Question about Canon PIXMA MX340 Wireless Office All-in-One InkJet Printer
My mx340 only prints half or less than half a page and then it stops. Wifi connection to my lap top.
SOURCE: slow printing
I was having same problem, disabled bidirectional support. works fine
Posted on Mar 07, 2008
  • 18 Answers
Purchase a PCMCIA parallel port adapter. the USB to parallel adapters are a pain to set up and are flakey at best. The PC card adapter provides a native parallel port to laptops without one, and works perfectly in ALL cases, even with the scanner cartridge. In Vista, the printer may then be manually installed from its list of printers, and set to use the new LPT port.
Posted on Aug 20, 2009
  • 113 Answers
SOURCE: Printer stops printing half way through as page ge...
your printer exit sensor has mulfunction. it got be replace.
Posted on May 21, 2010
  • 4 Answers
SOURCE: My printer is not printing all the horizontal lines
First try to copy and if copy works fine, means the hardware is fine and issue with the driver.
Do right-click on printer icon and select delete.
Once deleted, run the installation disc and click on add a device, follow onscreen instructions to complete the installation. Open printers and faxes window and then do right click on printer icon and select properties, click on print test page.
Check if it prints fine, if yes try to print from other application. I hope it will work.
Posted on May 26, 2010
Testimonial: "thank you i still have issues i copied a picture and i stll had the problem white lines accross the entire page horizontally about 1 inch apart 11 of them"
  • 3 Answers
SOURCE: samsung clp-315 printer stops printing after half page
i have samsung colour printer. half page printing then stop the printer. after turn on the printer the balance page automatic take out
Posted on Jul 21, 2010
Prints half page
Printing half a page with an Inkjet machine is not normally a computer issue. So windows 10 would not normally have any effect on the printing for a printer that has been accepted by the Windows 10 Operating System. If there was an issue in the software it would be printing gibberish or not printing at all.
Printing half a page is quite possably something stuck in the printer stopping the ink from getting to that half a page if it is printing down once side but not the other.
Printing half a page being that the top half is printed but not the bottom half (Or the other way around) it could be an air bubble in the feed line which can be cleared with a printhead clean or two.
Printing half a line rather than a full line such as the top half of each letter is clear but the bottom half of each letter is not visable is a blocked printhead. A couple of printhead cleans can also fix this.
Also check to see if the printer is not confused and actually has empty cartridges even if the printer thinks they are full. Brother printers can easily get confused about ink levels. If the cartridges are actually empty, replace them and away it should go again.
Hope that helps
Mar 09, 2016 | Brother MFC-490cw All-In-One Inkjet...
Connectng pixma mx340 wifi to my tablet
You should have no problems as long as the tablet can see the printer's signals. If you need to you may also use a USB cable to connect them. But generally you should have no issues in connecting a tablet to a wireless printer.
Mar 17, 2014 | Canon PIXMA MX340 Wireless Office...
Printer prints 2-3 pages then stops.
Open the print queue in the system tray and look at the status of the stalled doc. try restarting the doc. If the printing is a large file it could be a memory problem. check device mgr (Ctrl Alt Del) to see memory usage
Nov 19, 2013 | Dell Computers & Internet
Half of my screen flickers into blank white depending on the position of my screen
http://www.youtube.com/user/LCDPARTS?v=bqzaI7fK-HA
this page has a tester and how to change screens in a lap top..
hopefully its just a bad connection or loose connection.
Mar 17, 2013 | HP Pavilion DV9700Z notebook PC
MX340 connected to mac is offline despite drivers, cable and wifi assistant update. I have set this up before with the cd sent information to print. I see the printer in my printer queue but it says...
Try plugging it in directly.
Sometimes the wifi printer has to be set up AFTER the hardwire setup.
If you are desparate, plug it in directly to your computer to get your job done and figure out the wifi later.
Feb 11, 2013 | Office Equipment & Supplies
It takes 7 and a half minute to print a page. What's wrong. HP Officejet Pro 8500 Premier
It takes 7 and a half minute to print a page....
Depends on many factors my friend:
if u print big amount of data (big color pictures) through wireless connection and the WiFi connection is weak, then it takes time to collect data, evtl. stopping data-transmissions and reconnecting takes awful periods. check ur WiFi connection.
try to connect through USB and test again.
If then printing is normal, ur WiFi is to check, change security evtl. or change location of the printer to strengthen WiFi connection,
good luck
Ganimidis
Mar 04, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
My Canon MX340 is all set up wirelessly and has the blue light on. But when I try to print something from Word is shows that the printer is not responding. I know it prints because I used it to copy...
You MUST put in the password of the router in or it will never connect. Pressing a number key several times quickly should change the number to letters.
May 16, 2017 | Canon PIXMA MX340 Wireless Office...
CAn u help? The wifi on the lap top has stopped
check the drvier stats of the wifi is it there or not
Sep 02, 2009 | Famous Brand Notebook
Last page of printing stops 3/4 through the page.
Try cleaning your heads with appropriate solution. Then, cancel all print jobs. Try again. If it does the same i would turn it off, inplug all the cables, replug all and turn on. Try again. If still no good, completely unistall printer then reinstall it. Try once more. Good luck
Jan 16, 2007 | HP PSC 2175 All-In-One InkJet Printer
Canon PIXMA MX340 Wireless Office All-in-One InkJet Printer Logo
121 people viewed this question
old marine
old marine
