some alcohol or spirit. Wipe the battery terminal with a clean dry cloth.
3). confirm that the memory car slot/battery cover is securly closed.
4). Reload the battery several times. This will also remove poor contact between camera and battery terminals.
5).Check battery are loaded in the correct direction.
If the probem persists, you might need to take it to the service center.
Mar 02, 2009 | Casio Exilim EXZ1050 Digital Camera
Camera wont turn on
Here are some simple things to try first for a camera that won't power on. They won't work for every case, but they're worth a try:
http://camerarepair.blogspot.com/2007/11/simple-fix-for-dead-cameras-that-wont.html
May 27, 2008 | Canon PowerShot S45 Digital Camera
Won't Even Turn On
Feb 16, 2008 | Canon PowerShot SD400 / IXUS 50 Digital...
Wont turn on
Possible failed battery showing fully charged but actually not -or even charger.No reset] Disconnect from the wall socket- re connect and tell us if the battery is now charging. If show full- replace battery. Also tell Sony customer support
Jul 31, 2007 | Sony Cyber-shot DSC-T10 Digital Camera
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
