Question about Sony Playstation 3 (PS3) Console
PS3 get green/white lines and may scramble the images on games every couplf os seconds. Happens to Both Disc games and games on the hardrive. HOME is out of wack too. Store seemed to be OK.
    Filmmaker:
    Uploaded 5 video answers.
  • 84 Answers
One possible fix is to put the ps3 into recovery mode and formating the drive. WARNING: YOU WILL LOSE ALL SAVE DATA, MAKE SURE YOU BACK UP YOUR DATA FIRST. A video tutorial can be found here (http://www.youtube.com/watch?v=yZWye1CLTVo)
If that doesn't wor kthen there is a problem with the GPU (Graphic Processing Unit) possibly caused by overheating. If your ps3 is still under warranty I would suggest sending it to Sony for repairs, if it is not under warranty then it will cost you $150 to send it in for repairs.
Sony warranty information: http://us.playstation.com/support/warranties/ps3/
Posted on Mar 22, 2011
  • Wakakanada Apr 09, 2011
    I just bought a new ps3, TV, AV and had the green line problem. After no luck from internet suggested fixes, I was told by a salesperson at Futureshop that their tech guy advised that ps3's just don't seem to like being in HDMI inputs other than the first one. Sure enough, when I plugged it into the first HDMI input in my AV it worked perfectly. The other two inputs work fine for 3D TV and Movies, so perhaps there is something to this. All my gear is under warranty, but this seems to have worked...should I still consider returning it for repairs, or is this just the way it is???
My ps3 will only read one disc i have tryed all my other games and rebuilding the hardrive but no good ?
Try looking at your games and seeing if they are scratched or damaged, and if that isn't the case then it is probably a problem with the ps3 itself. If you can, phone Sony's support line and send in your ps3 if you still have your warranty, and you'll get it fixed for free.
Mar 02, 2011 | Sony Playstation 3 (PS3) Console
My playstation 3 will light up green then yellow
1. Try turning the ps3 on and off and then hitting eject.
2. Do Not try to open up the playstation. You may do more damage than good.
3. Try to halfway insert another game, cd, or dvd into the playstation 3 and press eject.
4. Here's the one that worked for me. I slid another compact disc into the console almost all the way but still holding on to it and pushed up as I pulled the disc back out. To my suprise another disc began to slide out with it. I had no idea how many discs were actually inside the ps3, but when I hit eject the original game that was in there still would not come out, so I new something still wasn't right. I repeated the process a few more times and low and behold, I had a total count of four, aside from the game. At last, eject finally pushed hubby's NBALive out of the playstation.
Feb 15, 2010 | Sony Playstation 3 (PS3) Console
My Ps3 is only staying on for 4 seconds (green for 2 seconds and yellow for 2 seconds) and then flashes red. when i tap the power button it stays red and repeats.
call sony the problem can be several things
call sony even if your console is out of warenty
i had the same problem a couple of months back and warenty was expired by a few months i called them and they gae me a refurbished ps3 free
Dec 29, 2009 | Sony Playstation 3 (PS3) Console
When PS3 boots the screen turns green with white dots
Emergency cooling should be cleaned. If not cleaned, you risk expensive repair.
Oct 24, 2017 | Sony Playstation 3 (PS3) Console
PS3 won't turn on
hi Torgsrus.
PS3 Light sequence
The following pictures illustrate the CECHX0X model, however the light sequence is applicable to all PlayStation 3 models.
No lights are on:
When no lights are on, this means that the main power switch on the back of the ps3 is off or the PS3 is unplugged. When the main power switch is off (the '0' is pressed) and you will not be able to access any features of the PS3 system. To turn on the PS3 system, make sure the main power switch is on (the 'I' side is pressed down).
If the PS3 does not turn on:
· Make sure the power cord is not frayed or damaged
· Try using another power cord, if available
· Make sure the main power switch on the back of the PS3 system is turned on
· If you continue to have issues contact our Technical support.
Solid Red:
When the power status light is solid red, this means that the PS3 system is off (or in standby mode).
Standby, mode means the PlayStation 3 system is off, but is ready to be turned on by pressing the power button.
If the ps3 system will not turn on when you press the power button, this is an issue with the PS3 system and you will need to send your system in for service.
Solid Green:
When the power status light is solid green, this means that the PS3 is turned on.
You should be able to navigate the XMB, play games, access the Playstation store,etc.
To turn of the PS3, simply press and hold the power button for two or more seconds.
If the power status light is green ,and you are experiencing problems- have a look on our forums for troubleshooting.
Flashing Red:
When the power status light flashes red after using the PS3 system for 3 or more minutes and shuts off, the PS3 system has possibly overheated.
This may be caused by poor ventilation or the vents may be blocked.
If this happens:
· Check to see if the vents are blocked. If the vents are dusty, vacuum the vents to remove the dust.
· If the PS3 system is in an enclosed area like an entertainment area, move it to a more open area.
· Leave the ps3 system off for 30 minutes to let it cool down.
· If you continue to have issue, you may need to send the console in for service.
Flashing Green:
When the power status light flashed green, it means that the PS3 system is turning off. Please wait while the system turns off.
If the PS3 system does not shut down immediately, it may be trying to finish save data to the Hard Drive. If it is, do not turn the main power switch on the back off as it may cause data on your hard drive to be corrupted.
If the green light continues to flash green, the ps3 system maybe trying to write to the hard drive, shutting down or running programs. It may take longer to shut down depending on when you pressed the power button. If the green power light flashed for a very long time, you can try holding the power button down for 5 seconds, the console will beep and should turn off. Then try to restart the PS3 system.
Flashing Green, Yellow and Red:
When the power status light goes from green, to yellow, to green, then to a flashing red, this means that they may be an issue with an internal part with in the PS3 system. This may be caused by a variety of reasons and would need to be diagnosed by our support line.
When the PS3 power light flashes in this order, you can contact our Support Line for further assistance.
Solid Blue:
When the disk status light is remaining a solid blue, it means the disc is inside the PS3 system. If you wish to eject the disc, hold down the eject button for 2 seconds and the blue disc status light will flash indicating the PS3 system is attempting to eject the disc . (NB: the power indicator light will always be a solid green).
If the disc is inserted into the ps3 system, but does not show up on the xmb or will not play, this may indicate an issue with the reader- check our guide Discs are not loading in my PlayStation 3? for further troubleshooting.
Flashing Blue:
When the disc status light is flashing blue, it means a disc was just inserted into the ps3 system or a disc is trying to eject from the ps3 system. Depending on when you pressed the eject button, it may take longer for the disc to eject. (NB: the power light will always be a solid green)
If the light constantly flashes blue, it may be an issue with the disk being stuck in the system. If this happens there is no way to remove the disc yourself if you are using an orginal 60GB PlayStation.
Dec 02, 2017 | Sony Playstation 3 (PS3) Console
Can i have the phone number for the sony ps3 help line
PS3 when playing a game (Call to Duty 4), game quit, TV screen has black, white and gray vertical lines on it, disc will not reject, game control red lights (4) keep blinking, and PS3 not accessible.
Thanks
coc5th46@yahoo.com
Jul 16, 2008 | Sony Video Game Consoles & Games
Ps3 60gb no operating system
First the PS3 doesn't use flash memory, it uses a 2.5in SATA hardrive. It can't be that there is no OS, otherwise the PS3 would write it to the hardrive, it must be corrupted or have some other problem.
I would recommend buying a 2.5in SATA hardrive - they're very cheap. Ask in store for one, or you can get one from Play.com. If that doesn't work, it's a problem with the PS3 itself and you should phone Sony.
Jun 20, 2008 | Sony Playstation 3 (PS3) Console
Error 8001002b
wat if its showin up as a game and there is no update
Dec 30, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
122 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
