Question about Garden
Need to know how to re tension pull cord spring on my baumr sx 38 chainsaw?
  • 604 Answers
You need to purchace a new spring box, usually they come with a new cord attached. remove the old spring box and replace with the new one. It is not advised to try and tighten the spring on the old box.
Posted on Mar 22, 2011
Spring fell out of my baumrag 750 sxi and no longer self propelled just need to now where spring goes
Contact them direct and ask them for a schematic. It is a too obscure Australian company with nothing helpful online.
Baumr-AG is a brand name Mills created in 2008 to sell tools online. It works. Mills's company, which started in 2006, pulled in $26 million last year. "With chainsaws, people think Germany.
http://www.baumr-ag.com.au/about-us
Jul 23, 2018 | Garden
Oil Pump & Worm gear drive for Baumr-ag SX 72 72cc Chainsaw
Cant find much on your machine as its an obscure make and model. This brings with it the ease of sourcing parts, sometimes its better to stick with known brands for this reason.
I managed to find this, it might be worth comparing it to the one on your machine. Hope it helps.
http://www.chainsawspares.com.au/oil-pump-and-worm-drive-for-baumr-ag-sx25-25cc-cha
Mar 30, 2016 | Garden
Hi i have this chainsaw as mention below.i need a replacement part.its the black cover that fits on both sides of the motor that covers the the rubber stopper that stop the motor moving.there are 2 .
Sounds like you will have to pull the cover part of pull cord there is a spring under cover it could be broken or needs cleaning and lube also spring tension could be slack and not returning cord properly or very dirty under there be careful as spring could also be broken
Feb 10, 2015 | Garden
I need a service centre for my Baumr SX 72 chainsaw in the Geelong?
Try reading
http://www.productreview.com.au/r/baumr-ag-62cc-professional/549822.html
Where I have a bit of a problem is that this question about a chainsaw is headed 'Problem with Video Cameras'. Maybe Fixya's fault.
May 29, 2014 | Video Cameras
The pull rope will not rewind. How do I reset it?
The cord should be removed from the spool entirely, then wind the spool spring CCW for a number of turns making sure the spool can be turned for about 6 turns more (during start). Wedge the spool so that it can't unwind the spring again. If the old cord was about worn out, replace it with fresh. Melt the cord end somewhat so that the knot won't pull out, then tie an overhand knot in the cord end. Feed it into the inner retainer on the spool, then thread the cord around the spool 5 or 6 times in a CCW direction. Once wound, feed the loose end out of the cord port, slide the pull handle on, melt the cord end, and tie an overhand knot on it. Stuff the knot into the handle and release the wedge from the spool so that spring tension pulls the cord tight. Pull the cord out several times to make sure nothing interferes with cord and mechanism, then install on the saw and check the start operation. The spring should never bind-up when the cord is fully extended. Hope this helps!
Jul 25, 2010 | McCulloch Garden
Need to replace the pull cord assembly, because something that tension the spring is missing. Tried substitute cord but found after reassembly there was no tention on the cord something is missing.
When the cord breaks, the internal spring will completely unwind. You have to re-tension the spring, then attach the cord and wind it onto the spool while holding the spool against tension. Finally, feed the end of the cord out through the cord port and tie the handle while still holding tension. A small pair of Vise Grip pliers will hold the cord while dealing with the handle. It's about like setting a trap without getting your fingers caught. Hope this helps!
Jun 07, 2010 | Craftsman sears 18" Chain Saw Chain (...
Starter coard broken
The starter housing is removed with a #20 Torx bit, then the cord replacement becomes obvious. You'll need to prewind the spring about half it's capacity before engaging the cord reel to the rewind spring. Good luck with it. These cords won't break if you use short pulls, preferably with your foot holding the right hand hold to the floor.
Jun 03, 2010 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
How do i get the pull cord spring back in on a
Recoil Spring Rewind
I invert and secure the housing and rewind the spring large coil to small (need eye protection, both hands and no women around work area!). I'm right handed so I tension the spring enough to insert it inside the previous coil while holding what has already been installed with my left about 180° from my right hand. The tension will hold the spring in the housing once completely inserted. Then bend slightly the inner most part to engage the starter spool. It will require about 2 turns of pretension for it to retract properly. HTH
Lou
Nov 22, 2009 | McCulloch Garden
Craftsman gas chainsaw 18'' model 358 pull start repair
If you're lucky you can pull the cord out enough for a pretension then slightly raise and add the withdrawn cord to the spool. HTH
Lou
Sep 20, 2009 | Garden
The pull cord has come off the spindle, how do I get it back on properly or install a new one and reset the spring tension
Remove the starter cover, rewind or wind a new cord onto the spool. Turn the spool about 2 turns against the spring, thread the pull cord through the starter cover and reinstall the pull handle.
Lou
Sep 05, 2009 | Homelite Consumer Products 9.0 Amp, 14 In....
Garden Logo
98 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
