Question about HTC Cell Phones
I need to upgrade my firmware so I can get live wall paper how do I do this
    Scholar:
  • 32 Answers
Hey there,
If your carrier has pushed out a firmware upgrade then upgrading will be a breeze. Simply go to the setting page and click about phone. Once there click on the option to search for update. If there is a firmware upgrade available you can then go and download it. If your carrier has not pushed out any firmware upgrades to its users then this method wont work and you will not be able to upgrade without rooting your phone and voiding your warranty.
Hope this helps!!!
Posted on Mar 22, 2011
Hp z2100 paper jam but no paper jam
If you have both firmwares as files, then yes you can downgrade, but be aware that some changes in firmware are not reversible as they reprogram hardware. Keep in mind that this product is classified as EOSL (end of support life) which means HP no longer provides support or spare parts.
Jan 24, 2015 | HP DesignJet Z2100 InkJet Photo Printer
After firmware upgrade the HP 4015x will not boot up with the duplex unit installed. Boots up ok without the duplex. We even reapplied the firmware upgrade.
I had the same problem. HP Pro Support advised me to
deinstall the additional paper tray and the toner.
and reapply the firmware update 3 times.
It sounded stupid to me but it worked!!!
Be sure to use usb connection and wait 30 min between progress.
1 st time - no paper tray, toner, wait 30 minutes
2 nd time - no paper tray, wait 30 minutes,
3 rd time - all together now, wait 30 minutes
I hope this will help you and others,
Arthur
Nov 05, 2010 | HP LaserJet P4015N Printer
Xbox Live with Netgear WNR834M Router
please follow the steps to fix you issue
1.upgrade firmware on router
link for latest firmware
http://kb.netgear.com/app/answers/detail/a_id/863
follow steps to upgrade firmware on router
1.Log in to the router using a Web broswer. The URL is http://192.168.1.1 ( if you did not change the router’s IP address ).
2.Click Maintenance > Router Upgrade
3.Click Browse and find the file you just downloaded.
4.Click Upload. Do not interrupt the upgrade while the router does this step. The router reboots when the upgrade is done.
5.After the router boots up, log in the router again.
6.You MUST Reset the router to default settings after upgrading the firmware
7.Click Maintenance > Backup Settings
8.Click Erase. The router reboots when the Erase operation is done.
9.If you would like to check that the upgrade was successful, log in to the router again at http://192.168.1.1, and check the firmware version.
10Re-configure the router with the settings you saved in step 1. Optionally, You can use the Smart Wizard configuration assistant on the CD to reconfigure the router.
after all this login to router
under advance you will WAN setup there will NAT ,you need to click on open then apply
regards
prakash
Jan 26, 2010 | NetGear RANGEMAX WNR834M Router...
I ripped Bluray movies using "ANY DVD HD" to my hardrive then playing them through "WD TV Live HD Media Player" (using HDMI cable to Sony Bravia HD L.C.D.TV) some movies work good but others play the video...
Either check around in Any DVD HD or the BluRay menu to set audio output to PCM, which doesn't require any decoding to play back properly or you will have to convert them separately.
Nov 30, 2009 | Western Digital TV HD Media Player USB...
The printer runs and the paper feeds but no thing is printed on the paper. I have had no problems previously. both cartridges have ink in them
perhaps the printer needs a firmware upgradation. open home center on ur computer,connect ur printer and computer and then go for a firmware upgradation.it will solve the issue if not,call kodak @ 1800 421 699
Jul 18, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
BONJOUR MONSIEUR :JAI DES PROBLEMES AVEC MON IMPRIMANTE HP500PS
MY DESIGNJET 500 HAVE THE 79:04 ERROR IT WAS JUST CUTTING THE PAPER WHEN THIS OCURR
Mar 03, 2009 | HP DesignJet 500ps (42 in.) InkJet Printer
Lost wireless-B light after firmware upgrade
I own the same router. In the back of the router there is a little red button you can push with a pen or the like. This should restore the factory default settings on the router. That should rollback the firmware upgrade and solve your problem. You will need to setup your router again but it should not be a paper weight anymore.
Jan 24, 2009 | Linksys BEFW11S4 Wireless-B Broadband...
Firmware upgrade
Firmware Upgrade Instructions:
Please download and unzip the firmware file to computer's local hard drive and then follow the instructions in the "readme.txt" file to upgrade the firmware.
Warning : -
Firmware upgrade failure may permanently damage the unit and causing it not to function. If the issues in the "Release Note" do not address the problem you are experiencing, please do not upgrade the firmware. Never upgrade the firmware using a wireless connection. Firmware upgrade will reset the Router to factory default state (all current settings will be replaced by default settings). When necessary, please write down the Router's current settings before performing the firmware upgrade. Please do not load the previously saved Router "configuration file" to the new firmware.
If you need assistance performing the firmware upgrade or if you have any questions, please contact our Techsupport Team http://www.trendnet.com/support.
Feb 16, 2008 | Trendware TEW-452BRP Wireless Router...
Whole thing
First thing you can try is Upgrading the Firmware or reflashing the Firmware. Open the Home Center software click the [ ? ] button on the top right then click [ maintenance ]. Then click [ Firmware Upgrade ] and follow the steps to complete it. even if the Version is the same. But do not complete it if the version is older then what you have. if it is older run the check for updates in the software and do the firmware upgrade again.
If that does not work open the back panel check for paper.
Make sure the small photo tray is not pushed in half way.
If all else fails take it back and exchange it. These are nice printers, dont let the few small problems get you down. The quality of pictures they print are great and the ink is cheep.
Feb 09, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
XBOX
Yes, both Playstation 2 Online and Xbox Live have been tested and are known to work with both game consoles online. Do make sure that you are using the latest version of the routers firmware. To get the latest version go to http://networking.belkin.com and click on Firmware. Make sure you download both the firmware and the instructions on how to update the router. If you are already running the latest version then you do not need to perform another upgrade. To check to see if you have the latest firmware version open a web browser and type 192.168.2.1 into the address bar. Log into the router as instructed in the user manual. Once logged in choose Utilities over to the left and the choose Upgrade Firmware. It will tell you the current firmware version in there. If it is V1.20 or higher then you are OK.
Feb 16, 2006 | Belkin (F5D6230-3) Wireless Router
Cell Phones Logo
153 people viewed this question
Top HTC Cell Phones Experts
Charles Blake
Charles Blake
Level 1 Expert
D. E. Hev
ChuckyMo
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
