Question about KitchenAid KSRP25FN Side by Side Refrigerator
Side by Side KitchenAid won't cool
I bought a used 2004 KitchenAid - I plug it in, and everything seems to work - light comes on, compressor hums, air cirulates, but it doesn't cool down (even when left all day). The fridge has been sitting turned off for the past year.
I checked the obvious - temperature control and cleaned the condenser coils.
5 Suggested Answers
hotuna
  • 288 Answers
SOURCE: KitchenAid fridg compressor heating up
If the compressor is very hot, it sounds like it may be locked up. Is there an external fan next to it that is not running. this will cause the comp. to overheat, like a dirty coil, which it sounds like you checked out. There is a thermal overload on the compressor. Its underneath the little plastic cover that the wires go to. It protects the compressor from a meltdown. It also has a relay in there. If you have an amp meter you can check this by waiting for it to cool off and clamp it on one of the compressor wires.when it clicks on, If the amps soar over 20 very quickly, and then stops. Its a locked compressor and the thermal overload is cutting it out. If you don't have a volt/amp meter, then try replacing the relay as its pretty cheap. But I would bet on the comp. as long as the fan is running.
Posted on Jan 16, 2008
  • 4 Answers
SOURCE: KitchenAid side by side KSRE25F not working
I have the same problem. However, the compressor on most of these refrigerators is warranteed for 12 years. Check your owner's manual. If so, you may be able to get a free compressor and just pay for the labor, which is around $200. I just had mine replaced but we're still having a cooling problem. If yours is the compressor, it should be covered. You need to go to a factory authorized repair center, though.
Posted on Dec 23, 2008
aborcass
  • 2651 Answers
SOURCE: Compressor not running
you can try to repalce the "overload relay", with the model numberlook up the correct part. i would also check with oyour manual perhaps you have an extended warr. on your compressor assembly( comes with a new overload relay)..
Posted on Mar 01, 2009
heatman101
  • 43501 Answers
SOURCE: We a have a 6 year old Kitchenaid fridge model
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Posted on Aug 02, 2011
KitchenAid KSFS25FKBL02. No cooling at all. Compressor not running. Fan, lights working. Went to check the start relay but am confused. Removed the black cover on the side of the compressor and see a...
Whirlpool refrigerators as well as the other brands that fall under the corporation most like at some point within the first five years will stop cooling and freezing, and the sound you here will be either a humming follow by a click or in some cases just the click alone. This is caused by the start device on the compressor. The relay part of it has basically burnt, fell apart inside, however you want to describe and is not passing the power to the compressor to come on. To access this pull the refridgerator out from the wall, and first and foremost unplug it. Once that is done remove the lower panel, sometimes cardboard sometimes metal which is held up by a few quarter inch screws. Place to the side and located the compressor. The box on the side is start device, it will have 2 or 3 wires going to it, most of the time red and white respectively. Also they maybe a black box thats connected to the start device and sits horizontallty. Thats the capacitor. Keep that if your going to do the repair yourself. I recommend doing it because its very easy and will save you alot of money. You can buy this part at www.repairclinic.com or at www.apdepot.com just be sure to have your make and model number handy.
May 19, 2012 | KitchenAid KSFS25FK Side by Side...
Have a KitchenAid Superba side by side with ice maker. (Don't know year or model number, came with the house we bought two years ago.) We took off the back panel to vaccuum coils and wipe out drip pan...
It sounds like the compressor is not running.
The compressor is the black metal dome shapped component in the back, it is about the size of a bowling ball.
- With the refrigerator unplugged take the back panel off. Find the wires that go into the compressor and follow them back, it is most likely that one came loose while cleaning. If you need help in locating where they should plug in I can help with that.
- If all the wires are connected then put the panel on and listen closely to the compressor area while plugging the refrigerator back in. You should here it start, a hum that gets a bit louder. If you do not hear this listen closely for a couple of minutes for a single 'click'. If you hear the click then you either have a wire off or the start device is in need of being replaced. This is a fairly easy repair.
If the compressor runs and there is no click and no cooling then the sealed system has been most likely damaged and the repair is a major one. This is highly unlikely with a general cleaning.
Apr 18, 2010 | KitchenAid Superba Architect KSCS25INSS...
It sounds fine but isn't cooling on either side.
If your model is the KSRD22FKST then we need to check to see if the defrost control board is burned out. It will be inside the fresh food section and behind the control panel. We also need to check the thermostat and the compressor start relay and start capacitor. I'm here if you need my assistance. Please confirm your model number. Thanks, Sea Breeze
Jul 18, 2009 | KitchenAid (KSRD22FKST) Side by Side...
Hello, We just bought a used ktrs20kawhoo KitchenAid top-freezer,that doesn't seem to be getting cold in fridge section. Freezer is fine. Does it automatically cool top first? The air vent is very small in...
Need to make sure both fans are working and the compressors is running all the time the fans are. If not we need to check the compressor for overheating and look behind back panel in freezer for frost build up. Let me know if you want my help, Sea Breeze
Jul 11, 2009 | KitchenAid KSBS25FK Side by Side...
KitchenAid Side by Side
if you hear a clicking like the compressor is trying to start, like a clicking on and off this sounds like it could be your start run relay trying to kick your compressor on. if this is bad it will continue to click, and your compressor won't start. unless your mechanically inclined this might be the time to call a service tech. the start run relay switch sits on the compressor behind the fridge.
Mar 12, 2009 | KitchenAid (KSRD22FKST) Side by Side...
KitchenAid Superba that doesn't refrigerate
cathe if compressor is not running nothinh will get cold specially if frezeer is not working then the other side wont etheir if compressor is not running then it might just be the overload if nothing is running just the lights the is etheir the timer or thermostat
Oct 14, 2008 | KitchenAid Superba Architect KSCS25INSS...
No Cooling
hi there,
sounds like you may have a compressor problem. most compressors have a longer warranty on them, so i would recommend that you contact an authorized service center and have them come and take a look at it.
thanks
Sep 30, 2008 | KitchenAid KSRG25FK Side by Side...
id get rid of it personally its at least 9 years old and it sounds like the compressor may be out on it its your call
Jun 27, 2008 | KitchenAid KSRG22FK Side by Side...
KitchenAid KSRP25FN Side by Side Refrigerator Logo
105 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
