Question about RCA RTD317W Theater System
I have the RTD317w model Sometimes when we try to play a DVD we get an error msg-i take the DVD out and clean it-sometimes after several tries it will play-also sometimes after this the DVD will stop in the middle of the movie and will not move any further-even if you choose scenes after where it stopped What could be wrong? Also the same DVDs will play fine on another DVD player
  • RCA Master
  • 6,993 Answers
how long have you been using this player? I suspect the laser (lens) of the player. I think the laser (lens) is weak that's why it cannot read data/files on DVD discs.
To confirm if actually its a laser problem, insert an Audio CD into the player and see if will play. If it plays, then obviously, your laser (lens) is weak. But if it doesn't play Audio CD, then it might still be the laser (lens) or a mechanism problem.
Get a lens cleaner, use it to clean the lens. If that doesn't solve the problem, get a screw driver, open the player's cover so that you can gain access to the lens, use a cotton board to clean the surface of the lens. This should clean dust or dirt that might be on the lens.
If non of the above solves the problem, then know that you need to replace the laser to a brand new one.
To replace the lens, remove the bad laser, use it as a sample to get exactly the same type and do the replacement. Note that replacing a laser (lens) needs a professional touch, so if you cannot replace the laser, get it to a repairman to fix it for you.
Once this us done, your player will play all DVD discs again.
Good luck.
Posted on Mar 22, 2011
Allegro DVD/VCR combo - not reading disk & eating tapes.
Sorry I know very little about the dvd side but my experience with several VCRs is they need cleaning sometimes just like audio tape recorders and players need cleaning. Early in my days of VCR ownership the engineer I used was sick of seeing me and taught me how to clean the heads, guides and rollers myself to restore performance and help prevent tapes being chewed. Head cleaning tapes simply did not reach the parts needing cleaning though the the wet type sometimes helped.
A VCR might work normally for several months and then suddenly it would happen again. Sometimes I needed to do a clean several times in a month. I did have a Sharp VCR once and that had something called an idler reel that would "suddenly" need replacing (several times) due to chewed tapes but other than that manual cleaning did the job every time.
Later VCRs were fitted with a self cleaner that worked well and meant there was no trouble for a long time but when the self cleaner became loaded with filth they actually made matters worse.
Matter of interest, I use clean newspaper and methylated spirit for cleaning.
Oct 23, 2017 | Allegro DVD/VCR ABV511
Trying to record on a DVD-R , after several minutes trying to load i get a msg saying it can neither read nor play this disc , check disc,,please help
I've had this problem with trying to record on CD-Rs also. DVD and CD recorders can be very fussy. You just have to get a piece of dust or a fingerprint on the CD or DVD that's being recorded onto and it gets kicked back as a check disc or blank disc..
Another problem is some recorders will only accept certain brands. I've had problems recording onto a SONY CD-R with a SONY recorder! So, in summing up, try a different brand or make sure the disc is clean. Sometimes just taking the disc out and putting it back in in a different position will make the recorder think it's an OK disc. Hope this helps.
Jul 22, 2012 | Samsung DVDR120 DVD Recorder
Panasonic SC-DP1. Sometimes plays a dvd, sometimes doesn't (same dvd!). same dvd plays on my other dvd player (toshiba). Any answers please? Rob - uk
hi!!can i help you?
did you already tried to open your dvd?do have somes skills in electronic let me teach you some basic,open your dvd player y\using philips screw,,then try to look for the lens,,get some pc. of cotton and clean the lens carefully,reminder pls dont touch directly the lens,,after cleaning your dvd player close it and try it,,,before playing the disk clean it first,hope this steps will turn your dvd player in a good condition,,,
Feb 04, 2011 | Panasonic DVD-RV31 DVD Player
The player all of a sudden stopped playing DVD's and I get a "can not play this disk" message on the screen
Try cleaning the laser pickup lens very carefully with rubbing alcohol "just a dab" and a Q-Tip, let dry for several minutes. If this fails try removing the dvd assembly and re-insert it back, sometimes the plug in don't contact correctly. The final solution will be to replace the whole dvd driver assembly.
Dec 27, 2010 | Sony DVP-FX820 DVD Player
My Samsung HT-Z210 Home Theatre System is crazy. Sometimes it plays the disks but most of the times it would sound as if it is trying to load a few times and then displays disk error and if it does play...
Check for fingerprints or dirt on your DVD. Wipe it clean and try again. Also check for scratches. Try another DVD and see if your system reads it. If it does not try cleaning the drive laser lens with a CD lens cleaner available at places such as KMart or WalMart in the electronic section. If that still does not work chances are you laser on your drive is bad and needs replaced. It will need servicing.
Dec 03, 2010 | Samsung HT-Z210 Theater System
Put in clean commercial disc and get error msg "no disc" period!
Dr. OM,
Lets give it a try. The purchasedate will be 1991 (HI).
I'll suppose you allready cleaned the laserunit.
You can try to clean the laserslides, sometimes they are sticky and dry. Then the laser is not fast and precise enough to read the index of your CD.
Clean them with some alcohol on cottontips.
When they are really clean, use just a little teflonoil to make sure the laserunit slides very smoothly.
Regards,
73's Gerard
May 13, 2010 | Sony CDP-C505 5-Disc CD Changer
We get a message that says can't read disk with every game we try to play. sometimes they will start to play and then the message comes up.
I fix this all the time..... You need a new laser if cleaning does not help.You get bad data transfer then an error msg with faulty laser.
Dec 02, 2009 | Microsoft Xbox 360 Console
Xbox
Some times a DVD cleaning disk will work. If that don't work try a can of the keyboard cleaner to blow out the dust and debris. Thank You for using FixYa.Com........... : )
Jun 18, 2009 | Microsoft Xbox Console
Problems playing DVDs, Random Disk Error
To answer this I need to know the make, model and year of your DVD player, and if you bought it in northamerica, or europe.
Jun 24, 2008 | Sylvania DVR90VE DVD Recorder/VCR
DVDM 1805
it sounds like you might need to clean the laser eye, try that and get back with me
Dec 10, 2007 | Denon DVM-1805 DVD Player
RCA RTD317W Theater System Logo
228 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
