Question about Samsung HLN5065W 50" Rear Projection HDTV-Ready Television
I have a 50' projection samsung and it got hit by lightning and now it wont turn on and we bought a power cable to start somewhere trying to fix it and that dont work and we know there is a way but any solutions that might solve the power problem?
  • Samsung Master
  • 6,993 Answers
The issue you describe is consistent with a power supply board issue. This is the board where the AC goes to. This problem may have occurred as a result of irregular power supply, or excess power supply or power surge.
The TV is receiving current but cannot circulate or transfer the current to other necessary part of the TV because of the defective power supply board.
I do not think it needs replacement, rather some defective capacitors are causing this issue.
Open unit up and take a look at the power supply board.You will probably see one or more electrolytic filter capacitors that are bulged up in the top-not perfectly flat like the others.
The value of these capacitors will be different, most likely they will be somewhere around-820 to 2200uF/25 V( or /10V sometimes)
You can replace them with same values but I would recommend the voltage rating to be higher(like 35V for an original 25V) for reliability purposes.
What happens is,these bulged top capacitors will cause a low and unfiltered DC voltage=main board will malfunction(the relay will keep clicking until the caps are holding enough charge to bring the voltage up over a threshold point).
You can buy these capacitors at any Fry's or Radioshack store or you can order them online at vendors like "mcmelectronics.com"(look for electrolytic capacitors).
After replacing these capacitor(capacitors) most likely the normal operation will be restored.
Note: There may be also some other causes for this symptom ,like a defective T con board ,or main board,but the bulged top capacitors are the most common cause for this issue.
If you don't know about TV repairers, take the TV to the nearest repairman to fix the fault for you. Also, note that TV stores a lot of current, so wait a while before opening the TV back cover.
I hope this helps.
Take care.
Posted on Mar 21, 2011
I have a Samsung Plasma tv (PN59D8000FFXZA) that after my neighbors house was struck by lightning it won't turn on. What steps should I take for diagnosing the root issue?
When it get hit with any surge usually the main Board is gone, to replace it and hope nothing else is wrong, you can get a 4k LED for probably same price
Amazon com 4k smart tv 50 inch Electronics
Jun 17, 2016 | Samsung Televison & Video
Samsung tv lightning
If lightning knocked it out warranty should cover it.
Oct 04, 2013 | Samsung Televison & Video
Sony wega kdf-e50a10 hit by lightning now it will not turn
follow the power cord and just check the input fuse if you've got a surge protector on it it may have just blown the fuse from a spike. It doesn't hurt to try. This fuse is inside the tv.
Sep 15, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
My Toshiba 50 inch projection screen TV isnt displaying
If you are capable of some basic troubleshooting you can determine what's wrong but you won't likely be able to fix it yourself. If you remove the TV's back panel, you can locate three plug connectors for the convergence correction yokes. You pull the red, blue, and green connectors and then plug the TV back in and hit the power button. If the TV comes on, its a failure of the convergence output ICs and will cost $350-450 if you call in a service company.
michtech
Feb 14, 2009 | Toshiba TP50G60 50" Rear Projection...
Dark Picture
Symptom: NO PICTURE
Cause: DEFECTIVE 3D/YC COMB FILTER
Symptom: DARK PICTURE
Cause: DEFECTIVE C724
Jan 16, 2008 | Hitachi 50SBX70B 50" Rear Projection...
Hitachi 51F510 HDTV Hit by lightning
The steps that need to be taken on fixing this set start with the standby voltage requirement. Is it there? next is the low voltage loop from the transformer, also a requirement for the set to come on. ...accordianman
Nov 19, 2007 | Hitachi 51F510 51" Rear Projection...
Samsung HLN5065W 50" Rear Projection HDTV-Ready Television Logo
111 people viewed this question
Jerry Greenberg
Jerry Greenberg
