Question about RCA L26WD26D 26 in. LCD TV
The set started coming on with a bright white screen, let it stay on for a while, then turn it off then on, and it will come on and work fine. It is now just coming on bright white and variances thereof and won't come on after repeated attempts at off-on. RCA L26WD26D flat screen LCD
  • RCA Master
  • 12,061 Answers
Hi, well I have seen this similar type of thing in my shop from time to time, whenever a screen is bright white, this usually indicates that the screen is being overdriven in the Brightness area, and it is being made so bright as to white out any images, or variations of similar things.
Now unfortunately there are quite a few things that will cause a symptom such as this, from a faulty supply rail from the PSU, to a broken down Diode in the brightness circuit, or even the display module itself.
To isolate and try to find out exactly what is wrong,one would have to have a service manual, & special equipment, and at the least. to my mind these days it's not that practicable to DIY these sets these days, unless it is a clear cut fault and fix, which this is not. Accordingly it is my recommendation, that you contact an RCA local or head office, and ask for a referral to an authorised service center, at the service center first ask for a "Quote" for the repair, before allowing any repair work to be started.
This way you can then make an informed decision as to repair or replace,as often these days we find, that the cost of repairs can quickly escalate,and often it is better to put any monies that would have been spent on repairs towards a NEW, unit with a full warranty.
Posted on Mar 22, 2011
    Sergeant:
    Champion:
  • 234 Answers
I am sorry to say but this will be a hardware fix. Your video board has failed and will need to be replaces, as well as the main power board may need to be replaced. Here is a short list on google of the parts you can get yourself. You will need the powersupply and main board. But I do recommend having it professionally worked on if you do not know how to repair this yourself.
Google parts list here
Posted on Mar 21, 2011
LCD screen is white, dim picture and sound works fine
seems the white balance is set inccorectly and the brightness is set wrong check your TV's menu and set them back to normal or reset the display controls in the tv menu if it turns all back white and dim then the display panel of your tv is needing repair
Mar 02, 2017 | Televison & Video
When trying to take pictures outside the screen goes blank.
Try to manually make it so that it is set to outdoor settings. Or maybe try low brightness and no flash.
May 12, 2008 | Olympus FE-190 Digital Camera
Asus Eee PC 1215n half screen on the right is white, the other half is fine
The LCD screen in your laptop is defective, the only option is to replace. Go to www.ebay.com Type: make and model of laptop, refine search to screen.
May 23, 2012 | ASUS Eee PC Seashell 1215N-PU17-RD...
LCD screen and small viewfinder screen go snowy than white. When I turn the camera on the LCD worked fine, when I than turn it, it was just white. Now it won't even turn on normal. I can still make...
Go to your menus, set all to factory settings or default.
Test the camera by using more of the settings, and notice how it works.
The LCD settings especially are what you want to make sure are set right...not too bright, and of course not too dim either.
Sep 25, 2009 | Canon Cameras
The screen won't light up and when the screen slided up the screen display becomes too bright (white) that nothing can be read off it
My MDA loses its settings frequently as well. Go to Start, Settings, System, Backlight, and see what it looks like. Maybe the settings have changed.
Sep 06, 2008 | T-Mobile MDA
Monitor black screen
Your first step in troubleshooting this problem is to plug in another monitor to your computer. If you are having the same problem it is related to your computer. If the second monitor works fine then your original monitor is shot.
May 11, 2008 | Mag Innovision LT776s 17" LCD Monitor
Sidekick 3 screen problem
This procedure usally will fix a white screen on a sidekick 3 or a sidekick ID.
http://www.repairmysidekick.org/Fix-Sidekick-White-LCD-Screen
Try this before you replace the LCD
Dec 06, 2007 | T-Mobile Sidekick® 3 Cellular Phone
Constant white screen
check the brightness and contrast from the menu on the monitor try increasing it ... the problem will get solved...
if same problem persists contact ur near by experrt technician he may tell that the tube is gone he must recharge it....
Sep 11, 2006 | Sony SDM-HS73P 17" LCD Monitor
Getting More Brightness/Contrast ?
problem with my monitor Viewsonic E70....Memory recall keep flashing......any help out there.....
Mar 15, 2006 | HP 90 19 in.CRT Conventional Monitor
RCA L26WD26D 26 in. LCD TV Logo
79 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
