Question about Brother MFC-845CW multi-function All-In-One InkJet Printer
I have a message on my display screen that says "unable to print 36" What does that mean and how do I fix it?
  • admnexcellen Mar 22, 2011
    Thank you. I cleared the paper but the error remains. Is there a way to reset? I've turned it off / unplugged it but the error returns when I turn it on. It was making a grinding noise when the paper initially got jammed...
  • 23 Answers
36 usually means that a paper is jammed. You will have to open it up and manually remove the paper.
Posted on Mar 22, 2011
    Novelist:
    Champion:
  • 256 Answers
HI
Error 36 refers to Paper jam to avoid paper jam use good quality paper and use proper size page
Thanks
Posted on Mar 24, 2011
BubbaGuru
  • 70 Answers
SOURCE: ! Unable to print 36
here is the solution according to brothers website
http://www.brother-usa.com/FAQs/Solution.aspx?FAQID=100000012648&Sympt=How+do+I+clear+error+message+Print+Unable+36%3f&Model=1208&ProductGroup=1&ProductID=HL4070CDW
Posted on Mar 23, 2009
SOURCE: error message on my printer that says unable to print 36
If this is a Brother clean the clear strip on the carriage assy. it is a timing strip for the carriage , I have seen ink on these cause the "36" code
Posted on Aug 05, 2009
SOURCE: Unable to print 36
lift the lid to where the connections cable is
I have had this problem several times & this is the only fix
Posted on Feb 02, 2010
komguy
  • 2306 Answers
SOURCE: Print Unable 36
That error is a carriage travel error, the printhead is not moving freely. Most often paper scraps either on the extreme right side where the printhead parks, or on the extreme left side where it's hard to see.
Posted on Feb 20, 2010
pineworks
  • 4041 Answers
SOURCE: unable to print
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Also clean The purge unit, called a spittoon assembly in an HP, Lexmark, Caonon and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
That is where you'll find the print head assembly parked on top of it.
It also has an electrical pump to milk the print heads and test for ink flow.
So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Apr 27, 2010
My print job stopped in the middle with the following message displayed on my Mac screen: "Unable to write print data; broken pipe". What's going on and how do I fix it? My system is wireless.
there is a inc suck up pipe the inc gets sucked up the pipe when the pipe is blocked it cannot remove spent ink or toner it will need cleaning out.
May 29, 2014 | HP Officejet Pro 8600
Display shows " Print
Here's a link to the user manual.
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_MFC_255CW_295CN_EN_1787.PDF
According to the message, there is debris in the printer such as a paperclip or torn paper. Clear this debris from the printer and it should clear the message. Refer to page 107 of the document.
Sincerely,
Mark
Apr 02, 2011 | Brother MFC295CNAll-In-One InkJet Printer
Displaying message "print unable 30"
Can you please provide the model number of the printer your having issues with along with a little more description on what you where doing when the issue occurred.
Thanks
Dustin
Jan 03, 2011 | Computers & Internet
Multi-Function Center MFC-240C All-In-One InkJet Printer: i get the message "print unable 36" displayed on m...
Error code 36 is generally because of a paper jam that was not cleared. Remove the rear jam cover (the plastic cover in the back center of the machine)and the paper tray and check for any pieces of paper. Sometimes just a scrap will remain, but it's enough to cause the machine to not work.
Once you've replaced the covers, if the jam code does not reset, turn the machine off and then back on.
May 16, 2010 | Brother Multi-Function Center MFC-240C...
Unable to clean 50 error
I have a Brother MFC-440CN fax machine and I am receiving error message "unable to clean 50". Can anyone help me to fix this error problem
Jan 13, 2010 | Brother Office Equipment & Supplies
Printer message "unable to print 36"
That error usually means a paper scrap or something is stopping the carriage from moving across the paper correctly, or there are scraps caught on either side of the carriage assembly.
Aug 28, 2009 | Brother MFC-465CN InkJet Printer
Error message on my printer that says unable to print 36
Jun 05, 2009 | Office Equipment & Supplies
Unable to print 36
Jan 26, 2009 | Brother MultiFunction Center MFC-440CN...
Brother MFC-845CW multi-function All-In-One InkJet Printer Logo
415 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
