Will not turn on or show picture. - Televison & Video
  • 6,993 Answers
The issue you describe is consistent with a power supply board issue. This is the board where the AC goes to. This problem may have occurred as a result of irregular power supply, or excess power supply or power surge.
The TV is receiving current but cannot circulate or transfer the current to other necessary part of the TV because of the defective power supply board.
I do not think it needs replacement, rather some defective capacitors are causing this issue.
Open unit up and take a look at the power supply board.You will probably see one or more electrolytic filter capacitors that are bulged up in the top-not perfectly flat like the others.
The value of these capacitors will be different, most likely they will be somewhere around-820 to 2200uF/25 V( or /10V sometimes)
You can replace them with same values but I would recommend the voltage rating to be higher(like 35V for an original 25V) for reliability purposes.
What happens is,these bulged top capacitors will cause a low and unfiltered DC voltage=main board will malfunction(the relay will keep clicking until the caps are holding enough charge to bring the voltage up over a threshold point).
You can buy these capacitors at any Fry's or Radioshack store or you can order them online at vendors like "mcmelectronics.com"(look for electrolytic capacitors).
After replacing these capacitor(capacitors) most likely the normal operation will be restored.
Note: There may be also some other causes for this symptom ,like a defective T con board ,or main board,but the bulged top capacitors are the most common cause for this issue.
If you don't know about TV repairers, take the TV to the nearest repairman to fix the fault for you. Also, note that TV stores a lot of current, so wait a while before opening the TV back cover.
I hope this helps.
Good luck.
Posted on Mar 21, 2011
My camera turns on but won't show a picture
If your camera is a "SLR" camera, the screen does not show "live", but only after you take a picture...
Jan 19, 2015 | Pix Cameras
The red light turns on but no picture comes on
Get real close to screen and maybe use a flash light to shine on the screen and see if you can see the picture still, it will be dark and almost not visible but you should notice something move. If your screen has picture then you most likely have a back light problem. Most common problems are bad inverters, or the inverter controller card. possibly a bad power supply but most likely inverters, test each circuit, replace as needed.
Sep 17, 2012 | LG Televison & Video
White screen
This is a problem with shutter not fast enough opening to take a picture indoor shows the horizontal lines. In sun light it is too slow and over expose the picture. Not worth the trouble to fix, buy another camera?
Jun 26, 2012 | Olympus Cameras
It does not shows clear picture
turn the black ring that is around the len's while your cam is on and you can see a picture. ...the black ring will focus your lens. turn till you get a clear picture...turn either one way or the other till picture clears up
Aug 30, 2009 | HP USB Web Camera
The monitor turns off and on repeatedly.
Is it desktop or laptop computer?
If its desktop the data cable might be loose on the back of the desktop computer.
Apr 26, 2009 | Acer Computers & Internet
DID NOT SHOW THE VIEW TO TAKE PICTURE INSTEAD IT
I THINK ITS A MEMORY STICK PROBLEM. PLEASE TURN OF YOUR MEMORY STICK AND TAKE PICTURE AGAIN . I THINK IT WILL BE WORK.
MY ADDERSS IS : bony_don@yahoomail.com
Mar 13, 2009 | Sony Cyber-shot DSC-N2 Digital Camera
Nothing shows on camera screen
Was taking a picture, the screen turn black; nothing shows up.
Oct 12, 2008 | Canon PowerShot A75 Digital Camera
Linux and UNIX wget command help --dns-cache=off, Turn off caching of DNS lookups. Normally, Wget remembers the addresses it looked up from DNS so it doesn't have to repeatedly.
Good Luck, Please dont for get to Vote/Thank You.
Dec 22, 2007 | Philips Magnavox 15MF400T 15 in. LCD...
Televison & Video Logo
14 people viewed this question
Top Televison & Video Experts
