Question about Olympus SP800UZ Digital Camera
When i turn on my camera it says write protection and i cant take any photos
  • 262 Answers
I looked at the specs for your Olympus SP800UZ Digital Camera, it must be quite new because they were only announced on 2nd Feb last year. Nice camera :-) Your camera takes the regular SD or SDHC cards, so this write-up that I've posted before certainly applies in your case. I hope that it covers all the possibilities for you, comment back if you have any extra questions, for example if you need to find the system reset in your particular menu.
Why does my camera say "Card Locked" or "Write Protected"?
The basics. In the same way that the recordings on audio cassettes and VHS tapes could be protected by breaking off the little tab on the back corner, the material on a memory card can be protected against being overwritten. Instead of a tab to break off, write protection is done by a tiny slider on the edge of the card (opposite the cut corner). Before the camera will take pictures, it's necessary that this slider on the card operates a microswitch in the camera, which it will only do if it's NOT in the 'lock' position. The slider actually does nothing inside the card, which is why I don't call it a 'switch' even though it seems like one. Its only purpose is to be detected by the microswitch in the camera's slot, and it's the camera that takes care of the write protection, not the card.
Diagnosis.
Obviously the first thing to do is to check that the slider is NOT in the lock position. If the camera is giving you this error in the unlock position, it means that the slider has failed to operate the microswitch, or that the microswitch itself is faulty, or possibly that there's some file system error with the card. To diganose the problem, it would be really helpful if you could try two or more different memory cards in the camera and see if just one, or all of them exhibit the problem.
If only one memory card exhibits the problem: In this case, it's clearly something to do with the memory card. Is the slider worn, bent or missing? A missing slider will write protect the card in the same way that sliding it to the 'lock' position will. There's another possibility. I've recently discovered that
some cameras which use xD-Picture cards also give this error even though those cards don't even have lock sliders! Furthermore, some users have reported fixing this error by reformatting the card. Therefore, I feel it's also possible that your error may be fixed by reformatting. Before you do this, make sure that you've copied all you want off the card and then use the camera's 'format' function to reformat the card. I advise using the camera for the format function because this guarantees the correct file system. If you use your computer to format it, you may easily get the wrong one. However if you need to do it this way, see which file system is currently in use on the drive before you start. Go to "My Computer" and right click on the drive which is the memory card, and choose "Properties". Examples of filesystems are "FAT" (probably FAT16), "FAT32" and NTFS; to make sure your reformat is successful, ensure you use the same filesystem as before.
If some memory cards work, and others don't, or the same cards sometimes work but only sometimes:
The slider is really tiny, so it's possible that the number of people reporting this error is caused by lack of precision in manufacturing sizes. It must be hard to make a microswitch that can feel such a small thing. Does a better brand of card work? Can you bear to simply stick to the better brands, or the ones that work most reliably? As a remedy of last resort, you could try wrapping a small strip of sticky tape over the slider to increase its thickness, but I think this is a risky solution. There's a risk that the tape will come off in the slot and cause even more problems, or that the tape will be so thick that the card will jam in the slot and you'll have trouble getting it out.
If all of your memory cards behave in the same way: In this case, it's clearly something to do with the camera. It could be that the microswitch is broken, or there's some software error. Although it's less likely, let's cover the software error first; please find the 'system reset' function in your settings menu and use it to clear everything. Any good? If not, try the sticky tape solution in the last paragraph in the hope that it's a size/fit problem with operating the microswitch, but if that fails we're out of options really, beyond a repair of that microswitch.
Posted on Mar 22, 2011
SD card is protected in my camera need my photos
There is a small white button on a slider on that card. Might it be that it has been protected by it?
Try sliding it towards the opposite of wich it is and make sure it stays!
Then retry!
Feb 10, 2012 | PNY 2GB microSD Memory Card
I cant take photos anymore and the LCD screen says CARD'S WRITE PROTECT SWITCH IS SET TO LOCK.How can i solve this problem?
You didn't specify the make and model of your camera, so I'm going to assume it uses SD and/or SDHC cards.
SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
If this doesn't do it, try another card.
Dec 28, 2011 | Cameras
I just turn off my camera and i remove the memory card to download my and photos to my laptop after that i put back in my camera and when i switch on i got a massege that the card had been protected...
You didn't specify the make and model of your camera, so I'm going to assume it uses SD and/or SDHC cards. If this is not the case, please reply to this post and specify the make and model.
SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Aug 14, 2011 | Cameras
Cant Take pictures
1) Take the card out, check the card, halfway up the left hand side, there may be a sliding notch. Move it to "Write enable".
or
2) Go through your camera menu look for photo protect, check if you've write protected all your photo's.
Just in case, you can download a user manual from here:-
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
May 30, 2010 | VistaQuest VQ-5015 Digital Camera
'write protect'
Have you removed the memory card and moved the switch in to the lock position by mistake? if so take out the card and slide it into the unlock position. hope this helps
Jul 03, 2009 | Fuji FinePix A400 Digital Camera
Camera wont back up to memory card
Hi there.
Check to make sure the write protection is turned off on the memory card itself, the write protection tab is located on the left hand side of the card and is usually coloured white.
Good luck and thanks for using FixYa!!
May 15, 2009 | Olympus FE-20 Digital Camera
Samsung S860...turn off photo protect?
First of all connect your camera to pc and use software unlocker to access the protected file . And then you can delete it .
Feb 18, 2009 | Samsung S860 Digital Camera
Turned on 'protect' mode on Canon PowerShot SD 300 and cannot turn off!
the only thing i can suggest is to buy a card reader that connects to pc via a USB. dont know where you are from, but here in uk they vary in price from about £5. if your card is an SD card, make sure the card itself is not locked, there is a little switch on one side, usually white, this switch slides one way is locked, the other unlocked. apart from that i cant think of anything else.
good luck
Sep 13, 2008 | Canon PowerShot SD300 / IXUS 40 Digital...
Write protection
format the card through the camera menus... always make sure you safely remove camera before disconnecting (Safely Remove Hardware)
Apr 07, 2008 | Olympus Stylus 720 SW Digital Camera
SD protection
The SD card is probably write protected, on the following link scroll down to "Optional write-protect tab" : http://en.wikipedia.org/wiki/Secure_Digital_card
Jul 15, 2007 | Polaroid PhotoMax PDC 4055 Digital Camera
Olympus SP800UZ Digital Camera Logo
314 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
