Question about Sony Computers & Internet
System boots and after with in 2 minutes its cuts the power and system shuts completely. Have to hit power button to reboot. I thought it was an over heating problem so i opened and cleaned the fan and heat sink, Still same problem
    Master:
  • 434 Answers
  • Try booting into safe mode
  • Check your power adapter
  • If it boots into "Safe Mode" scan for viruses
  • Does your computer make it to the log in screen?
Posted on Mar 21, 2011
Why doesn't my laptop start?.
remove the battery for about a 5 minute then insert it again, then press the on button
Jun 03, 2014 | Computers & Internet
Gx620 boots up, then screen goes blank, reboot gives blank screen with cursor blinking. will boot with cd but still shuts down after a minute or two.
Remove the battery and open the case. Look inside the computer with a flashlight to see if any of the capacitors are busted or leaking from corrosion. The capacitors look like little battery towers, but they are not as tall as the AA or AAA batteries.
If the capacitors are bad, your computer goes bunkers.
Apr 30, 2012 | Computers & Internet
Accidentally put my system on standby mode..using XP OS and DIY desktop.now i cannot get out of standby mode..check KB and mouse ok..any shortcut key or other ways i can start up and boot?even my two DVD...
I think you have to shut your computer down completely and reboot. This means that you will lose any work you didn't save before going in standby mode.
If your PC has a 'reset' button (usually located near the power button), press it. Your machine should reboot. If it doesn't or if you don't have one, you can try pressing and holding the power button for about 5 seconds. This should shut down your computer completely. Press the power button once more and it should boot normally, though you might get a warning saying Windows didn't shut down properly. If you get the choice, just choose to boot Windows normally. If pressing and holding the power button doesn't work, try looking for a power switch on the back of your machine. It should be near the power cable. Flip the switch, wait a few seconds and flip it again, then boot your computer as usual. You might get the same message which I mentioned above.
Mar 20, 2011 | Microsoft Computers & Internet
Hi there, Our Dell Inspiron 1525 specs are as follow: Windows Vista Home Basic Service Pack 1 Intel Core 2 Duo T5750 @2GHz 2GB RAM - 32-bit OS Symptoms are: - Freezes oftenly after random period...
Do you have any CD's thatcame with your laptop? If so, look for one that has "Diagnostics and utilities"listed under the "Contents". You will have to boot from that CD disk. To dothis, power on your laptop and tap the key to bring you to the "Onetime boot menu". Insert the CD and then select CD/DVD drive and hit key. Select the "Run the32 Bit Dell Diagnostics". Next select the "Express Test" and see if any errorsare detected. If no errors are reported, then your operating system software isprobably the culprit.The blue screen of death can be caused by hardware or software. If Diags pass you probably have a software issue. If you don't have the resource CD press the key while powering the system on. This will run theDell built-in Diagnostics.
Feb 22, 2011 | Dell Inspiron 1525 Notebook
HP had blue screen and said it would shut down. Problem is that it does turn off, so that it can be re-booted. Have tried to shut off PC, but continues to come on and not start.
Hold the power button in for 10 to 15 seconds for hard shut down if that doesn't work unplug power for about 5 minutes then plug power back in and see what happens
Jan 06, 2011 | HP Pavilion a1000n (PS567AA) PC Desktop
My computer won't reboot after trying to reboot it is stuck in a blue screen how do I get it to get out of the blue screen
You need to launch the Last know good configuration to get this fixed.
Follow the steps below,
Step 1: Shut down your PC completely.
Step 2: Trun on the Power button.
Step 3: As soon as you turn it on start hitting the F8 key on your keyboard until you get to a black screen called "Windows Advanced option". (If you don't get to that that screen but you end up reaching the blue screen than that means you have delayed in hitting the F8 key. start again from step 1.)
Step 4: As soon as you reach "Windows Advanced option" use your down arrow keys to choose an option called "Last know good configuration".
Step 5: Select that and HIT ENTER.
Step 6: you PC will boot to the windows. If this fails then you need to perform repair install using the Operating system CD.
Nov 21, 2010 | Computers & Internet
How can i reboot my computer.
If you are using Windows operating system then click on the lower left "Start" button, click on "Shut Down", and then let the machine shut itself off. Hit the power on button on your pc and turn it back on. That is the reboot. IF for some reason the Start button is not allowing you to turn off the machine, you are in other words "hung", then Hold Down the power button of your pc until the machine turns off. You should power back on your machine and choose to boot as normal.
Sep 13, 2010 | Computers & Internet
Computers & Internet Logo
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
