Question about Bose Companion 2 Computer Speakers
I recently bought some Bose companion 2 speakers. Shortly after I started using them the audio started skipping or sputtering really. And now when I plug the speakers or my other headphones in the jack the sound only comes out of the computer speakers.
  • 27,725 Answers
If you are having problems with your sound
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
Open up your computer the speakers plug/outlet is usually at the back of the computer
or you might have to clean the dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your sound card dust causes static to build up in a computer causing it to overheat any many other problems
be sure to wear an anti static earth strap before touching anything inside your computer
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it or select audio from the microphone drop down list make sure you have the right one selected and in the volume box make sure the microphone box has a tick in it or select the voice tab and make sure that you have the right media selected also select volume make sure the box for microphone has a tick in it
hope this helps
Posted on Mar 22, 2011
Can i connect my bose companion 2 speaker to my 42pg3000 plasma tv
yes audio out of your plasma tv use cable bose companion 2 Audio Input Cable with RCA plugs and try
May 20, 2012 | LG 42LG50 42 in. LCD HDTV
Okay I have a 2008 MacBook and my boyfriend bought me the Bose Companion #2 Speakers and the speakers sound out of phase when I up the volume. It sounds horrible from a different room you can even hear it...
Hi.
I would get an external sound card running on either USB (minimum 2.2) or firewire. I have had problems with mac audio ports. M-audio make a good range and so do ION. You need a stereo 2 in 2 out minimum (no need to overspend unless you plaun on starting a home recording or video project).
I would check to make sure there is no kind of phase switch on the speakers in anyway first though.
Jan 14, 2011 | Bose Companion 2 Series II Multimedia...
Bose companion 2 laptop speakers quit working
control panel sounds and audio,audio make necessary adjustments there or control panel,administrive tools,computer management,device manager,sound,could be a yellow? right click re-install drivers
hope this helps good luck
Aug 30, 2010 | Bose Companion 2 Computer Speakers
Speaker to sensitive to bits.
you can use another product with bose
Apr 09, 2010 | Bose Companion 2 Series II Multimedia...
Just purchased Bose Companion 2 speakers and I'm having difficulty connecting to my dell computer. Can you help?
What you need to do is connect your green audio jack from your speakers into the green audio connection at the back of your computer and you should have sorted it out :-)
Jan 02, 2010 | Bose Companion 2 Series II Multimedia...
I have Bose Companion 2 Series ones and the left makes odd noises
> I turn the volume to a low it still has the odd noise
If there is any drive to the speaker at all (volume not turned off), the rattle is probably coming from a broken 'surround;' the part that keeps the cone centered around the outer edge.
Another point of failure is a structure called a 'spider' that is located between the voice coil and cone that ensures the voice coil stays centered.
If there is hum with the volume turned completely down, the amplifier driving the speakers (internal or external) has a failing filter in the power supply.
Dec 14, 2009 | Bose Companion 2 Computer Speakers
Samsung TV and Bose Campanion 3 speakers
Are these PC speakers? OF so you need a stereo RCA to min-jack cable, assuming the TV has a set of RCA audio outputs.
Jul 25, 2009 | Bose Companion 2 Computer Speakers
Bass rattling on Bose Companion 2
My Companion 2 speakers were having the same problem with the rattling on certain frequencies and I am happy to say that Steve Allison was correct in my case. The speakers don't handle surround settings very well so if you're running your speakers through a source that had that setting turned on the easiest way to stop the rattling is to just turn the surround setting off. The speakers weren't really made to handle that kind of a signal.
Jul 14, 2009 | Bose Companion 2 Series II Multimedia...
Bose Companion 2 Computer Speakers Logo
114 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
