Question about Kenmore Blenders
I have a kenmore Blender Food Processor 100.80573. Looks like the fuse blew up. I am having hard time removing the casing. Is there a catch to it.
3 Suggested Answers
SOURCE: parts for cuisinart blender trio model bc-56
GO TO:
http://www.smallappliance.com/department.asp?cur=USD&sid=18954&mid=8&shopBy=Brand&cam=cuisinart_parts&gclid=CJTy7Om5qZoCFRk_awod9Gjw1Q
FOR CREDITS MAIL BACK TO: NEFIUINC@MSN.COM
Posted on May 07, 2009
SOURCE: wolfgang puck bistro blender won't turn on, need
I had the same problem. There's a little button on top of the base that is supposed to get pushed in by a male-type piece on the bottom of the pitcher. I broke a match stick and duck taped it so that it pushed in the button on the base - Voila! it works!
Posted on Jul 08, 2010
Food processor no longer working
Power in the USA is 115 VAC not 240 VAC. The motor probably blew out the thermal fuse . This fuse looks like a small silver colored cylinder connected to the power cord inside the base of the processor.
Nov 19, 2014 | Braun 220 Volt K700 Food Processor Center...
Blender overheated
If it won't run once it has cooled down, you have probably cooked the electric motor, which is not worth trying to fix.
If you have some time to poke around, it is vaguely possible that a switch has burnt out, which can be fixed/cleaned. Another longshot is a burnt out fuse, but I doubt it has one.
Jul 22, 2012 | Oster Fusion 7-Speed Food...
Fuse blew on my Oster BCVBO7 blender. Can it be
replace the fuse with the same specs. if it blows again, there is a short on the circuit.
Aug 22, 2009 | Blenders
Need to order parts for food processor for stainless steel blende
I neede a new blade unit for my phillips smoothie maker, I just googeld the model number + spare part and was redirected to the websites! Eventually you fine it!!
Feb 20, 2009 | Ultrex 834-334 Die Cast Work Top Blender
Cusinert blender
I had the same problem and I manaed to fix my Cuisinart SmartPower Duet blender. There are two thermal fuses, one tape attached to each stator winding. Both of mine were blown.
In addition, when the fuses blew, it must have spiked the triac. I had to replace mine. It's the black 3-legged transistor looking device with a small metal heatsink attached to it. This gizmo directly throttles the power to the motor under control of the microprocessor. There are some guides on the internet on how to test it.
Also, the clutch was very hard to remove and needs to be removed to more easily replace the thermal fuses. I clamped down the end of the motor shaft to a bench vise real hard and then I used a 7/8-inch open-end wrench to wedge into the clutch prongs which made it much easier to apply torque. Remember that its screw threads are reversed from normal screws so that it does not unscrew during operation. You have to turn it counter-clockwise to unthread it.
Hope that helps!
-Vince
Sep 13, 2008 | Cuisinart SPB-7 SmartPower Work Top...
Received the Breville Ikon 600 blender as a Christmas present in 2006 and have used it 3 times, with the third time being this past weekend. The product is now out of warranty and low and behold, it...
My IKON 600 Blender fuse had blown. It was located on the circuit board and can be found by removing the bottom of the blender. Fuse is Fast Blow 10A, metric 5mmx20mm. The fuse blew because the bearing in the bse of the jar froze. Bearing # 608-RS. The beraring froze because the seal in the base of the jar was leaking. Solution: Clean seak surfaces, replace bearing and fuse. Total cost of $6 with my labor.
Apr 16, 2008 | Breville CBL10 BlendMaster Classic Work...
Need new product
I have a brand new, never used (parts still in plastic, but no box) ULTREX Kitchen Preparation Center model 14008- Blender-Food Processor-Fruit Juicer that you could buy.
Nov 06, 2007 | Blenders
Blenders Logo
138 people viewed this question
Top Kenmore Blenders Experts
eyecam
Are you a Kenmore Blender Expert? Answer questions, earn points and help others
