Question about Kenmore Kitchen Ranges
How do I get to see the error codes on my kenmore ultra bake oven gas? Model # 665 750 2210. I figured this out once, but now I can't figure it out again.
  • 52 Answers
SOURCE: frigidaire oven will not heat up
here is a list of error codes that may or may not be displayed by the oven.
Frigidaire Range / Stove / Oven Fault Codes Failure Code Fault Code Description Solution F0 Electronic oven control failure Replace electronic oven control (also called EOC or clock). F1 Electronic oven control failure Replace electronic oven control (also called EOC or clock). F2 Oven temperature too hot Check and replace oven temperature sensor (RTD). F3 Open oven temperature sensor (RTD) Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok. F4 Shorted oven temperature sensor (RTD) Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok. F5 Electronic oven control failure Replace electronic oven control (also called EOC or clock). F6 Electronic oven control failure Replace electronic oven control (also called EOC or clock). F8 Oven door lock failure Check lock relay and door switches.
Posted on Jan 29, 2008
captaynkyrk
  • 170 Answers
SOURCE: Kenmore Ultra Bake GAs oven
Here's a link: http://www3.sears.com/ put in your make and model and you can order a manual. Good luck!
Posted on Jul 21, 2008
Krazytech
  • 725 Answers
SOURCE: Kenmore Ultra Bake. Gas won't come on
Loc is a child lock
1)press lock/unlock button for 5-10 seconds
2) set the clock
hope it helps
Posted on Aug 31, 2008
  • 172 Answers
SOURCE: f5 code on a kenmore range
Hi mrscottd,
The f5 indicates a loss of the relay drive circuit. To correct you can turn the power off to the range at the breaker box and wait about 10 minutes, then turn back on. This will reset the board. If the error returns you will need to replace the electronic range control (ERC). The part number for the control is # 338692 price $338.49 at Sears or My price $299.99 delivered. Good luck to you and please dont forget to rate me.
Mike Anderson
Anderson Appliance
(865)945-3808
Posted on Oct 30, 2008
  • 38 Answers
SOURCE: EO F2 code
hi, this appears to be a fault caused by a short in your keypad - electronic range control (ERC)
this needs to be replaced unfortunatly.
To assist you finding the proper part your model numbel means that the oven is manufactured by Whirlpool for Sears/kenmore.
Posted on Nov 02, 2008
My Kenmore ultra bake stove model 665 75022101 now has a " Loc" code on the screen. The gas range doesn't work. How do I clear this?
Notice the 2 buttons at the top right, "top" and "oven". If the top burners won't initiate, press and hold for at least 5 seconds the "top" button to unlock it. If the oven won't work, press and hold the "oven" button for at least 5 seconds to unlock it. I hope this helps you!
Sep 15, 2015 | Kenmore Kitchen Ranges
I need to know how to get a manual for a kenmore ultra bake self cleaning super capacity oven can you help me
Many Kenmore manuals are available from the Manage My Life site: http://www.managemylife.com/mmh/owner_manuals?intcmpMMHxG_HomexServices_Menu .
You will need the model number - there are over 9,000 ovens that come up when you search Kenmore Ultra bake self-cleaning super capacity oven. Most of the Kenmore ovens have the model and serial numbers on the front frame. (Left front of the frame on the lower oven on a dual oven model - just open the door and the panel should be visible.)
I hope this helps.
Jan 04, 2011 | Ovens
665.95802000 f1 - E 1 error code
take the consol off you will find the tech sheet with all the codes. make sure you turn your power off first.
Dec 23, 2009 | Kenmore Ovens
Kenmore Ultra bake self cleaning oven is showing code E0 - F2
My oven will not stay on, when started to preheat it will come on for a few seconds and they it will make a beeping noise and the codes E0 F2 will appear. The codes stay on even if the oven is off.
Jan 04, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Whirlpool Gas Range E2 F3
I HAVE A WHIRLPOOL GAS RANGE MODEL NUMBER SF379LEMS.OVEN WILL LIGHT UP BUT AFTER TEN MINUTES IT WILL KICK OFF ANF ON ON ,THEN AFTER AWHILE I WILL JUST SHUT OFF.ANY SUGGSTIONS. ADAM
Nov 23, 2008 | Whirlpool GS470LEM Gas Kitchen Range
Kenmore ultra bake oven is locked
The manual is located at the back of your oven. If your oven is against a wall, pull it back, not too far, and you will see a manual taped to the back of it. From there, it will provide you with answers some employers won't know. If it's not there, sorry, you're outta luck!
Oct 27, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
EO F2 code
Oct 24, 2008 | Kitchen Ranges
Loc is a child lock
2) set the clock
hope it helps
Aug 30, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kitchen Ranges Logo
Top Kenmore Kitchen Ranges Experts
Sal De
Justin Duby
Justin Duby
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
