Question about Garden
When I switch the nozzle to high pressure the engine cuts off. Can you tell me what's wrong
  • Kelly
    Kelly Mar 22, 2011
    Hi and welcome to FixYa, I am Kelly. I need to know w few things to help you.
    1. Your pressure washer model number
    2. The Engine number on the Engine
    3. The brand name of the high pressure pump if you can locate it. Comet and AR are just 2 names that make pressure washer pumps.
    4. When you say the engine cuts off does it sound like it is coming under and extreme load or.. that it does not have enough gas?
    I can not give you a professional answer without the information above.
    Kelly
  • rjbunting Mar 23, 2011
    HI THE MODEL NUMBER IS 020337. I'm not sure of the engine number , but it is a briggs&stratton 6.75hp. The pump is a annovi reverberi. It sounds like it is coming under a extreme load. Hope this helps. Thanks
  • 3,740 Answers
Hi again and thanks for your response. If the engine is coming under an extreme load the unloader valve is stuck in place. Since the unloader valve is on the bottom of the pump it stays wet all the time and when in not in use the metal parts of the valve corrode as will the brass parts of the pump housing.
The unloader valve is on page B of this link: (Item A)
http://www.ereplacementparts.com/troybilt-0203370-2550-psi-pressure-washer-parts-c-26780_27006_25694.html
The following steps are hard to perform without causing havoc with your engine due to tipping so, what I am recommending is that you do NOT tip the engine to perform the following procedure without any dis-assembly of your unit at this time:
- IF you have a very short garden hose like the one that would go to a hose reel or a washing machine hose. Use that hose for this procedure over night. Connect the short hose reel or washer hose to the water supply connection of the pump and also connect the high pressure hose to the pump. Pour about 5 oz of regular engine oil into the water supply hose and tie the hose so that it is elevated (to retain oil in pump) Keep the high pressure hose elevated also so that the hose does not drain oil the oil you just added from the pump. After a few minutes with the engine ign. OFF pull the engine through 2 times. Let is sit over night. (What your trying to do is lubricate the seals and hopefully loosen the grip of any internal corrosion in the unloader valve area.)
The next day... after no more than 24 hours. Connect the short hose to a real water supply and start your pressure washer. once started do VERY short bursts with the wand trigger (1sec bursts rapidly). Your trying to force the unloader valve move and cycle normally in the pump housing. REMEMBER you added 5 oz of oil yesterday to the water system so be careful where you spray the first bit of stuff coming out of the wand nozzle. Keep up this 1 sec burst cycle going for 2 to 3 minutes or if begins to work normally your done and it is time to tidy up. .
If this did not work.... (it does about 85% of the time)
- You will have to remove the unloader valve and clean it.
Once removed try to get as much stuff off of the spring and o-rings as possible.
- Also you will need to clean the pump housing where the unloader valve installs.
- INSPECT all of the o-rings for cuts and again carefully wipe them clean so as not to damage them.
- BEFORE you reinstall the unloader valve you will need to lubricate the pump housing and the unloader valve with "White Grease" (Auto parts stores have small tubes of #105 white grease) Don't be afraid to use liberal amounts of white grease.
- Re-install the valve and test
This should bring your pressure washer back to normal again.
Let me know how things went.
Kelly
Posted on Mar 23, 2011
  • Kelly
    Kelly Mar 23, 2011
    Hi again,
    I just took a short break and had a revelation that is nothing short of a keen sense of the obvious to me. Remove the high pressure nozzle and check for obstructions. inside the back of the nozzle before you perform the steps in my last post. I think your high pressure nozzle is clogged.
    Kelly
Throttle linkage is loose and when started water does not come out the nozzle after BEING BLED OF AIR
The unloader on your pump is bad...this is causing both problems. Find your pump model # ...probably an AR pump ...they fit the Honda GC engines well and go to this site Pressure washer parts catalog quick links Pressure Washers High Pressure... they can guide you to the correct unloader... Good luck
Jan 19, 2014 | Powerboss 020309 3000 psi 2.5...
How do I wire a Beckett 12v diesel burner? I have a Beckett 12v burner igniter with a fire eye, a high limit switch, and a flow switch. This unit came with all the wires cut and missing a t stat and...
first do you have a fuel solenoid???i am a burner tech for thirty plus years.fuel solenoids are mounted on the fuel pump.flow switch.high limit switch and thermostat are connected in series to feed the fuel solenoid.
Aug 16, 2013 | Briggs & Stratton Pressure Washer...
Presure washer
Adjust the screw on the pressure regulator on the high pressure hose is one way The other is to check the nozzle for obstructions. The problem is that there is insufficient flow from the nozzle so the regulator valve is trying to cycle between cut off and working pressure.. The regulator is set at factory for a particular size nozzle and anything that alters that ratio will cause you problem. The screw on the regulator has some fine adjustment to allow for slight changes. Any impurities in the water supply will tend to block the nozzle affecting the regulator .
Apr 26, 2013 | Garden
Torque specs for 1993 7.3L diesel injector
please rate, thanks
Installation
  1. Thoroughly clean nozzle bore in cylinder head before reinserting nozzle assembly with Nozzle Seat Cleaner T83T-9527-A. Pay particular attention to seating surface, in order that no small particles of metal or carbon will cause assembly to be cocked or permit blow-by of combustion gases. Blow out particles with compressed air.
  1. Remove protective cap and install a new copper gasket on nozzle assembly with a small dab of Multi-Purpose Grease D0AZ-19584-AA (ESR-M1C159-A) or equivalent. NOTE: Anti-seize compound or equivalent should be used on nozzle threads to aid installation and future removal.
    ani_caut.gif CAUTION: Be careful that nozzle tip does not strike against recess wall.
  1. Install nozzle assembly into cylinder head nozzle bore.
  1. Tighten nozzle assembly to 47 Nm (35 ft-lb).
  1. Remove protective caps from nozzle assemblies and fuel lines.
  1. Install leak-off tees and lines as an assembly by lowering onto nozzles. Connect clip and hose to fuel return elbow at pump. Install line to retaining clamps. NOTE: Install two new O-ring seals for each fuel return tee.
  1. Connect high pressure fuel line(s) and tighten to specification using Fuel Line Nut Wrench T83T-9396-A.
  1. Start engine.
  1. If necessary, purge high-pressure fuel lines of air by loosening connector one-half to one turn and cranking engine until bubble-free fuel flows from connection. ani_caut.gif WARNING: KEEP EYES AND HANDS AWAY FROM FUEL SPRAY. FUEL SPRAYING FROM PARTIALLY OPENED CONNECTION UNDER HIGH PRESSURE CAN PENETRATE THE SKIN AND CAUSE INFECTION. MEDICAL ATTENTION SHOULD BE PROVIDED IMMEDIATELY IN THE EVENT OF SKIN PENETRATION.
  1. Check for fuel leakage at high-pressure connections.
Nov 17, 2010 | 1993 Ford F350
Does not give a continous high pressure flow cuts in and out
that is sure signal of insufficient water supply!
try easy solution first:
make sure that your mains is fully open, that tap on whihc hose is hook up is fully open and hose is of "decent" diameter to allow sufficient flow.
if above solution do not work then you need to make another, more difficult arrangement:
prepare 20litres pressure tank with inlet connected to mains and outlet by short hose to power washer, fill it with water from mains, keep it under mains pressure and use karcher power washer normaly. this will solve water supply problem. twenty litres will last about 2min, because it is re-filled, under standard pressure therefore it will last about 3min...
third possibility is to stop washing...
if you find my advice helpfull, please do not hesitate to left the comment and vote for me, thanx!
Jul 31, 2010 | Karcher K2.26 Electric Power Washer
Doesnt build pressure up ,it just runs right without pressure does the compressor require being oiled?
HELLO THERE:
Here is some troubleshooting tips for you and a web link for you ok this should help
best regards michael
Troubleshooting Your Pressure Washer troubleshooting_pressurewasher.jpg General points to check if a problem occurs
  • Are the engine and fuel switches in the “ON” position?
  • When troubleshooting, always check oil and gas levels.
  • The oil for the pump is a 30W non-detergent mineral oil. Do Not fill over halfway on the sight glass.
  • Is the water tap open?
  • Check the choke and throttle levers.
  • Is the correct nozzle in the lance? Is the nozzle plugged?
  • Only the black nozzle is for soaping at low pressure.
  • Is the water-inlet screen clogged?
  • Hold the gun trigger open while pull starting the engine.
  • Check for O-rings in the lance and quick couplers.
  • Has the unit tipped over? Close the fuel switch and keep pull starting the engine until the excess fuel is burnt up, then open the fuel valve and try again. Some engines will need to be primed every time they are started.
  • Make sure the engine is turned off after each use. It should not be left running without use for longer than 2 minutes as the pump can overheat.
Are you experiencing low pressure?
  • Is there an air leak?
  • Dirty pump valves?
  • Check for worn pump valves or broken valve springs.
  • Check for a worn out spray nozzle.
  • Check for leaks in your plumping or hoses.
  • Troubleshoot your nozzle, is it turned to the highest pressure setting?
  • Is the unloader improperly set?
  • Are the engine RPMs too low?
  • Check if your water supply is sufficient.
  • Check if your engine is getting enough power.
Trouble with high vibrations
  • Do you have a sufficient water supply?
  • Is there are in your water supply?
  • Is the inlet water filter clogged?
  • Clogged or damaged spray nozzle?
  • Make sure it has the correct fuel
  • Has the choke been left on after the engine has warmed up?
If the engine won’t start
  • When troubleshooting the engine, check if it's low on fuel or oil?
  • Worn or dirty spark plugs?
  • Is the switch in the off position?
  • Is the fuel valve in the off position?
  • Is the engine flooded from over choking?
  • When cold starting, was the engine properly choked?
If the starter is hard to pull
  • Low oil in the crankcase or pump assembly.
  • Oil or fuel in cylinders (hydro locked).
  • Pressure built up in the system, relieve this by squeezing the trigger.
Sep 15, 2009 | Honda Garden
Compressor short cycles during operation. (load / unload). hose to guage and pressure switch ok. what could be the problem?
The pressure switch has an adjustment for the low pressure cut in and the high pressure cut out. If the pressure range is set too close the cycles will be short. You need to work out which setting is wrong by looking at the pressure guage when it is cycling and adjust the pressure switch accordingly.
Sep 06, 2009 | Ingersoll Rand UP6-30-125 120 Gallon...
Goes for awhile at high pressure then just cuts off
does the engine cut off or the pump cuts off.
the honda engines has a oil alert on the side, check the oil level.
check the nozzle in lance for over pressuring
Jul 03, 2009 | Honda Pressure Washer PSI 3000
Garden Logo
238 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
