Question about Alpine Air XL-15 Air Purifier
How do I put in the light bulb in a Fresh Aire model?
    Brigadier General:
  • 4,736 Answers
According to Alpine Air, if the light bulb is one that indicates how it's function operation, there is no need to replace it, if the unit is working properly. The specific model you have is over ten years old and is not repairable. At least, not by Alpine Air. For more information and how to contact Customer and Technical Service, click on the following link. http://www.alpineairtechnologies.com/?gclid=CISY_5SR4acCFZIK5Qod7GEu-Q
Posted on Mar 22, 2011
Fresh air 2, blue light goes out, fan still works, reads
If the light goes out, it is time to replace the bulb AND the bulb starter. They need to be replaced every two years. Beyond that, they are an expensive night light. If you need to order one, call (336) 499-2505. Also ask for supplemental cleaning instructions since the original instructions are incomplete.
Jun 10, 2012 | Ecoquest Fresh Air Air Purifier
What does a green blinking light mean on my eco box? Also when cleaning the unit, which way does the metal plate face? Does the metal plate face towards the outside or the center of the unit. I'm...
When the green LED starts to blink, means that there is a bulb failure in the RCI module. It typically glows greenish blue when it working. Check the connector to see if it is seated properly, and also check the power connector for problems. I had a problem with the power connect not making a good contact and it caused the power to be intermittent. I was able to clean the connector with a can of electrical contact cleaner from Radio Shack to fix this problem. If you can't get the bulb to light, you will need a new RCI module.
As for the purification plate, the one that shaped like a tongue depressor, it does not matter which way it go back in to the unit. You should be able to get parts from your dealer or you can call the company at 800 989 2299. Hope this helps.
Jun 04, 2010 | Ecoquest Fresh Air Air Purifier
Living Air Model XL-15C: the red-neon FT ionizer bulb does light.
Corrosion in the cicuitry at the connection are unseen until you take them apart, can cause this. The male and female connectors might be together but rotted inside the boots unseen and not connected. That happens sometimes. Gently pull those connections apart and look inside both connection areas and check.
Apr 28, 2010 | Ecoquest Fresh Air Air Purifier
The blue light of my EcoQuest Fresh Air Purifier flashes
The UV light is a Flourescent like bulb. It has a starter. The starter and bulb can be bought on Ebay for about $20. It is easy to replace.
Mar 31, 2010 | Ecoquest Fresh Air Air Purifier
Flashing UV light
I would jump out on Ebay and get a bulb and starter for around $20-25. Easy to install!
Mar 23, 2010 | Ecoquest Fresh Air Air Purifier
I HAVE THE FRESH AIRE MODEL JUST REPLACED rci CELL CLEANED FILTER AND CLEANED THE OZONE PLATE. THE FAN KEEPS TURNING ON AND OFF?? STARTS RIGHT BACK UP ON ITS OWN AND THROWS NO EROR MESSAGES??
The main circuit board is probably bad. It seems Ecoquest installed a number of them that have a problem. If the machine is under warranty, they will replace it if you pay shipping. Otherwise, you'll have to pay the whole bill. Either way, call first to get and RMA number.
Nov 23, 2009 | Ecoquest Air Purifiers
How do I change the light in my fresh air purifier
The light bulb is a tube style that clips in - - kind of like replacing a flourescent light bulb T-8, T-10 style. Try rotating it so that the end pins align themselves properly for removal. Simple !!
Oct 08, 2009 | Ecoquest Fresh Air Air Purifier
Lamp replacement???
Make sure the lamp is seated properly. Take it out, put it back in, turning it back and forth until it clicks. DO NOT TOUCH with your bare fingers.
May also need to replace the starter (the aluminum can at the rear of the unit).
Jan 20, 2008 | Ecoquest Fresh Air Air Purifier
Fresh-air purifier does not geenerate ozone
The fan is bad it should blow the fuse, I believe that the mother board has a problem, or the Display board may have gone bad.
Nov 04, 2007 | Ecoquest Fresh Air Air Purifier
Ionizer
IONIZERS to not PURIFY indoor air. IONS are either NEGATIVE or POSITIVE. In this case, the NEGATIVE IONS are the 'GOOD GUYS!"
An ionizer will usually put some negative ions into the air while trapping, just like positive/negative magnets would do- SOME of your airborne live contaminates onto a metal plate inside the ionizer. When you pull out the plate with this smorgasborg of contaminates to wipe it, some of them can go airborne again, plus you have a dirty cloth ripe with contaminates on which you should then throw away. You haven't PURIFIED your air-you've just added some negative ions to your air, which will make your air feel light and lively- but still not PURIFIED.
Our SUN AIRE purifiers not only PURIFY indoor air SAFELY and EFFECTIVELY like SUNLIGHT, but one of the side-benefits is that we replenish your NEGATIVE ION balance in your air because of our SUNLIGHT process of purifying your air.
We DO NOT LIVE in our ductwork, therefore, our SUN AIRE purifiers purify your air in your living spaces FIRST and then the allotropic oxygen can be sucked through your ductwork.
POINT-OF-CONTACT is the key to our SUN AIRE purifiers effectiveness. We recommend you place your SUN AIRE purifier as FAR AWAY from your cold air return as possible because we want you to use the allotropic oxygen FIRST, before it's sucked through your ductwork.
Thanks for your question. Please let us know if we may assist you.
www.betterair.com
Oct 04, 2007 | Sun Aire Sun-Aire Air Purifier - Stainless...
Alpine Air XL-15 Air Purifier Logo
101 people viewed this question
Top Alpine Air Air Purifiers Experts
Jerry Greenberg
Jerry Greenberg
Tom Chichester
Are you an Alpine Air Air Purifier Expert? Answer questions, earn points and help others
