Question about DISH Network IR Remote Control
I need a code for tp 3730dvb - DISH Network IR Remote Control
  • Official Brand Answer
  • 263 Answers
I would need to get a better idea of what model remote you have. I would recommend viewing our link here which provides both the instructions and codes to program your remote
http://www.dishnetwork.com/SupportSection/remote-setup
If the codes there don't work you can also try a power scan listed below to try and scan the code for the remote in. Which button you hold below depends what the equipment you're programming does. If VCR/DVD you'll use that button, if another device you'll use AUX.
1.) Press and hold the VCR/DVD or AUX button (about six seconds) on top of the remote until all mode button backlights come on, then release.
2.) Press 0 for a TV, 1 for a VCR/DVD, 2 for any other device then press STAR (*) and press and release the Power button.
3.) Press the Up button once a second while pointing the remote at the desired equipment. If the code for the equipment comes up, the equipment will power off.
4.) Press the POUND (#) button. If the code entered is valid for the remote, the mode light flashes three times. To verify the code works try several different functions for that equipment.
Posted on Apr 09, 2011
Hi audi a3 2.0t bwa two faults p2127 and p2122 what can cause this problem
code p 2122 has three reasons
1--accelerator pedal position (APP) sensor---switch D--low input==causes wiring short to ground --APP sensor /switch
2---throttle position(TP) sensor /switch D--low input===causes ---wiring short to ground--TP sensor/switch
3---engine control module (ECM) idle control---high input===causes --wiring short to positive ---TP sensor---ETS control module
code p 2127 refers to APP sensor--switch E--low input===causes wiring short to ground --- APP sensor/switch
also refers to TP switch E--high input====causes wiring short to ground ---TP sensor switch
Jan 31, 2018 | Audi Cars & Trucks
Code P1121 for TP sensor - where is it located on engine of 2002 4.0 ford ranger
P1121 - Throttle Position (TP) Sensor Inconsistent with MAF Sensor The PCM monitors a vehicle operation rationality check by comparing sensed throttle position to mass air flow readings. If during key ON engine running self-test the comparison of the TP sensor and MAF sensor readings are not consistent with calibrated load values, the test fails and a diagnostic trouble code is stored in continuous memory.
  • Air leak between MAF sensor and throttle body
  • TP sensor not seated properly
  • Damaged TP sensor
  • Damaged MAF sensor
Drive vehicle and exercise throttle and TP sensor in all gears. A TP PID (TP V PID) less than 4.82 % (0.24 volt) with a LOAD PID greater than 55% or a TP V PID greater than 49.05% (2.44 volts) with a LOAD PID less than 30% indicates a hard fault.
Do you know what scan data on a scan tool is ?
How to Install Replace Throttle Position Sensor TPS 2001 Ford Ranger Buy...
Jun 21, 2017 | Ford Cars & Trucks
Dodge caravan 2003 code p1598 and p0123
code p 1598 is a/c pressure sensor--volts to high
code p0123 refers to throttle position(TP) sensor A/ accelerator pedal position (APP) sensor A---high input===causes wiring short to positive--TP/APP sensor---ECM
it also refers to TP sensor A APP switch A--low input====causes --wiring short to ground--Tp/APP switch---ECM
Jan 19, 2017 | Dodge Caravan Cars & Trucks
Engine code of P2138. how do I fix it
-The throttle position sensor is defect. Check and replace it.
Good Luck
Mai
Jan 07, 2016 | Denso 2006 - 2007 Subaru B9 Tribeca Engine...
How do I fix this code P0123 for a Mazda Protege 2002?
Probable Cause:-
Possible Causes Setting Conditions
  • TP sensor connector is damaged (check pins for damage, and for moisture)
  • TP sensor signal circuit is open or shorted to voltage
  • TP sensor ground circuit is open
  • TP sensor has failed
  • TP sensor not mounted properly to the throttle body
  • PCM has failed
Engine running; and the PCM detected the TP sensor indicated more than 4.60v (i.e., a throttle opening of 92.27%). Note: This trouble code may set due to an intermittent fault.
I’m happy to assist further over the phone at https://www.6ya.com/expert/uttamjeet_2f3adc18600f8ede
Mar 23, 2015 | 2002 Mazda Protege
What dose it mean when engin light falshes contstantly
Flashing Diag Code P0122
TP circuit low input
DETECTION CONDITION
• If PCM detects TP sensor voltage at PCM terminal 89 below 0.10 V after engine start, PCM determines
that TP circuit has a malfunction.
POSSIBLE CAUSE
• TP sensor malfunction
• Connector or terminal malfunction
• Open circuit between TP sensor terminal C and PCM terminal 89
• Short to ground circuit between TP sensor terminal C and PCM terminal 89
• Open circuit between TP sensor terminal A and PCM terminal 90
• Short to ground circuit between TP sensor terminal A and PCM terminal 90
• PCM malfunction
Flashing Diag Code P0123
TP circuit high input
DETECTION CONDITION
• If PCM detects TP sensor voltage at PCM terminal 89 is above 4.77 V after engine start, PCM determines
POSSIBLE CAUSE
• Open circuit between TP sensor terminal B and PCM terminal 91
• Short to reference voltage (Vref) supply circuit between TP sensor terminal C and PCM terminal 89
• PCM malfunction
Jun 26, 2014 | 2000 Mazda Protege
P0123 2004 jeep liberty
ok that is easy as 123, and google is your friend.
first tech answer.
Trouble Code: 123
TP Sensor/APPS Circuit High Input Number of Trips to Set Code: 1
Trouble Code Conditions:
Key on or engine running; system voltage over 10v. The PCM detected the TP Sensor indicated more than 4.47v (Neon, Sebring, Stratus, Viper, Liberty) or 4.94v (all other models) for 0.48 second. If equipped, ETC light will illuminate.
Possible Causes:
  • Related TP Sensor engine DTCs present
  • Intermittent wiring or connector problem
  • TP signal circuit is open or is shorted to battery voltage or to 5v supply circuit
  • PCM has failed
Bar room answer:
The TPS device, failed 1 time.
This device is Throttle angle sensor, senses your right foot actions.
bad TPS
or ground to it is cut. (broken wire at TPS) lool
what should i do,? willy nelson says?
you should reset all DTCs with the scan tool and pray it does not return. if returns, its busted fix it.
to learn more?,? log in to alldata.com
Dec 13, 2013 | Jeep Cars & Trucks
Codes P700,P1121 and P0122
Trouble Code: P0122
Are you sure on p1121 or was it po121 because there is no p1121?
Throttle Position Sensor 'A' Circuit Low Input
Possible Causes:
TP sensor signal circuit is shorted to ground TP sensor VREF circuit is open or shorted to ground
Trouble Code: P0700
TCU Request For MIL -ON-
Possible Causes:
poor connection TCM
Trouble Code: P0121
Throttle Position Sensor Performance
Possible Causes:
MAF sensor or TP sensor ground circuit has high resistance MAF sensor has drifted out of calibration TP sensor has drifted out of calibration TP sensor is damaged or has failed PCM/ECMTP sensor is damaged or has failed PCM has failed
Jun 08, 2012 | 2003 Kia Sorento
Diagnostic Code P2074 on 2007 PT cruiser-can't find on OBD list.
P2074-manifold Pressure/throttle Position Correlation
CORRELATION - HIGH FLOW/VACUUM LEAK
When Monitored: Engine Running, during all drive modes.
Set Condition: If vacuum drops below 1.5 Hg with engine RPM greater than 2000 RPM
at closed throttle.
POSSIBLE CAUSES
VACUUM LEAK
HIGH RESISTANCE IN MAP (K7) 5 VOLT SUPPLY CIRCUIT
RESISTANCE TO GROUND IN MAP (K7) 5 VOLT SUPPLY CIRCUIT
MAP SENSOR
HIGH RESISTANCE IN (K1) MAP SIGNAL CIRCUIT
RESISTANCE TO GROUND IN (K1) MAP SIGNAL CIRCUIT
HIGH RESISTANCE IN (K4) MAP GROUND CIRCUIT
PCM
TP SENSOR OPERATION
HIGH RESISTANCE IN (K6) TP SENSOR 5 VOLT SUPPLY CIRCUIT
RESISTANCE TO GROUND IN (K6) TP SENSOR 5 VOLT SUPPLY CIRCUIT
TP SENSOR
HIGH RESISTANCE IN (K22) TP SIGNAL CIRCUIT
RESISTANCE TO GROUND IN (K22) TP SENSOR SIGNAL CIRCUIT
HIGH RESISTANCE IN TP (K4) SENSOR GROUND CIRCUIT
Mar 27, 2009 | 2007 Chrysler PT Cruiser Touring Hatchback
DISH Network IR Remote Control Logo
35 people viewed this question
Top DISH Network Televison & Video Experts
S. Gontko
john milligan
Jaime Hernandez
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
