Question about Fantech DBF110
MY FAN HAS BEEN INSTALLED FOR 2 YEARS AND HAS HAD NO PROBLEMS UNTIL 2 WEEKS AGO. IT STARTED TO CYCLE ON AND OFF BEFORE IT WOULD SHOUT OFF. NOW THE FAN CONTINUES TO RUN. THE FAN IS ON A VERTICAL RUN OF 16'. IT IS INSTALLED 3' FROM THE ROOF OPENING. "THANKS"
Temp on screen rises & flash high temp.
Hallo
The compressor winding's could also be faulty.
regards
May 19, 2016 | Frigidaire Refrigerators
2001 Honda Accord. I am having clutch problems. I changed the master and slave cylinders 2 years ago and it worked fine. About 3 weeks ago it started acting up again and I changed the slave cylinder. It...
Master and Slave cylinder will not require often replacements until they replaced it with some cheap ones. With new master and slave, you still need to bleed the system to make sure there is not any air bubbles present in the system that might prevent it from proper functioning.
May 19, 2013 | Cars & Trucks
I have a Sony KP-53HS10 TV for over 9 years. It still works great, good picture. But few weeks ago, it started making a "ssssssi" noise after turning on 4~5 minutes. The noise might come from a cooling fan...
There are no fan in this tv.This tv most common problems are the dead convergence board parts have problems,picture have colors lines R,B,G out of alignment,have colors shadows,and 3D pictures.The convergence board must have it 2 STK convergence ICS and some or all it resistors to be replaced to solved convergence problems.The problems u discribing,it a starting point,just the convergence problems,have not take it effect yet.Sooner or later ur tv will have the convergence problems.
Jun 23, 2010 | Sony KP-53HS10 TV
2004 Mitsubishi Outlander AWD, over heats when idle/stopped, cools down when driving. Added antifreeze 2 weeks ago, problem fixed until yesterday when started heating up again during idle, antifreeze...
Sounds like the electric fan is not coming on. Could be the switch screwed into the radiator, a malfunctioning fan relay, a blown fan fuse or the fan motor has gone bad.
Jun 23, 2010 | 2004 Mitsubishi Outlander
Grrr...! Okay, I had the 1400 for 2 years, loved
If you've only bought it 2 months ago it will still be under warranty.
Apr 22, 2010 | Epson Stylus 1400 InkJet Photo Printer
Dishwasher wont drain after rinse cycle . Moffat Quiet One
My dishwasher runs but just does not clean and leaves food particles all over like its not getting clean water to it. I cleaned the passages of any food from the top end. Any suggestions. Its a moffit MLD4007l20ww
Feb 20, 2010 | Dishwashers
2003 Toyota Corolla 30 amp keep blowing
it sounds like when the cat was changed they have trapped a wire or just moved one over a bit and its rubbing think about what items this 30amp fuse is protecting are any of the items close to the exhaust or around that area, i dont see the aftermarket starter doing this after 2 years hope this is helpful regards JR
May 17, 2009 | 2003 Toyota Corolla
Fantech DBF110 Logo
87 people viewed this question
Top Fantech Dryers Experts
Marvin
Marvin
Are you a Fantech Dryer Expert? Answer questions, earn points and help others
