Sony vega kv-36xbr250 screen black - can feel static - has sound
  • 8,457 Answers
The tv 1 or 2 long LCD inverter board it is dead.These 1 or 2 long LCD inverter boards help the LCD screen panel to have a backlight to produced a picture.Tries websites like Shopjimmy.com,Ebay.com to buy those 1 or 2 LCD inverter boards for the replacement.
Posted on Mar 21, 2011
TV SONY Trinitron XBR KV-36XBR250
Check whether the filament of CRT glow or not. If not, check all the solder terminals at the CRT base card. If it glows, check all the voltages at the video output card, said above. If you wish to get some details, check the site linked here. http://electronicshelponline.blogspot.com/ Pull up older posts.
Jan 01, 2014 | Sony KV-36XBR250 TV
Red stand by light blinking continuously black screen
It cannot be reset fully unless it comes on and stays on (the model you have listed here.)
That set should have a blink error code--watch the red power light to see if blinking in a number sequence like 7blinks pause and repeats over and over.
Dec 20, 2012 | Sony KV-36XBR250 TV
I just got the Sony KV-36XBR250 from a friend of mine. It worked fine at his house. I have since moved it 1 mile down the road and I plugged the satellite cable into the "to converter" port and I don't...
double check your cable routing. The cable that goes into the tv from a satellite box should be "out to tv" or something like that. If you have an old vcr laying around you can test that on channel 3 to the tv. Just in case something broke in the tuner circuit. Hope that helps.
May 12, 2010 | Sony KV-36XBR250 TV
Sony Wega Kv-36XBR250 screen blinking
I have seen this flashing before, this could be an indication that the picture tube is weak, what happens is that if the white balance is off there is a circuit called akb it monitors the kathode of each gun and if they are not in balance it will attempt to balance it out. if it can't the picture will begin to flash, sometimes in some models the power light will blink 5 times. On some models the power light will only flash if the tv gives up trying to compinsate for white balance and shuts off compeletely. If you see the tv shutting off with 5 blinks then you know for sure it is time for a new set.
Sep 02, 2009 | Sony FD Trinitron WEGA KV-20FS120 20" TV
Was watching tv when all of a sudden screen went black but still had sound what could be the problem?
In this situation various faults could be arise, like oscillation is not being made, horizental out put could be open or short, filament voltages are improper, could be a cold soldering fault, Therefore i must advise you to consult any expert nearby.
Hope you will understand my sayings.
Thanks for using fixya.
Jul 02, 2009 | Sony KV-36XBR250 TV
Sony TV Won't Come On
Thats great, problem resolved.
Please rate solution as fixya ( 4 blue diamonds)
Thanks.
Jan 23, 2009 | Sony KV-36XBR250 TV
Blinking picture
TV Repairman came out today to look at my Sony KV-36XBR250 today with the exact same problem - he was able to adjust the settings through the service menu, but said it was a temporary fix only.
The picture tube is going and the Sony circuitry has a "video mute" that it uses when it senses the tube is not warmed up enough. The degraded state of the tube causes the blinking on and off as the signal from the tube wavers.
He ballpark estimated the tube replacement cost well above the price for replacing the set with a 37" LCD, so it's going to the dump...
Mar 02, 2008 | Sony KV-36XBR250 TV
Picture tube
Ibonne- firstly what is the reasoning for wanting a pix tube" do you have dark picture or poor color. generally when the tube is gone the screen changes to one color.the price of any pix tube is more than the set is worth generally.Please explain problem and maybe I can help you. cooltek Feb.15/08
Feb 14, 2008 | Sony KV-36XBR250 TV
No picture but sound is good. Screen is black
Do you feel static electricity on the screen when you turn it on? If you do, you have vertical output failure. If you do not, then the likely failure is the high voltage power supply.
Nov 06, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Televison & Video Logo
Top Televison & Video Experts
Marvin
Marvin
