Question about Air Conditioning and Heat for Lexus IS 250 C
The A/C on my IS250 remains switched off when I restart the car and the yellow front defroster light blinks. I have to press the Auto Button again and readjust the temprature down from 25C
I have problem with remote control, my remote control gives me blue light to switch the dashboard on but there is no lights coming on the dashboard. what is the problem
Hi, your remote has probably lost its coding. If you have the owners manual check page 65 learning additional remotes. If not do the following 1. Plug in the 6 pin hopped coded plug to control unit under drivers seat. 2. Press unlock button twice to disarm. 3. Press learn button on hopped coded plug. this erases all pre learnt codes. The led on dash should start blinking once per sec. 4. Press learn button on hopped coded plug again. The led on dash remains on for 4 sec. and then starts blinking faster. Ensure to do step 5 within 25 sec. 5. Press any button thrice on your remote that has a problem. 6. In response led on dash remains on for 4 sec and then blinks once per sec.This indicates that the remote has been learnt. Hope this helps.
Mar 09, 2015 | 2006 Tata Indica LSi
Tip
2010 BMW 528XI Garage Door Opener Homelink Setup
**** >>> This setup I performed with my new 2010 BMW 528XI Garage Door Homelink and Chamberlain Garage Door Opener <<< ****
Chamberlain:
01. Power off or unplug the garage door opener motor power supply (which is mounted on ceiling of the garage) ;;;
02. keep the garage door opener transmitter in your hand (do not press any button at this time) ;;;
03. In your 2010 BMW 528XI Homelink button (which resides under rear view mirror) press the 1st and 3rd homelink button together for about 30-40 seconds (i.e., until the yellow light blinks fast) and when the yellow light next to the homelink button blinks fast release from pressing the (homelink) buttons ;;;
04. now hold the garage door opener transmitter closer (means within 2-4 inches) to the homelink button (either 1st or 2nd or 3rd) whichever you are planning to program to open the garage door ;;;
05. now press the garage door opener transmitter button and chosen homelink button (either 1st or 2nd or 3rd whatever you need) together ;;;
06. the yellow light (next to homelink button) initially may blink slowly but after few seconds (may be 10-20 seconds) will blink fast; once it started blinking fast release from pressing both garage door opener transmitter and homelink button ;;;
07. Now plug or power on the main garage door opener motor (which is mounted on garage ceiling) ;;;
08. On the main garage door opener motor (which is mounted on garage ceiling) press the "LEARN" button (once you press it may have yellow/orange color light; make sure the light is on) ; then within 30 seconds do the next steps #9, #10, #11 very carefully ;;;
09. go to your car and press the homelink button you programmed and hold it for 4 seconds and then release it --> 1st iteration ;;;
10. again hold the same homelink button you programmed and hold it for 4 seconds and then release it --> 2nd iteration ;;;
11. again hold the same homelink button you programmed and hold it for 4 seconds and then release it --> 3rd iteration ** important note; generally three iterations are not necessary; and steps #9, #10, #11 must be performed within 30 seconds ** ;;;
12. during one of the iteration you will hear "CLICK" sound one-time from Garage door motor (which is mounted on ceiling) and if you have light attached with it; it will blink once (** if you hear the CLICK sound and/or light blinks once**) then the particular homelink button is programmed ;;;
13. now press the programmed homelink button; the garage door will open or close (but always it will take 3 or 4 blinks in yellow light or 2-3 seconds before the garage door opens or closes and which is normal) ;;;
** Thats it, your 2010 BMW 528XI Garage Door Opener Homelink setup is complete ** ;;;
You can program rest of the homelink button the same way but following from the steps between #4 and #13 ;;;
Hope this steps will help you to program chamberlain Garage door opener in 2010 BMW 528XI Homelink. ;;;
** possibly the above same steps may work with other BMW 5-series cars homelink too (but I'm not sure) **
on May 29, 2010 | BMW 528 Cars & Trucks
Lexus IS250 trunk will not open
I have on 07 is250 and the power windows and trunk release were not working. There is a trunk/valet button in the glove box that needed depressed in order to make them work again.
Jan 03, 2012 | Lexus 220 SS SIGNATURE SERIES Cars &...
Canon i9900 printer. Yellow light remains on. Does not blink. Green light will not come on. Anyone know what part needs to be replaced?
1) With the printer powered off, hold down the resume button and press the power button.
2) While holding down the power button, release the resume button and press the resume button twice in succession. Now release the power
button. The indicator will blink in green and remain lit in green.
3) Press resume 4 times (Green) for Waste ink counter reset.
4) Press the power button. The printer will switch itself off after performing the function.
Or try
1) Power off printer
2) Hold RESUME button then press and hold POWER. (The beeper MAY sound once, or may not depending on your model.)
3) Hold POWER and Release RESUME.
4) Press RESUME twice then release both POWER and RESUME buttons.
5) When the indicator lights steady, press RESUME 4 times (for the S900, 3 times for the 8200 apparently).
6) Press power to set data.
7) Print away!
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 21, 2010 | Canon I990 InkJet Photo Printer
I was driving down the road and my 4WD HI light started blinking today on my 1997 Chevy 1500. If I put it in 4 LO the 4 HI light quits blinking and the 4 LO light comes on Press the 2WD button and the 4HI...
check switch connections,fluid level and actuator at transfer case if good have truck scanned for possible trouble code possibleas sensor or component going bad , some auto stores such as auto zone /advanced auto do it for free if theres a trouble code it will be a starting point
Oct 29, 2009 | 1999 Chevrolet Silverado 1500
Hello. I get 8 yellow flashes indicating the ink
Or try
7) Print away!
Oct 07, 2009 | Canon i950 InkJet Photo Printer
Lacie 2 big does,nt boot
Hmmm, reseting worked on mine. Identical symptoms except light stayed blue, not red. Unable to power down.
Before trying to get the drive working I got the data off using the procedure in the second post of this thread:
http://www.linuxforums.org/forum/peripherals-hardware/126831-reseting-lacie-2big-network.html
You need a linux system running. Maybe a live cd will do. I installed on an old IDE drive I had.
I then rest the decive using this procedure from Lacie and my drive is working again. Worthless though, because I can't trust it.
The procedure below will reset the 2Big Network to factory settings:
IMPORTANT NOTE: Following the procedure below can ERASE ALL DATA on the drive. Prior to following these directions, verify important data is stored securely on a different storage device.
Switch the drive OFF. Once it has shut down, ensure the power switch remains in the OFF position.
If the drive is in the SAFE mode, move the RAID switch to the BIG mode.
PRESS AND HOLD the button on the front. MOVE the power switch to the ON position. The light on the front of the drive will start blinking.
Once the light stops blinking, RELEASE the front button.
When released, it will begin BLINKING AGAIN. When it stops, PRESS AND HOLD the front button. The light will begin to blink again.
When the light stops blinking, RELEASE the button. The drive is now resetting itself. Switch the RAID selector back to SAFE if desired.
To restore data if it was lost during the process, recreate the shares and users on the unit prior to the reset. Any firmware updates applied will need to be applied again.
Sep 02, 2009 | LaCie 2big Network (2-disk RAID) (301257U)...
MACHINE RUNNIMG STOPPED SUDDENLY WITH THE LIGHTS BLINKING AND WE TRIED TO RESTART IT AGAIN AFTER DRAINING THE WATER THROUGH THE OUTLET PIPE &OPENED THE DOOR REMOVED THE CLOTHES AND RESTARTED IT AGAIN BUT...
turn on power switch,then press the spin speed button then push start, the water should drain then spin. if the water does not drain chech the drain pump button trap, located lower left front panel.
Dec 30, 2008 | LG WM-2277HW Front Load Washer
Can not turn on laptop.
remove battery plug in power.startup.if pc still is flashing press and hold power button until pc shuts down.restart.everthing should be ok now.wait until os is loaded then insert battery.
the battery should not begin to charge.
Dec 05, 2008 | Toshiba Satellite A45-S120 Notebook
Trisonic ts-rc488
OK EVERYONE I FOUND ALL YOUR ANSWERS , IM JOHN FROM NEW JERSEY JAC1NJ@AOL.COM , FOR THE TRISONIC UNIVERSAL REMOTE CONTROL , TC-RC488 AND MAYBE OTHERS , INSTEAD OF THE CODES THIS IS EASIER,TURN ON THE TV OR VCR ETC. FOR THE POWER MUST BE ON WHILE DOING THIS PROCEDURE , PRESS THE YELLOW SET UP BUTTON AND THE DEVICE KEY U WANT SUCH AS TV1 OR VCR1 AND HOLD THEM BOTH DOWN UNTIL THE RED LIGHT ON UR REMOTE STAYS ON THEN IMMEDIATELY AFTER HIT THE YELLOW SETUP BUTTON AGAIN UNTIL UR RED LIGHT STARTS BLINKING THEN POINT THE REMOTE AT YOUR TV OR VCR AND KEEP HITTING THE RED POWER BUTTON AS THEN YOUR REMOTE IS TRYING TO FIND A CODE AND WILL EVENTUALLY FIND A CODE , AND YOUR TV OR VCR WILL SHUT OFF , THEN THE RED LIGHT WILL BLINK LET IT BLINK UNTIL IT GOES TOTALLY OFF, THEN HIT THE POWER BUTTON AND YOUR REMOTE SHOULD WORK , SOMETIMES YOU HAVE TO HIT THE DEVICE KEY AND YELLOW SETUP KEY SEPARTELY AND THEN THE RED POWER BUTTON, I CALLED TRISONIC AND ACTUALLY HE HELPED ME AND I HELPED HIM , HE SAID I SHOULD WORK FOR TRISONIC , THIS IS A QUICK SEARCH , NOT REQUIRING ANY CODE NUMBERS, HOPE I HELPED YOU ALL SINCERELY , JOHN A.CLINE , CHECK OUT MY LIST OF LYRIC BOOKS AND MUSIC AT WORDCLAY.COM BYE!!!!!!!!!!!!!!!!
Aug 19, 2007 | Trisonic TS-1666RFS Remote Control
Air Conditioning and Heat for Lexus IS 250 C Logo
Top Lexus Vehicle Parts & Accessories Experts
Colin Stickland
Colin Stickland
Hugh Mckernan
Hugh Mckernan
Level 1 Expert
Thomas Perkins
Thomas Perkins
Are you a Lexus Vehicle Part and Accessory Expert? Answer questions, earn points and help others
