We have a 60 in or bigger plasma tv the model no is pd6120d when we plug it in and try to turn it on nothing happens
  • 6,993 Answers
The issue you describe is consistent with a power supply board issue. This is the board where the AC goes to. This problem may have occurred as a result of irregular power supply, or excess power supply or power surge.
The TV is receiving current but cannot circulate or transfer the current to other necessary part of the TV because of the defective power supply board.
I do not think it needs replacement, rather some defective capacitors are causing this issue.
Open unit up and take a look at the power supply board.You will probably see one or more electrolytic filter capacitors that are bulged up in the top-not perfectly flat like the others.
The value of these capacitors will be different, most likely they will be somewhere around-820 to 2200uF/25 V( or /10V sometimes)
You can replace them with same values but I would recommend the voltage rating to be higher(like 35V for an original 25V) for reliability purposes.
What happens is,these bulged top capacitors will cause a low and unfiltered DC voltage=main board will malfunction(the relay will keep clicking until the caps are holding enough charge to bring the voltage up over a threshold point).
You can buy these capacitors at any Fry's or Radioshack store or you can order them online at vendors like "mcmelectronics.com"(look for electrolytic capacitors).
After replacing these capacitor(capacitors) most likely the normal operation will be restored.
Note: There may be also some other causes for this symptom ,like a defective T con board ,or main board,but the bulged top capacitors are the most common cause for this issue.
If you don't know about TV repairers, take the TV to the nearest repairman to fix the fault for you. Also, note that TV stores a lot of current, so wait a while before opening the TV back cover.
I hope this helps.
Good luck....
Posted on Mar 21, 2011
I have a samsung 50 plasma tv that will not turn on now. If I unplug it and plug it back in it makes a clicking sound 4 or 5 times then nothing happens.
Probably bad capacitors. Samsung TVs are famous for this. Relative easy fix for a technician that knows how to do board level repairing
Apr 29, 2017 | Samsung Televison & Video
My nec plasma sync tv wont turn on
Is it plugged in?
Lol gotta ask that.
If so, you might have a problem with a dead power supply or perhaps even the outlet where it's plugged in is having an issue...blew a fuse, tripped a breaker.
First try plugging it in somewhere else (another room).
If that doesn't work, and there is power in your house, you might need to take it to be serviced or toss it and buy a new one.
Nothing lasts forever. You just need to determine if the price of service + parts is worth it.
Aug 17, 2014 | NEC PlasmaSync 60XC10 - 60" plasma panel...
Our akai pdp6065ta 60" plasma hd tv will not turn
Try the power button on the tv. Your remote may have dead batteries. If no luck still, it sounds like your power supply unit has gone south. Check for warranty before attempting to repair.
Feb 18, 2011 | Akai PDP6065TA 60 in. Plasma TV
Plasma problems
It's in standby mode.
Let's do a reset and see what happens
While holding down the reset button on the remote
Press the power button on the tv
(The tv will turn itself off the back on)
Now release the reset button
Let me know how this works
Jan 30, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
Plasma problems
Well, it may be your power cord, check the cord for bare wiring which is the metal hanging out of the insulation rubber. If it is then go buy another cord.
Jan 29, 2009 | Panasonic TH-42PWD6UY 42 in. HD-Ready...
Sony Plasma TV.
I have the same problem. since I have 3 of these TV's, I switched boards around, and I came to the conclution that is the power board. I will try to repair it, and I'll let you know the component that is bad. Gaston
Dec 28, 2008 | Sony FWD-50PX2 50 in. Plasma Television
Televison & Video Logo
Top Televison & Video Experts
