Question about DISH Network IR Remote Control
I need a remote control code for tp 3730 - DISH Network IR Remote Control
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 358 Answers
Tony_ballard
I could not find a code for that TV brand but I have provided instructions on performing a power scan to possibly find a code with your DISH remote that will work for your TV. I hope this helps.
Remote: Basic Remote (Television Only)
  1. Turn the Television On.
  2. Press and hold the TV Power button for three seconds until the LED flashes.
  3. Press and release the TV Power button.
  4. Press and release the Up or Down Arrow on the remote until the television turns off.
  5. After the television turns off, press and release the OK button.
  6. Test functionality with the TV.
  7. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
Ray Calo
DISH Network
Posted on Apr 19, 2011
Hi audi a3 2.0t bwa two faults p2127 and p2122 what can cause this problem
code p 2122 has three reasons
1--accelerator pedal position (APP) sensor---switch D--low input==causes wiring short to ground --APP sensor /switch
2---throttle position(TP) sensor /switch D--low input===causes ---wiring short to ground--TP sensor/switch
3---engine control module (ECM) idle control---high input===causes --wiring short to positive ---TP sensor---ETS control module
code p 2127 refers to APP sensor--switch E--low input===causes wiring short to ground --- APP sensor/switch
also refers to TP switch E--high input====causes wiring short to ground ---TP sensor switch
Jan 31, 2018 | Audi Cars & Trucks
We need a remote control for a model TP 2012 DA (OA?) aRE THEY AVAILABLE?
You can use a universal remote. The codes for Quasar tv are 0171 0148 0054 0170 0062 0374 0381 0003 0070. Gerald
Sep 08, 2011 | Quasar TP-2012D 20" TV
I need a code for my sky remote for my Onn T.V model number TL2638-TP
Hello
Sky remote codes for Onwa Tv are:
246 399 461 609
Sky+ Remote Control Unit Programming Procedure Follow the steps below
1* Select any channel on the TV.
2* Point your Sky+ remote control away from the TV and press the tv button.
3* Press and hold down the Select and red buttons simultaneously on the Sky+ remote control until the red light at the top of the Sky+ remote control flashes twice.
4* Input the 3 digit number from the Sky+ remote control codes then press the Select button. The red light at the top of the Sky+ remote control should flash twice.
5* Point the Sky+ remote control at the TV and try the volume button.
If this works try the other TV functions.
If these work then the correct code has been selected.
It's important to note that not all TV functions will be supported by the Sky+ remote control e.g. Picture in Picture.
If all functions do not work correctly, then repeat steps 1 - 3 and work through all the relevant 3 digit numbers from the Sky+ remote control codes, until you find the code which supports all or as many of the TV functions as possible.
Please note: In order to operate both your TV and Sky+ with your Sky+ remote control, you will be required to switch modes e.g. to switch on your TV from stand-by, you would need to press "TV" followed by the "Stand-by" button. Then to change channel on your Sky+ you would need to press the "Sky" button followed by the "TV guide" button.
OK.
Jul 25, 2011 | Televison & Video
I need a code for tp 3730dvb
I would need to get a better idea of what model remote you have. I would recommend viewing our link here which provides both the instructions and codes to program your remote
http://www.dishnetwork.com/SupportSection/remote-setup
If the codes there don't work you can also try a power scan listed below to try and scan the code for the remote in. Which button you hold below depends what the equipment you're programming does. If VCR/DVD you'll use that button, if another device you'll use AUX.
1.) Press and hold the VCR/DVD or AUX button (about six seconds) on top of the remote until all mode button backlights come on, then release.
2.) Press 0 for a TV, 1 for a VCR/DVD, 2 for any other device then press STAR (*) and press and release the Power button.
3.) Press the Up button once a second while pointing the remote at the desired equipment. If the code for the equipment comes up, the equipment will power off.
4.) Press the POUND (#) button. If the code entered is valid for the remote, the mode light flashes three times. To verify the code works try several different functions for that equipment.
Mar 21, 2011 | DISH Network IR Remote Control
The remote code for Dishnetwork to work a coby tftv 3217 tv?
U have tp call the company for the code then program your remote
Aug 09, 2010 | Televison & Video
Unable to pair a Philips Universal remote with Sansui TV
Hi
1032, 1051, 1052, 1054, 1061, 1075, 1079, 1091, 1140, 1157, 1173, 1203, 1209, 1232, 1237, 1258, 1287, 1337, 1339, 1340, 1375.
Regards
Phillip
Aug 15, 2009 | RCA RCR311B Remote Control
Need manual for rca
How to program my coby tv to my rca universal remote control
/uploads/images/need-manual-rca-34705436-4-1.jpg
Sep 16, 2008 | RCA 3-Device Universal Remote
Need help tp program my rca remote control HELP
I misplaced the instructions to the RCA TV remotes with the codes. Could you please provide me the codes to operate a Sansui Television. Remote: RCR311B
Jun 15, 2008 | RCA RCR311B Remote Control
Codes for universal remote control
i have the list of codes for the 40085 HTFB, but no instructions. (I assume this is because it's LIDL - their store security is a joke). Which code do you want? And do you want to swap for instructions on how to set up for a specific TV?
Jan 10, 2008 | Universal Remote Control URC-6131N Remote...
DISH Network IR Remote Control Logo
62 people viewed this question
Top DISH Network Televison & Video Experts
S. Gontko
john milligan
Jaime Hernandez
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
