It will not turn it the light flashes and still will not come on
  • 6,993 Answers
Hi.
The issue you describe is consistent with a power supply board issue. This is the board where the AC goes to. This problem may have occurred as a result of irregular power supply, or excess power supply or power surge.
The TV is receiving current but cannot circulate or transfer the current to other necessary part of the TV because of the defective power supply board.
I do not think it needs replacement, rather some defective capacitors are causing this issue.
Open unit up and take a look at the power supply board.You will probably see one or more electrolytic filter capacitors that are bulged up in the top-not perfectly flat like the others.
The value of these capacitors will be different, most likely they will be somewhere around-820 to 2200uF/25 V( or /10V sometimes)
You can replace them with same values but I would recommend the voltage rating to be higher(like 35V for an original 25V) for reliability purposes.
What happens is,these bulged top capacitors will cause a low and unfiltered DC voltage=main board will malfunction(the relay will keep clicking until the caps are holding enough charge to bring the voltage up over a threshold point).
You can buy these capacitors at any Fry's or Radioshack store or you can order them online at vendors like "mcmelectronics.com"(look for electrolytic capacitors).
After replacing these capacitor(capacitors) most likely the normal operation will be restored.
Note: There may be also some other causes for this symptom ,like a defective T con board ,or main board,but the bulged top capacitors are the most common cause for this issue.
If you don't know about TV repairers, take the TV to the nearest repairman to fix the fault for you. Also, note that TV stores a lot of current, so wait a while before opening the TV back cover.
I hope this helps.
Good luck.
Posted on Mar 21, 2011
2001 tp cruiser turn signals wont flash
check the flasher relays in the fuse box. these are what causes the lights to flash.
Feb 11, 2014 | Chrysler Cars & Trucks
Tv will not turn on, red flashing light comes then turns off
tv will not turn on, red flashing light comes then turns off.
light flashes six times.
Aug 15, 2012 | Sony KP-53HS30 53" Rear Projection...
2000 Hyundai tiburon all lights flash when turn
The new marker turn signal lights came with 1 element bulbs and the tiburon takes dual element bulbs . Problem fixed.Cant believe they came that way from the dealer.
Feb 05, 2010 | Hyundai Motor 2000 Tiburon
Dasboard lights flash and warning beep operates (Seat Leon 2001)
flashing dashboard lights when the ignition is turned off
Dec 01, 2009 | 2001 Volkswagen Golf
Manual light & exposure settings
if you are using flash lights on the art work, please follow the following steps
  1. turn off your flash in cam since it bypasses the external flash and makes the picture look different.
  2. turn your light settings to either automatic or "flash light or arc light".but do not set them to incandescent light!!!
  3. turn your macro to on status if you are going to take a close up shots, but please note that close up shots work great in natural sunlight than at flash lights...
Sep 13, 2009 | Fuji FinePix S2000hd Digital Camera
Land Cruiser (2006)Emergency Flashing Lights will not turn off
Unplug the battery fr 15 minutes then that should reset your computer
May 16, 2009 | 1999 Toyota Land Cruiser
Light flashing and tv won't turn on
you might want to have the power transformer checked to make sure its working correctly.sometimes when they go bad all you get is the flashing light
Oct 22, 2008 | Mitsubishi WS-55513 55" Rear Projection...
I can't remember how to turn the flash back on to auto flash?
  folloe these steps
camera<settings <Flash< turn it on .    or camera<more<flash<turn it on
Oct 16, 2007 | Sony Ericsson K750i Cellular Phone
Televison & Video Logo
16 people viewed this question
Top Televison & Video Experts
