Question about Philips Magnavox MS3652S 36" TV
Magnavox pr1902 c125 turn it on and it turn off again keeps doing it now wont stay on clicks on and then ya hear a relay click off off it goes again
    Genius:
  • 1,114 Answers
You have a faulty power supply, and it needs to be replaced. The estimated cost of repair is 175-300 dollars.
Posted on Mar 21, 2011
`2005 Acura RL randomly wont start , key -on all works key to start -nothing dash lights stay on . even w/jump. Power start, sol. ,, starts right up . Next time you turn key=yes -no ? ? ?
lister for a clicking from the start motor you may need some to help you. if you or your friend hear the click on the starter motor then the motor and it does not turn the engine or goes crunch like its engaged but does not turn,It will need replacing or fixing, if no click this could be the starter relay or the ignition switch or you have a lose wire tot he relay.
Jul 11, 2017 | Acura Cars & Trucks
Mitsubishi Medallion does this
hi there,
Check for bad solder on convergence module. May have bad stk's. Do not neglect looking for bad solder on dsignal and defl boards. Mitsubishi is very prone to bad solder.
`jack
May 26, 2008 | Mitsubishi WS-55411 55" Rear Projection...
Magnavox PS1955 C125 TV universal remote codes. I need these for a Mediacom digital converter box remote programming. Thanks.
Visit this site for more details. Type in the site name Electro-help either to Google or Yahoo search box [not in the address bar of your browser], and click search. It is an electronic equipments service help site. All details you want are there. Note the position of hyphen in between words in site name, when you type it in. The site will appear as it is in web; subtitled as electronics equipments' repair help.
Check this site. It have the code list for most brands converter boxes.
May 16, 2012 | Televison & Video
Philips Magnavox 32MT3305 keeps shutting off with relay clicking. The green power light stays on but the picture and sound go out right after the orange status bar goes away. If the channel up or down...
the relay is the safety protective device..sometimes a defective component or something. maybe an overloaded power supply might caused this problem..so before any thing could gets worst..the relay will shut the unit..
Jul 18, 2011 | Philips 32MT3305 TV
Jeep wont start, engine goes to turn over but wont go all the way
Ok...what you need to determine next is if the fuel pump is operating. Turn the key to the on position and have someone listen at the tank. If you can't hear it, it's not on. (that can be pump relay, pump or sometimes asd relay) to quick check relays see if you can feel each click when the key is turned on. If you can get the pump to run by banging on the tank bottom go no further and replace the pump. Most relays are the exact same and can be interchanged as well (except abs relay)
If the pump is coming on the next item to check is the crank position sensor. You will need a digital multi-meter and a manual for the test, but if you shoot some carb cleaner into the intake and the engine starts (do while cranking) likely it is OK and then back to the pump or get a chiltons manual and a meter and do complete testing. Battery needs to be fully charged or any tests are invalid.
May 31, 2010 | 2001 Jeep Grand Cherokee
Head lights wont turn off 1999 avalon . running lights off but headlites stay on when key is off
You may have a siezed up head light relay, look in your user manul to locate the relay and tap it to see if it drops out. You should hear a click when you turn the head lights turn on and off.
If you pull the relay out while the lights are on, you should hear a click when the relay drops out, if you do then it is not the relay, it could be a switch
Feb 24, 2010 | 2004 Toyota Camry
No picture on my philips 42PF7321D/37
Bad caps in the power supply must be replaced .
Jul 21, 2009 | Philips 42PF7320A 42 in. Plasma HDTV
Startup Problem with my 42pf7321d/37 Phillips plasma TV
I need to know how long do you have the tv?In the other word,approx. how many hours you have put into it?
Secondly,did you wall mounted the tv or setting it close the the area which there is not much room for the back of your tv to breath?
solutiondoct
Nov 06, 2008 | Televison & Video
42pf9956/37 philps plasma
I don't know why but this got my TV on.
I took off the back cover and found the source of the clicking.
Two blue plastic rectangular relays in the exact middle.
When I pushed the power button, I felt the top relay click, and I saw a flash from the bottom one. (they are right next to each other)
I took a hair dryer and placed it over the two relays for about 1 minute and tried the power.
It clicked only 4 times and then came on!!!!!!!!!
For some reason heat helps the relay.
If anyone is a tech and can explain this, please do.
Good luck!!!!
My tv is on and it didn't cost me anything.
I just can't turn it off now!!!
Sep 25, 2007 | Philips Magnavox 42MF521D/37 Television
Philips Magnavox MS3652S 36" TV Logo
153 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
