Question about LG Washing Machines
Cleaning rags with mineral spirits were accidentally put in with the wash. How harmful is that to the machine and how can I get the smell out. I've already tried a bleach rinse as I normally do to clean the machine tub and have also tried baking soda and lastly white vinegar. Will anything help?
    Sergeant:
  • 192 Answers
It will not affect your machine but may stick around for a few cycles. Just use fabric softener and you should not notice a difference.
Posted on Mar 21, 2011
I put my hands in stagnant water in garden up the smell was terrible after washing my hand several times i can still smell on my skin can this be harmful or absorbed through the skin
Most stagnet water will have a bad smell especially if it just sitting for a long time. Yes if you put your hands in it they will smell bad and most likely there will be no harm done. Get yourself nice smelly soap and wash with that and they will smell better. If i get gasoline on my hands I get myself some shaving lotion and pour a little on my hands and wash good afterwards.
Mar 21, 2017 | Washing Machines
Best cleaning chemical for auto carpet and upholstery? I'm cleaning cloth upholstery in a 2011 impala and its coffee and coke stains that keep bleeding through.
Mineral spirits. You can go to any hardware store and get some. It may be called paint thinner. However, get "mineral spirits". After using mineral spirits, soap and water. Soak up as much as possible with rags. Then, if not too much mineral spirits are still present, use a shop vacuum and an gallon of soapy water. Suck it out really well. Then let it dry well. You will be shocked at how clean it comes out.
Mar 18, 2017 | 2011 Chevrolet Impala
How can I remove tar from inside a washing machine's drum
Use mayonnaise, a sponge or a rag and some elbow grease.... My husband is a roofer and we always end up with some tar in the washer and dryer. So I just scrub it out with mayo. And do a soapy rinse afterwards in the washer, and if its in the dryer I throw a wet rag on a quick cycle to make sure there in no lingering mayo in the drum.
Oct 16, 2012 | LG Washing Machines
There is a musty smell in the maytag washer even b4 I fill it with water, I've disconneted the hoses & flushed with bleach that did not take care of it,Iv'e run washes without clothes in it...
When a moldy or musty smell develops in a washing machine, many times the smell is coming from the open areas of the agitator. Water along with soap and/or liquid softener sometimes splashes into an open agitator, and when the lid is closed it does not dry out. Instead, mold begins to form, and a musty smell wafts from inside the machine, even after the lid has been opened for an extended period of time. Until the mold is removed the washing machine will continue to smell bad, even if it is used and allowed to air dry with the lid open.The tub can also be the source of the smell. Lint can gather and collect in the holes, and when it does not dry fast enough it ends up smelling musty and moldy. Even the top of the rim can become moldy and musty, but proper cleaning can get rid of the odor.
So that said.To clean the machine,fill to just above the top row of holes in the tub.Add 2 cups of bleach.Let sit for 1-2 hours.Then let the machine run it`s wash cycle.Lastly use bleach water and a rag to wipe the machine down inside and out.If the agitator has a cup on top remove and clean with bleach.Leave the top open so the machine can dry.
Now it should smell better,if so use as normal,and leave the lid open when not in use.
May 15, 2011 | Maytag Washing Machines
My washing machine smells where is the filter does it have a filter all other machines do
Run a tub filled with a couple of quarts of white vinegar thru the cycles. It generally reduces smell of mildew and bacterial odor. Clorox works too. Run rags or other "throw-away" laundry during these cleaning methods.
Oct 08, 2010 | Maytag Neptune MAH5500B Front Load Washer
I own a Singer kitting machine (circa 1990) in need of repair. Can you help?
yes what do you need to know?? you will need to give it a good clean first i use surgical spirits, a good paint brush for flicking out dirt, a strong vacume cleaner, a coffe jar to put spirits in with the needles shake them about and they clean them selves.. dont forget to put a good sized piece of material down on the floor to protect your flooring as plenty dirty oily stuff will come out...lots of non fluffy cleaning rags, cotton is best... askmore details and i will help more thanks heidi
Dec 19, 2009 | Singer Deluxe Knitting Machine
Terrible smell coming from our washing machine
remove bottom cover at back of machine, loosen large jubilee clip on hose between drum and pump. pull hose down and off, take out strainer basket and pull top off, clean top, ball and basket by running under tap. clean out hose with an old rag. reassemble strainer and put back into hose, in the correct position. fix hose back on to drum and tighten clip. run machine on a hot wash and all should be fine.
Nov 04, 2009 | Hotpoint Ultima WF860 Front Load Washer
Our front-loading HE washing machine delivers
try putting in 2 caps of a citrus or pine bleech straight in to the drum with some old rags. then select a boil wash. the rags will spray the water around the tub, the bleech will clean the tub and make it smell fresh. DON'T put any clothing in whilst doing this. if you are worried about bleech in the machine just select a rinse cycle after. i do this once every 3 months
Aug 05, 2009 | Maytag MAH2400A Front Load Washer
How do you remove vct adhesive from concrete in prep. for epoxy?
We use floor sanders ...or rent the units at Home depot ... Clarke floor maintainer, with appropriate discs ... 60 - 80 grit 17" disc... you may need more than 1 depending on size of job. They have finer grits available also ...30-35 bucks a day ... and they have 1/2 day rentals too.
Mar 22, 2009 | Q.E.P. Co., Inc. Traditional VCT Adhesive...
Washing Machines Logo
124 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
