Question about Brother Office Equipment & Supplies
The AX-25 is printing ggggggg instead of normal print. Other letters also are printing.
    Genius:
  • 1,622 Answers
Does it power up? Does it go thru its initialization routine?
If it doesn't power up, it could be a blown fuse. It is located on th circuit board undrneath the top cover of the machine. This requirs removing I think 4 to 6 screws, on th bottom of the machine. UNPLUG THE MACHINE frm the wakll outlet.Check for 0 ohms with an ohm meter. If not 0 replace fuse. size and amperage is stamped in the silver ends.
If it powers up, but doesn't do its initialization, there is a plastic arm, on the left (ithink), or right side of the typewriter that goes into a slot to engage a switch. It could be bent or broken. If bent, GENTLY straighten it and see that it is lined up with slot. f it is broken, you can fabricate an arm with a piece of hard plastic and super glue it to th stub of where the arm used to be. Or, you can fold up a small piece if typing paper and stick it in the slot, carefully, and the machine will do it's "dance". Then youshould be able to use typewriter.
If these 2 solutions are not useful, you may need to find a service company to resolve problem.
Let me know
Posted on Mar 22, 2011
Hi. My brother ax425 is printing mad. How can I correct it
First check the printwheel. look at the spokes if they are not all the same in a row, replace the printwheel. and try it.
Jul 29, 2014 | Brother AX-425 Typewriter
Special paper tray is empty error
Sounds like someone requested A4 size paper in a print job instead of the normal Letter size paper...
Try putting regular letter size paper in the bypass tray and then set it up as A4 size...the print job should then print out on that paper.
Apr 09, 2014 | Xerox WorkCentre C2424DN All-In-One Laser...
How to print label on b-sx4 label printer
You must use the option send file to printer in the seagull driver not print else it is converted to graphics and sent to the printer.
May 16, 2012 | Toshiba TEC B-SX4 Thermal Label Printer
Prints some letters incorrectly
because of mixing in foreground in background
but as per your problem is concern it is because of wrong printer driver processing
Mar 16, 2012 | Panasonic KX-P1695 Matrix Printer
I have an ax 60 nakajima typewriter and the ceilings are not writing the letters that should appear when you mark this messy writing, not the logical order
If this says that the tops of the letters are not printing Be sure that the ribbon is properly installed and isn't folded.
DickyO
Dec 09, 2010 | Nakajima WP-T160 Typewriter
I have a Brother AX- 25 and I cant get it to print in Bold print, can someone help me with setting it up to print bold?
Here is where you buy a users guide.
Ribbon printers are switched to bold by sending an 'ESCAPE SEQUENCE' to the printer just before you send the print out for that line of text. The escape sequence should be in the owner's manual.
Word for Windows will Automatically print correctly in bold if the text is bold, if the right driver is loaded. I cannot find a driver. The driver should be IN Windows.
Apr 02, 2010 | Office Equipment & Supplies
Normal color print ,black print cuts off top/bottom of letters
Suggest using the printer software utility to clean the print heads, then print a test page.
Nov 29, 2009 | HP DeskJet F4280 All In One Printer InkJet
Brother AX-25 typewriter won't print
If the cams assembly in the carrier unit does not cycle properly the power on routing will not complete. This problem can be caused by worn contacts in the dc motor, causing intermittent or slow operation of the cams during POR or printing. This is common with older machines. I have replaced quite a few dc motors in carrier units of this style of printer. The motors are no longer available but they may be revived by spraying a good electronic cleaner in the holes of the motor to clean the brushes (RH SIDE). Take care to not damage the plastics of the case with cleaners. If you have many machines w/ motors, you may become accomplished at disassembling the motors and repairing the brushes, but this is difficult and time consuming.
Nov 16, 2009 | Brother Office Equipment & Supplies
ON SOME LINES OF PRINT, THE ENTIRE LETTER DOES NOT PRINT
Do a printer utility deep cleaning and possibly be prepared to replace the cartridges
Nov 23, 2008 | HP Photosmart 8450 InkJet Printer
Doesn't print correctly
Current printers do not have a 'built-in' font or character set. The printers only print what they are told to print by the application from which they are printing. What program are you printing from? Does it do this with all programs? Check printing from very basic programs like Notepad or Wordpad (print documents that are at least a couple of pages long). If the printer prints correctly from there, you may need to contact the publisher of the program that is giving you the weird printing.
Apr 23, 2008 | Canon PIXMA MP160 All-In-One InkJet...
26 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
