Question about Panasonic Viera TH-50PZ85U Plasma TV
Tv won't turn on red light flashes 10 times then pauses
  • Panasonic Master
  • 6,993 Answers
The issue you describe is consistent with a power supply board issue. This is the board where the AC goes to. This problem may have occurred as a result of irregular power supply, or excess power supply or power surge.
The TV is receiving current but cannot circulate or transfer the current to other necessary part of the TV because of the defective power supply board.
I do not think it needs replacement, rather some defective capacitors are causing this issue.
Open unit up and take a look at the power supply board.You will probably see one or more electrolytic filter capacitors that are bulged up in the top-not perfectly flat like the others.
The value of these capacitors will be different, most likely they will be somewhere around-820 to 2200uF/25 V( or /10V sometimes)
You can replace them with same values but I would recommend the voltage rating to be higher(like 35V for an original 25V) for reliability purposes.
What happens is,these bulged top capacitors will cause a low and unfiltered DC voltage=main board will malfunction(the relay will keep clicking until the caps are holding enough charge to bring the voltage up over a threshold point).
You can buy these capacitors at any Fry's or Radioshack store or you can order them online at vendors like "mcmelectronics.com"(look for electrolytic capacitors).
After replacing these capacitor(capacitors) most likely the normal operation will be restored.
Note: There may be also some other causes for this symptom ,like a defective T con board ,or main board,but the bulged top capacitors are the most common cause for this issue.
If you don't know about TV repairers, take the TV to the nearest repairman to fix the fault for you. Also, note that TV stores a lot of current, so wait a while before opening the TV back cover.
I hope this helps.
Good luck....
Posted on Mar 21, 2011
My panasonic plasma hd tv red light flashes 10 times and will not come on
Check its fan SOS board for fault. Visit this site for more details. Pull up older posts. Blinking codes to Panasonic Plasmas are given in detail.
Mar 31, 2013 | Televison & Video
Set won't turn on, 10 red flashing lights
This is an error code and depending on brand/model number can have a number of meanings---
You can GOOGLE the model number with "error codes" etc to get an idea of what likely your error code means.
Mar 19, 2012 | Televison & Video
50 inch Panisonic TH-50PZ85U, wont turn on and has red light flashing 10 times
thats usually caused by a blown thermal fuse on the transformer and the 10 blinks appears. I can assist but will need to do it via email you can contact me at slinteriors@yahoo.com
Mar 19, 2012 | Panasonic TH Televison & Video
The fan dont turn on when i turn on the tv and the red light is flashing
Red light flashing on tv indicates that tv got some problem and shifted to protection mode to avoid further damage.
If Lamp light is flashing on tv then check lamp that would be dead or broke, replace lamp to solve tv problem.
If standby red light is flashing on tv then let me know how many times it is flashing after 3 seconds long pause to provide you helpful info.
Thanks.
Jan 22, 2011 | Sony KDF-E55A20 55 in. LCD Television
Panasonic pt47wx52cf tv shut off and wont turn
Please count red light flashes and let me know. There would be long pause between flashes so count pause to pause. It is an error code of TV problem.
May 18, 2009 | Panasonic Televison & Video
Sony KV34XBR800 Red Flashing Standby Light No Power
The red light should be blinking a code. For example it will blink 4 times pause then 4 times pause or 5times pause 5 times pause, whatever the error might be. Let me know what it is and then we can help more.
Tim
Experttv@comcast.net
Sep 07, 2008 | Sony BRAVIA KDL-40V3000 Television
Please Help
Is the red light flashing a code ? exaple 4 blinks pause 4 blinks ?
Apr 07, 2007 | Sony KV-27FV16 TV
Panasonic Viera TH-50PZ85U Plasma TV Logo
259 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
