Question about Epson Stylus Photo R220 InkJet Printer
I have an epson Stylus Photo R220. I have had a paper jam. I have got the paper out, but think a triangle of paper may still be in the printer at the right hand side (as you look from the front of the printer). Now the paper light continues to flash. If I put paper in the tray and press the paper jam button the paper feeds through but not all the way the last inch or two are still gripped by the rollers. No jammed paper has been pushed out by this process. What do I do next?
Paper jam, printer R230
Posted on Mar 29, 2011
5 Suggested Answers
squipps
  • 204 Answers
SOURCE: epson stylus photo r220
Open the printer Properties, Under quality there should be a box
that you can check (print in greyscale) or (print in black & white).
You have to remembe to uncheck to print in color.
Posted on Feb 05, 2008
SOURCE: Epson Stylus Photo R220
I need the software & drivers please 4 epson styuls photo R220 some one send it to wickedwelchtattoos@att.net thank you.
Posted on Sep 30, 2008
luciana44
  • 292 Answers
SOURCE: Need software for Epson Stylus R220
Use this link to go to the relevant page of Epson website.
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?oid=60202&infoType=Downloads
Select your operating system
Select the driver for windows vista.
and download and install. Hope this will help
Posted on Aug 27, 2009
jayinaki
  • 84 Answers
SOURCE: Epson Stylus PHOTO R220 red lights keep flashing
I hope this will help you :)
* Green Power light flashes- The printer is receiving a print job, replacing an ink cartridge, charging ink, or cleaning the print head.
* RED paper light is On- If the CD/DVD try guide is open, close the CD/DVD tray guide, load paper, then press the paper button. Your paper ran out or multiple sheets loaded at the same time . Load paper and press the paper butoon to resume printing.
* RED paper light flashes- Paper is jammed in the printer. Press the paper button to eject the jammed paper. If the light is still flashing , open the cover and remove all paper, including any jammed or torn pieces. Then reload paper and press the paper button to continue printing.
* RED Ink Light Flashes - One or more cartridges are low on ink. Check the message that appears on your screen to determine which cartridge is low, or follow the instructions in " Checking the Ink Supply". Make sure you have a replacement cartridge.
* RED Ink Light is ON- One or more cartridges are out of ink or not installed. If you have just installed a new cartridge, it may be incomaptible with the printer or incorrectly installed. Reinstall it or replace it with the correct cartridge
* RED Ink and RED paper lights flash alternately- The CD/DVD tray guide was left open when you turned on the printer or when printing on paper. Just simply close it/
* Green Power Light is Off; RED paperand RED Ink Lights flashing- Paper may be blocking movement of the print head. Turn off the printer, then open the cover and remove any jammed paper or other foreign objects. Turn the printer back on again. Or it may have an internal error. Turn off the printer, wait a few seconds, then turn it on again.
Posted on Jul 06, 2011
Jul 06, 2011 | Epson Stylus Photo R220 InkJet Printer
Printer won't print with Hahnemuhle 300gsm papers.
Brand new printer feed up to 350 gsm paper. Rubber paper paper pick up deterioration. Replace paper feeder. Or find similar solution (repairing paper feeder) on aicaxz's for resolving this.
Feb 02, 2010 | Epson Stylus Photo R220 InkJet Printer
Two red lights are blinking simultaneously...I check if there is any paper jam but i don't see anything. anyone can help me would be much appreciated.
first have you checked any clogged papers? have you checked ink cartridges if yes continue doing the following
Before run adjustment program or software resetter Epson Stylus Photo R220 and R230, set date setting in your computer to 12 January 2006. Appearance of adjustment program Epson stylus photo R220 and R230 like adjustment program for Epson C45. Your Epson Stylus Photo R220 and R230 must be installed correctly in your computer before using the software otherwise so this software resetter will not be used.
Here how to use the software
  • Download and extract downloaded software and run it.
  • Click accept button.
  • Set model name, port selection and destination setting and equal to your printer.
  • Click Maintenance Tab.
  • Check mark waste ink pad counter.
  • And the clear the protection counter (reset counter to zero)
  • Then click Ok, Ok
  • done
download link:
http://www.mediafire.com/?9njmgwlxqgj
Nov 10, 2009 | Epson STYLUS R230 InkJet Photo Printer
My Epson r220 photo printer is giving false paper jams. What can I do?
the false paper jam problem is creating by paper out cansor so please this is the repairing mater you care it a repairing shop.
Jun 23, 2009 | Epson Stylus R220 Photo Printer
Stylus photo r220 not picking up 4by 6 inch photo paper
move the paper sideways (end on as apposed to flat) or select portrait printing instead of standard. good luck!
Mar 11, 2009 | Epson Stylus Photo R220 InkJet Printer
R220
what type of light? ink light or paper light?
if its on ink light it means one or more of the inks is empty, if its the paper light means paper is jammed.
try to turn off/on the printer then load again paper.
Sep 26, 2008 | Epson Stylus Photo R220 InkJet Printer
Sep 22, 2008 | Epson Stylus Photo R220 InkJet Printer
Epson R220 paper feed lop sided and jammed
try putting a thick piece of card thro the paper path. this tip was given to me by an approved epson repairer. evidently paper pieces and other bits get stuck in the paper path. hope this helps , good luck
Nov 22, 2007 | Epson Stylus Photo R220 InkJet Printer
Epson Stylus Photo R220 InkJet Printer Logo
184 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
