Question about D-Link RangeBooster G WBR-2310 Wireless Router (WBR2310)
During the installation process the setup wizard is telling me no internet connection. I have internet connection through my cable modem. I have the ethernet cables hooked up right into the modem and router. I am able to access the internet. Just not able to continue in the configuration of router.
When I write my name and password it dosent continue
Posted on Mar 29, 2011
I cannot connect my Belkin 54g to the internet at all. I followed the wizard and got the information from my ISP - user name and password. The wireless light works, the port shows that it working but the...
ghost2233_6.jpg Did you connect the lan cable to the right port ????
1. Shut down any programs that are running on your computer at
this time.
2. Make sure you have the following items at the computer that is now
directly connected to the cable or DSL modem. DO NOT CONNECT THE
ROUTER AT THIS TIME.
• The Easy Install Wizard CD-ROM
• The Router
• The Router power supply
• Category 5 networking cable
• This Quick Installation Guide
3. Turn off any firewall or Internet connection sharing software on
your computer.
4. Insert the Easy Install Wizard software CD into your CD-ROM drive.
The Easy Install Wizard screen will automatically appear on your
screen within 15 seconds. If it does not, select your CD-ROM drive
from "My Computer" and double-click on the file named "Setup" on
the CD-ROM.
5. Turn on your cable or DSL modem by reconnecting the power supply to The Wizard will take you through the completion of the process.
the modem.
6. Before plugging the power cord into the Router, plug the cord into the
wall, then plug the cord into the Router's power jack.
7. Verify that your modem is connected to the Router by checking the
lights on the front of the Router. The green light labeled "WAN" should
be ON if your modem is connected correctly to the Router. If it is not,
recheck your connections.
8. Verify that your computer is connected properly to the Router by
checking the lights labeled "LAN 1,2,3,4". The light which corresponds
to the numbered port that you connected your computer to should
to the numbered port that you connected your computer to should be
ON if your computer is connected properly.
Good luck
Mar 12, 2011 | Gateway Belkin 54g Wireless DSL/Cable...
How to instal printer on dilink dir-888
i 1 D-Link DIR-855 User Manual 0
Section 2 - Installation
If you are connecting the router to a cable/DSL/satellite modem, please follow the steps below:
1. Place the router in an open and central location. Do not plug the power adapter into the router.
2. Turn the power off on your modem. If there is no on/off switch, then unplug the modem’s power adapter. Shut down your computer.
3. Unplug the Ethernet cable (that connects your computer to your modem) from your computer and place it into the Internet port on the router.
4. Plug an Ethernet cable into one of the four LAN ports on the router. Plug the other end into the Ethernet port on your computer.
5. Turn on or plug in your modem. Wait for the modem to boot (about 30 seconds).
6. Plug the power adapter to the router and connect to an outlet or power strip. Wait about 30 seconds for the router to boot.
7. Turn on your computer.
These instruction are on the CD that came with the router
Here is the start:
D-Link DIR-855 User Manual 13
The DIR-855 includes a Quick Router Setup Wizard CD. Follow the simple steps below to run the Setup Wizard to
guide you quickly through the installation process.
Insert the Quick Router Setup Wizard CD in the CD-ROM drive. The step-by-step instructions that follow are shown
in Windows® XP. The steps and screens are similar for the other Windows operating systems.
If the CD Autorun function does not automatically start on your computer, go to Start > Run. In the run box type
“D:\DIR855.exe” (where D: represents the drive letter of your CD-ROM drive).
When the autorun screen appears, click Install Router.
Section 3 - Configuration
Configuration
This section will show you how to configure your new D-Link wireless router using the web-based configuration utility.
Web-based Configuration Utility
To access the configuration utility, open a web-browser such as Internet Explorer and enter the IP address of the router (192.168.0.1).
Select Admin from the drop-down menu and then enter your password. Leave the password blank by default.
If you get a Page Cannot be Displayed error, please refer to the Troubleshooting section for assistance
Click Launch Internet Connection Setup Wizard to begin.
If you want to enter your settings without running the wizard, click Manual Configuration and skip to page 19.
follow the prompts.
You also can go to D-Iink.com for setup instructions
Apr 20, 2010 | D-Link DIR-855 Wireless Router
DIR-615 wireless router not installing
You setup the router with the Ethernet cable always plugged in.. UNTIL you are finished configuring through the Ethernet cable via your browser. Once WiFi SSID & passwords WEP/WAP has been finished, AND you had another WiFi card in that PC the Ethernet cable was also connected to... well, THEN, I guess THEN, you may be able to disconnect the router from PC & then connect it again Wirelessly. But whats the point? But until then you won't find your router ON the Ethernet port, it would then be trough the WiFi adapter.. and that would have to be activated to work. Hope this clears things up
Feb 02, 2010 | D-Link DIR-615 Wireless Router
How do I hook up a Berklin wireless router to my comcast internet
Use an Ethernet cable to connect the port on the Comcast modem to the WAN port on the Berklin (Belkin????) router.
Use another Ethernet cable to connect one of the LAN ports on the router to the Ethernet port on your computer.
Start Internet Explorer on your computer.
Connect to the web-interface inside the router.
Run the "network setup wizard".
Run the "wireless setup wizard".
Nov 17, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Hi, i have wnr2000 and am trying to set it up. i'm at the setup wizard which says that i already have a valid internet connection. what does this mean and what do i do next?
Basically you need to sign up with an Internet Service Provider in your area. The ISP will advise you the type in modem/Internet connection you need for their service (ie. DSL or cable) and advise you or provide you with a compatible DSL or cable modem. The ISP will provide an installation disc or instructions to configure the modem so it connects with their Internet server.
The modem is then connected to the wnr2000 router's Internet/WAN port with a LAN cable.
If you have already configured the modem and connected it to the wrn2000 router and the setup wizard has detected that you already have a valid Internet connection (it has detected your TCP/IP address which your Internet Service Provider has given you - this IP address is your unique network address - it is similar to your house address in your street, in your suburb, in your state, and in your country). Just click OK and continue with the setup.
Oct 30, 2009 | NetGear WNR2000 Wireless Router
Orange blink of death!!!
Hello houng_lee,
I have the exact same modem, if the modem/router light is blinking, that indicates a problem with the modem. You indicate that you have internet connectivety, so you should have modem light solid blue. When you look at the Wireless light it's probably off. Which means that at this point you have internet connectivety, you should put the cd in and run through the wireless connection wizard on the CD. It will check to see 1) if you have internet connection, 2) the type of connection you have (comcast) 3) if you have any wireless devices to be hooked up. 4) That all connections are working properly.
If you have a laptop that you want to connect to the wireless router, have it next to the router, so once you've finished setting up your Wireless security and issing a WEP number for local access, you can test your setting immediately with the Laptop. I always suggest that you create a WEP number for securty reason, If you perfer not to create a WEP number, and leave it as an open access (which is fine, and easier to setup) make sure that you shut off broadcasting, So your neigborhood doesn't jump online once they see an open access router.
If you've tried these steps let me know what problems your getting during the wizard setup. It will tell you if everything is setup correctly, or their is an error. Right now, I think the problem is your setup, and it's not communicating correctly. But, the wizard will tell you that as well.
Let me know,
Good Luck
Mark
Feb 17, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
Laptop doesnt find connection to cable modem
download setup wizard to find connection from windows
Feb 12, 2009 | Acer Aspire One PC Notebook
SETTING UP EASY INSTALL WIZARD - Belkin F5D7230-4
just type 192.168.2.1 into your browser and it will get you into the settings, just as a cd would but you still have to manually enter your settings with either way of setup.
Sep 06, 2008 | Belkin (F5D7230-4) Router (587009)
I cannot connect wirelessy to internet on my compaq pressario v6000. The orange wireless light is on and the internet connectivity icons in the task bar have a red cross on them. I have tried all options...
Part 1: Before You Start loadTOCNode(2, 'summary'); You need the following: • A broadband connection to the Internet and the appropriate hardware. For example, cable-based Internet access that uses a cable modem that is provided by your ISP. • The Microsoft Broadband Networking Setup CD-ROM. • The Microsoft MN-500 Wireless Base Station. • The Ethernet cable that came with your base station. • The AC power supply. • The blank floppy disk.Check the following: • On computers that are running Microsoft Windows 2000 or Microsoft Windows XP, you must be a member of the Administrators group to set up a network. If you cannot run Setup, click Log Off on the Start menu, press CTRL+ALT+DELETE, and then log on with as an administrator. • Turn off any firewall or Internet connection sharing software on your computers. Your base station replaces these functions. The Setup Wizard cannot continue if they are enabled. • Do you have a Point-to-Point Protocol over Ethernet (PPPoE) Internet connection or a static Internet Protocol (IP) address? The Setup Wizard prompts you to type your user name, password, and service name for a PPPoE connection. For a static IP address, you must have the IP, subnet, and ISP gateway addresses. If you have one of these types of connections, gather this information from your ISP.
Part 2: Install the Software and Connect the Hardware loadTOCNode(2, 'summary'); 1. Insert the wireless base station Setup CD-ROM into the CD-ROM drive. If the Setup Wizard does not start automatically, click Start, click My Computer, double-click the CD-ROM icon, and then double-click Setup or Setup.exe. 2. Follow the on-screen instructions to install the software. 3. In the second part of the installation, select the option to set up the wireless base station, and then continue through the rest of the Setup Wizard. 4. When the Setup Wizard instructs you to connect your wireless base station, position the wireless base station close to your modem and computer, and near the center of your intended network area. If you want to set up the wireless base station vertically, attach the included stand. 5. On the back of your computer, unplug the Ethernet cable that connects your computer to your broadband modem. Leave the other end of the cable plugged in to the modem. 6. Plug the cable in to the "To Modem" port on the back of the base station. The base station is now connected to your modem. 7. Plug one end of the blue Ethernet cable that came with your base station in to the Ethernet port that is labeled 1 on the back of the base station. Plug the other end into the Ethernet port on the back of your computer. This is the same port from which you just disconnected the modem cable.
Important The modem must use its original Ethernet cable or one of the same type to connect to the base station. 8. Plug one end of the power supply that came with your base station into the power jack on the back of the base station. Plug the other end into an electrical outlet. The power indicator light on the front of the base station should turn on. 9. Return to the Setup Wizard, click Next, and then go to Part 3 of this article.
Part 3: Configure the Base Station and Network Settings loadTOCNode(2, 'summary'); Continue to follow the instructions on the screen to configure your wireless network settings: 1. Setup prompts you to enable wireless security (WEP). Microsoft recommends that you enable WEP. 2. Setup prompts you to save your network settings to a floppy disk for use in later installations. A blank floppy disk is provided for this purpose. If you do not save to a disk, you receive a list of network settings to print or write down. 3. Click Finish to exit Setup, and then remove the Setup CD-ROM from the CD-ROM drive and the floppy disk from the floppy disk drive. You can use the same CD-ROM and floppy disk to set up additional computers on your network.
Part 4: Test Your Network loadTOCNode(2, 'summary'); 1. View the status of your network in the Broadband Network Utility (BNU). Make sure that you can see your base station and the computer that is connected to it in the BNU status screen: a. Click Start, point to All Programs, and then double-click Microsoft Broadband Network Utility. b. View the information on the Network Status screen. 2. If your broadband Internet connection is being shared through your wireless network, start your Web browser program, and then try to visit a Web site. If your network is working properly, you have access to the Internet from the computer you just set up.
Aug 21, 2008 | Computers & Internet
Internet connection
Ok I have done it a little different sometimes... try this approach... First connect up the DSL Modem to the PC via Ethernet.. Configure the modem from the PC using the Connect to the Internet Wizard... enter all ya ISP details Logon, Password etc. Once this is going OK.. Disconnect the Modem... and then connect it up to the "Router" using the "Uplink" port and when connect ya Modem to the router... then connect another Ethernet cable from Router to same port on ya PC. Then simply use the network setup Wizard to set up an Internet Connection and connect up via ya router thru ya modem... generally works for me....
Aug 31, 2007 | Dell TrueMobile 1184 Wireless Broadband...
D-Link RangeBooster G  WBR-2310 Wireless Router (WBR2310) Logo
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
