To transfer pictures from your computer to your Android 2.2 device, connect the Android device to the computer by the USB cable. This should pop up a "USB connected" message. Click the Turn on USB storage on the Android device. If this doesn't show up, you might have to pull down the top notification bar on the android device and select "USB connected" first.
Once you choose to turn on USB storage, you will get a message asking you to confirm, as it can cause running applications to crash if they need to use the SD card. Select OK once you have confirmed you have no running applications that need the SD card.
After a few seconds your computer should have recognized it and pop up a message asking you how you want to use the device. Select view folder. If it doesn't pop up, you can always go to My Computer and open the drive named after your Android device.
To copy the files simply drag them from their current folder to the folder you want them to be in on your Android device. Please pay attention to the symbol on the file icon as you drag, as depending on system settings you might be either moving or copying the files. Shift and Ctrl will toggle this setting to the other one before you release the mouse while holding them.
Please leave feedback if this was helpful. Thanks.
