Question about Samsung Audio Players & Recorders
I have a samsung home theater model# ps FTZ512 and i can't sync the rear wireless speakers with the receiver. Can you please guide me through it?
3 Suggested Answers
SOURCE: Durabrand home theater speaker help
Hire an electrician
Posted on Oct 10, 2007
djnick989
  • 1067 Answers
SOURCE: RCA HOME THEATER SYSTEM REAR SPEAKERS NOT WORKING
cheak the mode u are in theter mode reg sterio mode wont do the back ok cheak settings dsp modes
Posted on Jan 20, 2008
Code to change settings for Small loud speakers to large. Model No HT-F450K to HT-F455K models
Speaker size selection usually is part of receiver set up; the DVD player has nothing to do with it.
Jun 27, 2016 | Samsung HT-C650W DVD Home Theater System,...
Hi, I recently purchased a Samsung - 1000W 5.1-Ch. Blu-ray Home Theater System: Model: HT-C5500XAA and was wondering what I need to make the rear speakers "wireless?" I understand a module is...
HT-C5500XAA / HT-C7530W This system comes with wireless speakers... Maybe return this system and get the one with wireless included.... Retails for $999.95
www.samsung.com/us/video/home-theater/HT-C5500/XAA - Cached
Also try out this website....It is quite handy.... Cheers...Sincerely HDTV GURU JAY
Mar 17, 2011 | Televison & Video
How do you fix rear check fault on samsung htc5550w blueray
It means that your wireless rear speakers can not be detected by the 'radio' on the bluray player. Move your wireless receiver (the one the rear speakers connect to) closer to the player or put it in a place where it has a 'clear line of sight' with the player. Should solve it!
Oct 06, 2010 | Samsung HT-WP38 Home Theater System System
My rear speakers are not working on my Samsung HT-TWZ412 home theater system. The wirless module blue LED link light blinks when turned on but then goes to standby. Any suggestions?!?
Try resetting the system then place the wireless module in sight of the receiver. Once you establish a connection try moving the wireless module to your desired location.
Oct 23, 2009 | Audio Players & Recorders
How do i hook this up Samsung HT-WX70 Theater System with Wireless Speakers
1. Connect the front left, front right, center, and sub woofer speakers to the back of the home theater system.
2.
With the home theater system off, insert the TX card into the TX Card connection (WIRELESS) on the back of the home theater.
Important:
Make sure to insert the TX card with the slanted portion of the card facing left.
3. C
onnect the rear left and the rear right speakers to the back of the SWA-3000.
4.
Plug the power cord of the SWA-3000 into an electrical wall outlet, and then switch the power switch on the back of the SWA-3000 to [ON]
Hope this helps!
Jun 27, 2009 | Samsung HT-WX70 Theater System
Hi, I have Samsung HT-X50 connected with SWA-4000. It was working fine, then for somereason I had to remove and reinsert Tx card. After doing that SWA-4000 is not connecting to HT-X50. Blue light blinks...
You have to reset the connection:
With the home theater system off, press the 0-1-3-5 buttons in that order on the home theater's remote control.
Power on the home theater system.
With the wireless module on, press the [ID SET] button on the back of the wireless module for five seconds.
If your home theater continues to display rear check after you have tried the steps above, call Samsung Customer Care at 1-800-SAMSUNG (1-800-726-7864). Have your model number and serial number on hand to set up service.
Hope this helps!
Jun 09, 2009 | Samsung HT-TZ515T Theater System with...
My main unit will not connect to the rear unit
I had a similar problem but mine cut out intermittently.
First, check to make sure the speakers are plugged in solidly. I was plugged into an outlet with a fancy cover and it caused the connection to short out intermittently.
2. Make sure all your wires are securely attached to the receiver unit.
3. If that doesn't work, try turning off the wirless speakers and the Home Theater system and then turn on both of them.
If one of these doesn't work, Samsung has chat support available onlline.
Good Luck!
Mar 13, 2009 | Samsung HT-TZ512T Theater System with...
Installing Samsung HT-Z510 wireless speakers
I was able to solve the wireless speaker problem through unplugging all of the units and starting over. I need to have the signal go from the satelite box to the recioever then the TV in order to get home theater to work.
Jan 05, 2009 | Samsung HT-Z310T Theater System
Rear check message on HT-TXQ120 samsung home theatre
Looks like it is to do with the rear wireless speaker. Now, my problem is over. Its gone. I first turned the reciever on and then turned on the rear speaker wirel less on. No rear chk in problem now. Hope this helps. R.
Nov 19, 2008 | Samsung HT-TXQ120 Home Theater System...
Rear Wirelss speaker do not work
With the main unit turned off, press and hold [REMAIN] on the home theater's remote for 4 seconds. (The REMAIN button is directly under the 7 button). Once held down for 4 seconds, the Volume Indicator on the main unit will turn on for 1 second. Release the [REMAIN].
Press the [RESET] on the back of the Wireless Receiver 2-3 times. The Standby/On LED on the front of the Wireless Receiver will blink 3 times
Turn on the main unit. The Link LED on the wireless receiver will light up if process is done correctly. The front of the main unit will no longer say REAR CHK and the rear speakers should now function correctly.
Feb 24, 2008 | Samsung HT-WX70 Theater System
179 people viewed this question
Top Samsung Audio Players & Recorders Experts
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
