Question about Dell Dimension 2300 PC Desktop
Dell Dimensions 2300 hard drive replcement
I have a Dimensions 2300. I want to replace it with a larger hard drive.
what are he limitations of size and type?
LeRoy
grandpask193968@sbcglobal.net
  • grandpak1939 Aug 03, 2008
    Will this work:
    Maxtor 300GB Ultra16 PATA Internal Hard Drive
    • 300GB
    • Parallel ATA (PATA)
    • 300GB
  • 659 Answers
Seagate Barracuda 7200.10 750GB Hard Drive
goes for about 180 bucks and it a IDE PATA Drive I do belive since your dimensions 2300 motherboard 3T237 is only IDE and does not have SATA
your motherboard can also handle 1 gig of ram so if you havent maxed out your motherboard yet I would highly suggest it. Ram for it wont cost you much either.
I would add the newer drive as a secoundary drive since I am sure that your operating system is pre loaded.
or you can also add external drives to your system as well for more storage as well and they are starting to come down in price as well. you have options it all depends what ya wanna do with it.
Posted on Aug 03, 2008
How do I replace hard drive in dell OptiPlex 360 with Seagate barracuda 160 gb 7200 sata hard drive?
Do you want to replace it or add it as a slave drive....is your hard drive bad or just limited use...there are different jumpers that need to me set for different way of installation....do you have a new license for installing an operating system....several questions come to mind...I've replaced several and added slave units but it differs.....Can you give me more details and I may be able to assist you with your endeavor....Do you have an alternative method for accessing the internet or better yet, fixya website?
Oct 18, 2013 | Dell Dimension 2300 PC Desktop
What can I replace a rheem 71-30S 120v 30 gallon water heater with thats the same size, not larger in dimensions
Measure what you got, and add comment.
Measure across the top.
And then measure the height.
Then I will check resources and find close match.
Otherwise, the last guy wanting a small water heater bought his at local Lowes and it was small enough
Apr 13, 2013 | Water Heaters
What's the maximum hard drive I can install in a Compaq SR1420NX I have a 80 hard drive right now I want to install a larger one. Will this computer handle a larger Hard Drive
The BIOS has a max. hard drive size limitation. Check the manual for the maximum size the motherboard can support.
If the maximum size hard disk it can support then you can add a second hard drive in the computer as a SLAVE hard drive to double your disk space capacity.
Mar 15, 2011 | HP Compaq Presario SR1420nx...
What Is The Bigger Hard Drive I Can Use
It looks like this computer only supports IDE hard drives.
The larget drives are all SATA hard drives. You can get a host card like this one: http://www.newegg.com/Product/Product.aspx?Item=N82E16816102065 which will give you some SATA ports. Make sure you have a free PCI slot.
There's a limitation with current operating systems that won't let you have a boot drive be larger than 2.2TB. I wouldn't recommend getting a drive larger than 2TB for that reason.
Good luck.
Mar 01, 2011 | Dell Dimension 2300 PC Desktop
I want a larger capacity drive. can i replace the mk1637gsx with a MK3265gsx?
It depends on whether the motherboard will correctly recognize the larger disk-size, but the most-likely answer is 'YES''.
Check the web-site of the manufacturer of the motherboard, to see if they have any model-specific limitations.
Oct 30, 2010 | Toshiba MK1637GSX 160 GB IDE Hard Drive
Dimension 2300 PC Desktop: remove hard drive?...
Here ya go
http://support.dell.com/support/edocs/systems/dim2300/replace.htm#1126855
May 07, 2010 | Dell Dimension 2300 PC Desktop
HDD capacity greater than 128GB with Acer Travelmate 2300
ive had a look on the acer website and there is a replacement bios available , but theres no mention if it would enable large Hd support , rather than flashing your bios and potentially destroying your laptop i would purchase a external drive , you can get the enclosures for 10-20 pounds and fit a decent size HD in this
http://www.ebuyer.com/product/159438/show_product_reviews
Nov 09, 2009 | Acer TravelMate 2300 Notebook
I have a dimensions 5150 and want to add more disk space. What is largest size hard disk i can add and is there a thickness issue to bear in mind
technically there is no specific size limit ..currently the max. avaiable for home use is 1.5TB ...(LARGEST) hard drive
your model can surely fit in 500 gb of disk space...(again it all depends if u would be needs so much ) i leave that for u to decide .
assuming to dont have big video cards , that may cramp the internal space , i am sure anything under 500 gig should easily fit in ...
good luck
Oct 26, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
DOES THE VERBATIM HARD DRIVE NEED TO BE FORMATED?
Many Verbatim hard drive models with a FireWire interface come “Mac formatted” – pre-formatted for immediate use with Apple Macintosh computers running Mac OS. They are formatted as HFS+, the preferred format when using the drive exclusively with Mac OS computers.
Note: A Mac-formatted drive will not mount on a Windows PC.
If you plan to use a Mac-formatted hard drive only with computers running Mac OS, you can leave it formatted as it comes from the factory. However, if you plan to use your hard drive with computers running Windows, or with both Mac OS and Windows computers, you should reformat your Verbatim hard drive before saving data to it. Generally, for use with both Mac OS and Windows you should format to FAT32, and for use strictly with Windows you should format to NTFS. More information about these two format types is given below.
FAT32 FAT32 is compatible with the following Windows operating systems: Windows 98, Windows 98 SE, Windows Me, Windows 2000, Windows XP, Windows Vista. FAT32 can also be read by Apple Macintosh computers running Mac OS.
Limitations: Maximum file size is limited to 4TB. Furthermore, using the formatting tools included with Windows 2000, Windows XP, and Windows Vista users will not be able to create partition sizes larger than 32GB (though they can access these larger partitions). This limitation does not apply to other supported operating systems. Furthermore, Verbatim provides a FAT32 format utility (see further below for download instructions) that eliminates the 32GB partition limitation.
FAT32 is a good choice if you’ll be using your Verbatim hard drive with older computers running Windows 98, Windows 98 SE, or Windows Me, or if you’ll be using it with both Windows and Mac OS computers.
NTFS NTFS is compatible with the following Windows operating systems: Windows NT, Windows 2000, Windows XP and Windows Vista. NTFS usually results in higher performance than FAT32, and will permit users to create partition sizes larger than 32GB, and file sizes larger than 4TB.
Limitations: NTFS is not compatible with Windows 98, Windows 98 SE, Windows Me, or Apple Macintosh computers running Mac OS.
NTFS is a good choice if you will be using your Verbatim hard drive only with one or more computers running Windows XP, Windows 2000 or Windows Vista. This is also a good choice if you plan to store files larger than 4TB, such as digital video files.
Per: http://www.verbatim.com/downloads/format.cfm
Good Luck
cbinny1
Oct 20, 2008 | SimpleTech SimpleDrive Portable USB 2.0...
Dell Dimensions 2300 hard drive replacement
that one looks like you would need a Serial ATA-enabled motherboard or adapter card find one that is pata/ide
Aug 03, 2008 | Dell Dimension 2300 PC Desktop
Dell Dimension 2300 PC Desktop Logo
393 people viewed this question
Alun Cox
