Question about Bassett Baby Gear
We want to convert our Chris Madden Bassett crib (purchaed in 2003) into a full bed. Is it possible to find the conversion kit/rails or ones that would work? I've been told that they have been discontinued....
  • 3 Answers
SOURCE: Need Ellis Cherry Crib Conversion Rails (or substitution) in US
Yes all i have a solution for the simplictity problem.
There is a company in Canada that has the conversion rails and other parts you are asking about. They do deliver to the US. There name is The Kiddies Store. The Ellis collection is called the Sydney.
Phone number is 1-800-755-4857
web site is http://www.tjskids.com/simplicity-sydney-4in1-convertible-crib-cherry-p-4226.html.
Posted on Jul 13, 2009
SOURCE: Unique Oak Treasures Crib - Full Bed Bassett Model 5542-0521
We have this crib as well. We bought it from Babys R' Us in 2005.
We also purchased the rails to convert it to a full sized bed. It did not come with instructions but I can explain to you how to put it together.
The rail conversion set should come with 2 pieces of wood that act as the bed frame. You do not need to purchase the extended frame. The set should also come with 4 long screws, the hex tool to tighten it and 4 metal pieces. You might also have some wood nail cover plugs.
Once you've taken apart your crib, the only pieces that you will need are the 2 longer pieces of the crib...the headboard and the footboard. The 2 shorter side pieces which served as a headboard and footboard as a crib and the metal grate to hold up the mattress can be put into storage.
On the sides of each of the new wood rails, you will see a circle indent on each end with a hole. You will insert one of the long screws into each and then insert it into the head board. You must use the special tool to screw/ tighten it in. The metal flat pieces can be inserted into it the circle befor eyou are done tightning so that it does not strip or damage the end of the circle. You do this with the other rail on the other end and then add the footboard using the same process. If you would like, I can send you a copy of what this looks like close up. ( the cricle indent with screws. The bed is extremely strong. We've all napt in it as a family along with our 2 large dogs. I highly recommend ordering the extra long/ tall bed rails from OneStepAhead for security because my son has rolled out of the bed and it is super tall!
http://www.onestepahead.com/catalog/product.jsp?productId=534602&parentCategoryId=85183&categoryId=85216&subCategoryId=86203
Posted on Jul 18, 2009
  • 123 Answers
SOURCE: ELLIS CRIB SIDE RAIL CONVERSION KIT?
http://userguides.50webs.com/
These guys carry every make of crib and baby
furniture maker available.
Posted on Dec 05, 2009
SOURCE: Help! Pottery Barn discontinued Madeline crib
I plan to list one of the Madeline Conversion Kits in the Antique White on ebay tonight. Just do a search for this item or search under my store "L Decor and More".
Posted on Mar 19, 2010
SOURCE: Morigeau Lepine 9000 Collection conversion kits
Call Lazar's in Chicago. 847-679-6146. They may not be able to provide the conversion kit to people outside the chicago area, but they may be able to fax you instructions on how to do it yourself.
Posted on Apr 21, 2010
We have a Morigeau-Lepine convertable crib-day bed-full size bed, but we are missing the instructions to convert it to the full-size. It's model number is DA722-BC & the model is somewhere between...
I can't offer the exact answer, but hopefully my suggestions will be helpful...
Converting the crib to a full-size bed should actually be a fairly simple process of detaching the 4 sides that make the crib, and replacing the 2 short sides with the full-size bed rails that were sold separately in a conversion kit. The 2 long sides of the crib become the headboard and footboard of the full-size bed.
Unfortunately, it's only a simple process if you already have the full-size conversion kit bed rails. And since Morigeau-Lepine went out of business, they aren't making any more conversion kits. If you don't have the full-size bed rails, then this could be quite difficult.
It's possible that some stores that used to sell Morigeau-Lepine cribs might still have a conversion kit hidden somewhere in the back of their stock room or warehouse. You could try calling around to a few of your local stores to ask if they would check for you. It's a long shot, but it doesn't hurt to ask.
If you have the rails, or are lucky enough to find them, then it should be as simple as locating the screws that hold the crib sides together, removing them (most likely with an appropriatly sized hex-key,) and putting the screws back through the headboard and footboard into the bed rails. (I'm really just assuming that it works the same as the Babi Italia conversion.) If no screws are visible, or if removing them doesn't detach the crib sides, then they are probably also held together with locking bed rail fasteners. To release the fasteners, remove any visible screws, then push upwards on the short side rail while pushing down on the long side rail. You might have to tap the rail up with a rubber mallot to get it moving.
If you don't have the full-size bed rails, and you can't find them anywhere, your only option may be to build them yourself, or find a woodworker to build them for you. Search online for "Bed Rail Fasteners" and you'll see several options for hardware, but they might require modifying the headboard and footboard as well. Full-size matresses are 75 inches long, so you'll want the length of your rails to accomodate (ours are 77 inches long.)
I hope I've been helpful. Good luck!
Jan 19, 2011 | Baby Gear
Need side rails to convert our bassett 5469-0521 crib into a full size bed - where can I find them?
This is Products America! Although we do not carry conversion hardware, you may try www.bassettfurnituredirect.com and see if there are any rails for your Bassett crib at a Bassett direct near you. We hope that this will help with your crib hardware needs!
May 19, 2010 | Baby Gear
Missing conversion kit
I ran into a similar problem but found this out from a website when I ran a search:
The Sorelle Full Size Bed Rails (Sorelle Adult Rails / Full Size Bed Rails)
are designed to work with the following Sorelle Cribs: Madison, Tamcrest, Caroline, Vicki, Cottage, Chantelle, 9000 series, Turnberry, Anne's Lace, Manhattan, or Vista. When your child is ready to make the move from a toddler bed to a full-size bed with a headboard and footboard, you'll need these rails to make the conversion. Like all Sorelle furniture, the rails are eco-friendly, too. Each product by Sorelle is manufactured with water-based paints and odorless glue. And, Sorelle also participates in a reforestation program.
  • Dimensions: 59" X 31" X 51"
TabbedUI.prototype.initialize();
Mar 02, 2010 | Sorelle Vicki
Jul 12, 2009 | Bassett Cottage 3-in-1 Crib
I need bed rails for the simplicity ellis crib in white. Any suggestions on where to find them or an alternative?
i have the same problem but i searched long and hard and found this wesite where you can purchase the conversion rails.
Simplicity Ellis Crib Conversion kit for Full size Bed
http://www.nybabystore.com/p-4994-simplicity-ellis-convertible-kit.aspx
Apr 08, 2009 | Simplicity for Children Ellis 4 in 1 Sleep...
Instructions To Convert Jardine Madison Life Time Crib
To convert your crib to a Full Size bed you will need to purchase a set of full size bed rails (hook style for headboard and foot board). You can find this at any discount mattress store, or furniture outlet, it can range in price from $39.99 - $99.99. To install the rails you will see slots with bars on the headboard/footboard, this is where the hooks on the rails slide into. There are no bolts used to secure the rails to the headboard/footboard.
Jardine enterprises does not make a wood rail kit as was shown in some of the earlier ads for the Madison line of convertible cribs, and do not waste your time ordering the rail kit from Babies-R-Us as it is simply a metal rail kit (which you may be able to get cheaper at a local furniture/mattress store).
Use the lower daybed rail between the two front posts for the foot board. Another option for the full-size conversion is to purchase the metal rails (hook style) for a headboard only and not even bother with a foot board.
If you are still unsure of what you need to do for the full-size conversion please feel free to email me at gistecknician@aol.com.
Feb 21, 2009 | Baby Gear
Morigeau Lepine 1900 Series Crib Conversion Kit
Mother's Choice One Stop Baby Shoppe has the rails to convert this. I got mine last week.
416-285-0334
Feb 04, 2009 | Pali Katie Crib
HOW DO I ACTUALLY CONVERT A 3 in 1 CRIB TO A BED?
I have two children and I changed their beds from the cribs to the day beds by taking the front or footboard part off.  You have to save this part because in order to change it from the day bed to a full bed, you have to buy a siderail kit, take the sides off, and attach the siderails to the headboard and footboard.  Hope this helps!
Oct 11, 2007 | Bassett Cottage 3-in-1 Crib
Baby Gear Logo
280 people viewed this question
Top Bassett Baby Gear Experts
Jennifer Rock
Jennifer Rock
ray gallant
Tom Chichester
Are you a Bassett Baby Gear Expert? Answer questions, earn points and help others
