Question about Sanyo VPC-E760 Digital Camera
Lens Errors 17 & 27 on Sanyo VPC-E760
Can view pics but if turn to setting to take pics it gives the 2 lens errors & shuts off. Also lens stays fully extended all the time - does not go in when turned off.l
  • 4 more comments
  • applestycx Oct 05, 2008
    I am able to view my pics. but unable to replay videos taken- it skips along really slow. When I turn it to take a pic, it gives 2 lens errors and shuts off. Also, lens is staying fully extended.
  • ajac0288 Oct 12, 2008
    It will not take photos or the lens will not go back in
  • c_dsmith5119 Oct 25, 2008
    I turn on my camera and I can view the pic's but when I try to take a pic it say lens error 12 and 25 but my len's will not open, Someone PLEASE help
  • Anonymous Jan 11, 2009
    When trying to turn camera on to take pics, I get errors 17 & 27. I can view my pics, just not take any new ones.
  • sorty23 Mar 12, 2009
    i have a sanyo vpc-e760 pink camera. 6 months after i got it i dropped it by acident and the lens zoomed in and wouldent go in. if you zoomed in to much it wold turn of and say lens error 17
    three months after that the lens finaly went in but then wouldent come oout. the only time it would turn on is when i had it on play back and would say a lens error.
    if i put it on any of the picture modes it would turn off and say another lens errors.
  • gracecollins Mar 31, 2009
    I can view the pictures, but when I try to take a picture, it says the lens errors 17 and 27 and turns off. I didn't drop it or anything, and I've tried to pop the lens back in several times.
My camera was showing lens error 12&25 and then shutting off. I tried gently trying to twist and pull the furthest out part of the lens and it popped back into place easily. It made a noise when it did this, and then i turned the camera off, and the lens went back in!! Completely fixed now!!
Posted on Oct 05, 2008
Lens 21 error vpc-e760
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Feb 18, 2011 | Sanyo VPC-E760 Digital Camera
Lens erros 27 and 12
i have the same problem...
Sep 19, 2009 | Sanyo VPC-E760 Digital Camera
Broken Lense
try these:-
  • connect it to pc and on it
  • vaccum the barrel of lens
  • changing mem. card and batt. for 2min.
  • shake it.
  • on and off in different positions
  • hit the part near lens softly with palm (trust me this made mine work)
May 30, 2009 | Sanyo VPC-E760 Digital Camera
Lens error 22 or 25
This is probably THE single most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
May 29, 2009 | Sanyo VPC-E760 Digital Camera
Lens error:21/16 on my sanyo vpc-e870
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Apr 11, 2009 | Sanyo VPC-E760 Digital Camera
My sanyo vpc-e760 digital camera is showing lens error:22 what do i do
well i have a SANYO camera and every time i cut it on it cuts on a little bit and i see it and it sais lens error: 308 what does that mean?
Oct 08, 2008 | Sanyo VPC-E760 Digital Camera
Problem with sanyo VPC E760
i bought a sanyo vpce760 and one day i just turned it on but the lens dont come out. i can only look at pictures but i cant take pictures.
Jul 14, 2008 | Sanyo Xacti VPC-S60 Digital Camera
My sanyo camera is not working
Well maybe I can solve this..... My lens would not retract and showed two error messages. Tried a number of tricks that have been recommended on this site to no avail. Ultimately what worked for me was pushing quite hard on the barrel of the lens trying to force it back in ( yeah i know, sounds extreme but did'n't think it could make the situation any worse ). The lens remained in the locked out position not moving in spite of the fact that I pushed it fairly hard. When I turned it on the lens retracted and it appears to be fully recovered from whatever was ailing it. Hope this works for you.
Jun 09, 2008 | Sanyo VPC-E760 Digital Camera
Lens error
Hey jennbrady24,
What is most likely causing the lens error is that something is obstructing the movement of the lens (i.e. sand). I would first try removing the batteries and the memory card and waiting at least 2 minutes and then reinserting them. If this doesn't work I would then try blowing compressed air into the lens to try and dislodge whatever is causing the lens to stop moving. If this doesn't work I would try placing the camera on a flat surface with the lens pointed upwards, then press and hold the shutter button while you turn the camera on. If none of these options work I would have it looked at by an authorized service technician. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Jun 04, 2008 | Cameras
Sanyo vpc-e760 camera lens error 41
dudeee. totally have the same problem cept mine stays fully zoomed then when i try to zoom more it says lens error 41 and turns off and the lens doesnt go in
Mar 04, 2008 | Cameras
Sanyo VPC-E760 Digital Camera Logo
291 people viewed this question
Top Sanyo Cameras Experts
ray gallant
Are you a Sanyo Camera Expert? Answer questions, earn points and help others
