Question about Refrigerators
My drain tube keeps freezing every few weeks. I pour hot water to clear it out and I get it draining for a while, but it freezes up again and water collects in freezer.
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 239 Answers
Install a drain tube heater. Instructions are included with the heater kit.
Kelly
Posted on Mar 21, 2011
Kenmore side by side drain tube in freezer keeps freezing up Any solitons other than to keep thawing out the the every two weeks
try to locate the drain tube on the bottom and blow it with compressed air to clear the way for the condense water to drain out or open the freezer back panel and run hot water to see if it clears.
Dec 11, 2013 | Refrigerators
Subz 550 drain tube keeps freezing up, causing water to spill onto base of fridge and freezing
i know this is late but there's a heater kit made for this 4202160 is part number,you remove the shelves,you can put a mark under the shelf arm on the far outside where the shelves hook on so you can put them back in the same spot,then remove the light cover,the two screws and metal cover and then pull the wall off and set it to the side ,the drain heater kit plugs into the wire harness,the heater will heat up and keep drain from freezing,you can slide the tube off,stick a screw driver in to hold it down to the floor so you don't burn your hand and blow hot air into it with hair dryer to melt out ice,keep heat on for like 20 to 30 seconds then cold air or remove heat you don't want to mess the hose up from overheating wait a bit and hit it again until you melt out the ice,then i use a long plastic wire tie to stick into drain hose to clean it out,some nasty stuff in there,i use a steamer to clean the line out and then i have a piece of 1/4 inch plastic water line to snake into the drain,if this is the first time this has happened you don't need the heater kit,just clean out the tube and metal drain trough,also clean the back of the top crisper drawer shelf,crumbs and stuff can get in between the back wall and the top shelf and then will fall into the drain,if you keep that area clean you won't have to many issues and keep the fridge a little warmer so it doesn't freeze up the water in the drain tube,put the drain tube back onto the trough and pour hot water into it,if it drains down you're done if it's still blocked get a turkey baster and push hot water down into the drain tube to clear it,if it still doesn't clear remove the bottom kick panel,you'll see the drain pan and look at it because you have to get it back the same way in the clips then you can see the drain tube,stick a plastic tie up in there to clean it,sometimes there could be dust or something in the drain pan,when the water hits it it can get into the bottom of tube and block it but i've only had to do that once,hope this helps you out.
Nov 16, 2017 | Sub-Zero Bottom Freezer Refrigerator
Ice build-up at bottom of GE Monogram refrigerator. Ice melts and leaks onto floor. How do I resolve this problem?
The drain hole is blocked, so water is not drain and getting freezed, and then melting and it leaks.--------the drain is stopped up ,, remove the inside back panel inside the freezer and pour hot water into the troft under the coil in the back and flush the drain ,, once water runs though the drain hole then put the panel back in and it will be fine.
The drain tube is located below the pan below the fins at the rear of your freezer. The drain tube has a trap (s-shaped curve) to prevent air flow out of the freezer. The problem is that water gets in this tube and freezes. You can take the sheet metal cover off the back, get a turkey baster and flexible tube, and continuously flush hot water.this will clear the clog.--------- Thanks.
Sep 13, 2011 | Refrigerators
Water drips in bottom shelf of freezer, creating a piece of ice and then water leaks under refrigerator
Sep 13, 2011 | Frigidaire Refrigerators
Condensation drain hose freezes - water drains into frig.
The problem is probably the drain itself. It is probably partially clogged. Another thing could be ice build up. I will usually get a peice of metal coat hanger a few inches long and I will hook it over the defrost heater and let in hang into the hole about an inch or so. That way when the unit defrosts that hanger will heat up and keep it from freezing.
Sep 07, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
My freezer drain line must be stopped up. It fill the freezer with water and freezes a thick layer of ice. It then drips in to the frig!! How can I upstop the drain line? I have poured hot water and used a...
The backed up ice must be completely removed and the line cleared all the way to the collection pan.make sure the frig is positioned so the water drains quickly. you can also wrap a piece of 10 gauge copper wire around the defrost heater and allow it to stick into the drain hole a few inches without touching the drain tube to keep it from refreezing again. Eric
Aug 11, 2009 | Refrigerators
Same Problem ...Drain Hole Freezing up.
After facing the same issue (defrosting, cleaning the drain, drain gets blocked again...start again: defrost, etc..) I decided to try to give it one last go:
1. Defrost
2. Clean & rinse the drain (ensure is fully clean and I can pass liquid through the drain).
3. Get a ~30 cm pure copper wire
In my case I took a 3amp power cable, and took the copper wire from one of the cables.
4. Wrap one end of the copper wire around the copper coil at the back of the fridge (where the coil is warmest)
5. Insert the other end of the copper wire in the drain (just above the drip tray). I inserted ~15cm of wire into the drain.
The purpose of these last steps was to ensure there was no "freezing" happening on the drain. The copper effectively will keep the temperature inside the drain above freezing.
Not sure how permanent this might be.. so far at least I'm getting more months than with the previous symptoms treatments ;)
Best of luck!
Jul 09, 2009 | Hotpoint RFA60 Bottom Freezer Refrigerator
Sub Zero 550
Clarkk what that metal strip is doing is transfering heat from the heater to the drain to keep it from freezing. Make sure that the metal is connected tightly to the heater. I have used 14 guage copper wire to build this strap to help resolve the issues.This will keep the drain from freezing. You can if you want get what is known as a drain heater. It is wired in with the heater and slides down the drain and heats the drain when the heater is on.
Aug 18, 2008 | Refrigerators
Refrigerators Logo
230 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
