Question about Whirlpool Duet GHW9150P Front Load Washer
The problem i'm having with my washer is that it's leaking water underneath the detergent dispencer. I had the same problem a while ago and a tech fixed it he found a sock in some were in the dispencer but I can't remember exactly what he did. He did explain it to my husband but we can't seem to remember.
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 239 Answers
Remove the door bellow, small spring around the outside of the rubber boot. Peel the upper LH corner of the boot back and you will have access to the dispenser outlet.
Kelly
Posted on Mar 21, 2011
My wirpool duet sport is leaking alot of water out of the detergent compartment whats wrong? Please help
You could have a clog in the housing underneath the dispenser where the water flows through a hose into the tub.
Pull the dispenser drawer completely out.
There is a tab that needs to be depressed to release the drawer and remove it.
Check the opening at the bottom of the housing just inside the dispenser housing opening to see if a small sock or garment is clogging this opening.
Reach down into this opening to see if an item is inside the hose.
This is the normal issue that will cause water to leak out of the dispenser housing.
Wash the dispenser drawer thoroughly with warm water. Make sure that you pull off the siphon covers and wash all siphon holes. This process is described in your owner's manual. Replace the dispenser drawer and try the washer again.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
The washer seems to leak a small amount of water, less than a cup after each wash. It looks like it is coming from the back underneath. Checked the filter and such.
You may have an oversudsing condition which will cause it to leak like this. It can cause permanent damage over time.
Try to use one eyedropper full of HE detergent, either the liquid stuff or powdered dissolved in hot water. Use vinegar for fabric softener it will rinse the load clean. Run it on a hot cycle first with a cup of vinegar to flush the detergent residue from the drum, no laundry, and see if the water runs clear and/or if it leaks, if the problem occurs you may be facing a gasket breach. More often than not it's due to oversudsing. They tell you NOT to use regular detergent and that is why.
Apr 21, 2010 | LG WM1814CW Front Load Washer
Softner in detergent drawer dispence at the wrong time
Take off the top of the front loader, topfrontleft is the dispenser, there is a movable part that was incrusted and unablble to freely move, clean off parts, little water will do, the movavable piece should move back to the roman numeral one, it is spring loaded, put top back on, done.
Dec 30, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer kenmore leaking water out bottom
Its very possible it could be one of the tubes that run to the fabric softener or detergent.
Dec 30, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Works on hot not cold cycle
Hi. this is a failed timer device. simply replacing the timer control module will eliminate these issues you are having.
Jun 10, 2009 | Bosch Nexxt 100 Series WFMC1001UC Front...
Water leaks from bottom
check for cracks and corrosion on the outer tub.thats where the water must be leaking from.good luck.
Dec 25, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Leaking machine
possible split hose.
Check the hoses connecting to the Drum and water Pump.
Mike @ Compurepair.
Feb 24, 2008 | GE WSXH208A Front Load Washer
Kenmore front load washer
check teh rubber seal on teh front door. They sometimes leak down the front of the door.
Jan 14, 2008 | Kenmore 44832 Front Load Washer
Water in detergent dispenser
Remove dispencer again, remove conditioner syphon assembly and clean up the little tube. Should then go okay
Jul 06, 2007 | LG WM2277H Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
37 people viewed this question
Dan Webster
Dan Webster
Sal De
