Question about Philips Televison & Video
My plasma TV won't turn on. It worked just fine last night and has never shown signs of trouble. Are there common issues I should consider?
  • Philips Master
  • 6,993 Answers
The issue you describe is consistent with a power supply board issue. This is the board where the AC goes to. This problem may have occurred as a result of irregular power supply, or excess power supply or power surge.
The TV is receiving current but cannot circulate or transfer the current to other necessary part of the TV because of the defective power supply board.
I do not think it needs replacement, rather some defective capacitors are causing this issue.
Open unit up and take a look at the power supply board.You will probably see one or more electrolytic filter capacitors that are bulged up in the top-not perfectly flat like the others.
The value of these capacitors will be different, most likely they will be somewhere around-820 to 2200uF/25 V( or /10V sometimes)
You can replace them with same values but I would recommend the voltage rating to be higher(like 35V for an original 25V) for reliability purposes.
What happens is,these bulged top capacitors will cause a low and unfiltered DC voltage=main board will malfunction(the relay will keep clicking until the caps are holding enough charge to bring the voltage up over a threshold point).
You can buy these capacitors at any Fry's or Radioshack store or you can order them online at vendors like "mcmelectronics.com"(look for electrolytic capacitors).
After replacing these capacitor(capacitors) most likely the normal operation will be restored.
Note: There may be also some other causes for this symptom ,like a defective T con board ,or main board,but the bulged top capacitors are the most common cause for this issue.
If you don't know about TV repairers, take the TV to the nearest repairman to fix the fault for you. Also, note that TV stores a lot of current, so wait a while before opening the TV back cover.
I hope this helps.
Good luck.
Posted on Mar 21, 2011
Testimonial: "WOW, never knew that there was such a valuable resource of knowledge and advice available....THANK YOU!!!!!!!"
50" Philips Plasma 50pfp5332D/37 won't turn on
I have a 42in vizio led with about the same problem i replaced a 75 cent chip # u33 on computer board problem fixed.
Sep 25, 2012 | Philips 50PFP5332 50" 1366 x 768 Plasma...
Hi my 32in lg plasma was workin last night now wont turn on
this is the ysus board u can replace for around 100£
easy if u have a screwdriver and patients,,
and make shure the tvs switched off for a day before u replace board ,,
replacement type this in on ebay..
6871QYH053B
theres one guy on there 64.99 and 12£ swop your old one for this,,
i tend to replace the hybrid chip myself ,, but this guy has loads no its not me,,i dont have the time,i own my own tv repair business, so, hope this helps.
May 21, 2010 | LG 42PX5D 42 in. Plasma HDTV
I have a TH42PA50A plasma panasonic, it was working fine last night but when I go to turn it on this morning all that happens is the red light flashes and nothing. Please help
Right now the TV is in " Protection Mode " and the blinking red light is a trouble code.
Try leaving the TV unpluggeds for 30 minutes, that way the TV can reset itself.
If that doesn't work, most likely the TV has a power supply related problem. The most common thing to go out is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board.
But, I can't say it's 100% the problem because I can't actually look at the tv over the internet.
If by chance the TV is still under warranty, go that route.
If not under warranty and If you have some electronic experience, if you can find and purchase a Service Manual over the internet; It will help you diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you red light blinking codes, circuit diagrams, test points, and part# lists. Usually, cost under $20. And most cases the new part cost less than $15.
I hope I shed some light on the subject for you.
Jul 05, 2009 | Panasonic Televison & Video
Black 3" vertical line through the center of my Plasma TV
Sounds to me like one of the drivers for the display died. Typically this requires a replacement of the entire panel (expensive) but I'd check with your local repair shop
May 04, 2009 | Panasonic Viera TH-50PZ80U Plasma TV
Power Issue 42" plasma flat HDTV Pixel Plus
you ip board is bad go t0 this site partstore.com typ in the modle of tv and buy it . works like brand new .trust mr it did and saved a lot
Apr 07, 2009 | Samsung SPN4235 42 in. Plasma HDTV
My brand new tv lost the picture last night.
This commonly happens when the power inverter board goes out. It powers the LCD or PLASMA screen.
It's a common problem for all brands of TVs. Mine was brand new and it lasted for 4 months until I had the power inverter board replaced.That was back in Nov of '08. And it's still working today.
If you have the warranty, use it. The board itself cost between $75-$250, depending on the size of the screen.
I hope I answered your question. Please rate me. :)
Mar 20, 2009 | Sanyo Televison & Video
Picture issue
It's not the TV it's the source( check settings in your DVD player or cable box
Nov 22, 2007 | Hitachi 55HDS69 55 in. Plasma Television
PIONEER PLASMA NOT TURNING ON
common problem power supply need replacement
Oct 25, 2007 | SVA-USA HD4208TIII-VR 42 in. Plasma...
Televison & Video Logo
239 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
