Question about Wacom (PTZ930AC) Graphic Tablet
Wacom Tablet overly sensitive
Hey, I have a Wacom tablet being used with Windows vista.
For the past 8 months or so, it has been running without any serious problems, but now all of a sudden, the tablet pressure has become WAY over-sensitive, as in, I can have the pen an inch off the tablet surface, and it will act like the pen is putting on full pressure, reggarless of the program I am using.
(ex, when I am on my desktop and I move the pen around, not touching the tablet, its like I am dragging the mouse around the screen, constanly holding down the left-click, or, in photoshop, it makes marks without the pen and tablet touching)
Also, when I AM touching the pen tip to the tablet's surface, it wont act like the typical singular-click the way it used to, if that helps.
I've tried re-booting, changing the driver, plugging and unpluging the tablet, and searched the internet for answers, but nothing seems to work.
Help please!!
  • 3 more comments
  • hgrande Aug 13, 2008
    I have had the same issue. I used the same tablet on my old laptop with windows Xp and it worked great, but after moving to a new machine eqipped with Vista, it is way too sensitive.
  • Anonymous Sep 10, 2008
    I have the same problem but just for the eraser. I have an Intuos 3 and use a Mac.
  • artgirl83 Sep 13, 2008
    Mine is doing the same thing. It selects everything without touching the actual tablet and paints in photoshop when I don't want it to. How do we solve this problem?
  • Anonymous Dec 05, 2008
    Same problem here. Graphire4 and Windows XP, pen just acts like it is pressed as soon as the tip is hovering close to tablet -> everything is just selected.... I'd think this is something what might be fixed just by setting different values for the pressurelimits, but where...
    The pen tablet properties, Tip Feel, setting that to Firm doesn't help me at all, still the pen just selects everything.
    There must be some way to enter completely different values for the pressure sensitivity.
    My tablet is almost unused, pen worked well for few months, but then I didn't use it for several months, and then when I tried, the problem just appeared. Of course I couldn't find the guarantee paper etc...
    Anyways, good product, if it just would work. I have also older product Artpad (10 yrs old or so) which still works very well.
  • amsearle Apr 29, 2009
    I have exactly the same issues, and they started pretty much from the offset, the pen selecting and painting when it is an inch off the tablet is especially frustrating. Yet setting the pen pressure to firm doesn't solve this only means I get random pressure when painting. A software buddy of mine thinks it may be a faulty magnet in the pen tip. I have updated drivers, re-installed everything. Am off to mail Wacom to see if they can suggest anything. Mine is still under guarantee. Will keep you posted.
I had the exact same problems with my graphire4 pen.
take a tool to remove the tip of the pen. just blow inside the pen, put the tip back and press it in back but not too hard. works like magic!
Posted on Jul 24, 2009
  • 2 more comments
  • sylvik Dec 22, 2010
    thank you! you are a cerative genious!!
    it resolves the problem .simple ,fast and easy solution!
  • shelly111473
    shelly111473 Apr 10, 2013
    marry me!
  • sophielolll3
    sophielolll3 Apr 11, 2013
    My Pen doesn't respond anymore!
  • Gelynn
    Gelynn Oct 26, 2017
    While my stylus wasn't giving me insanely full pressure, simply removing and replacing the nib helped with this odd pressure trailing I was getting. I must have gone crazy recently with putting too much pressure, because the nib almost felt stuck. Now it's behaving! Funny how simple fixes do the trick.
I had this same problem.
  • Unplug the tablet from USB.
  • lay the stylus on top of the stylus.
  • Plug in tablet.
I tried unpluging and restarting several times, but always had the stylus in my hand. this worked on the first try. Good luck.
Posted on Aug 05, 2009
Just been playing around and if you go into your Wacom Properties in Control Panel and turn your double click distance off or down to very low it stops!
Posted on Apr 29, 2009
Hi Everyone! here's my 2cents
i had this problem like everyone after not using the Wacom for a year or so..
after installing drivers. unplugging and plugging again.. with the pen on top of the surface - nothing worked.. i also removed the nozzle and replaced it, and it still worked very very strange..
i then started tapping the tip on the tablet like 10 times and it just started working, probably recalibrated the distance or something.
hope this works for you!
Posted on May 27, 2012
I had the same exact problem, but with a Graphire4 in Mac OSX. I downloaded the latest wacom driver and now it seems to work perfectly without so much as a reboot.
Posted on Sep 30, 2008
    New Friend:
I finally downloaded the full manual for my Intuos pen & touch (CTH-480) and found an interesting bit of text in several places. It states that the pen can be "aproximately" 14 mm (0.5 inches) and still move the cursor or recognize the switches on the pen.
There is an "About" button in the (Mac) prefs panel (Properties on Windows?). Clicking that brings up a 'normal' About window but there is a "Diagnose" button, also. Click that button and you can test all the functions of the pen/tablet, including how close to the surface the pen is when it becomes active. It may be helpful to tell Wacom what that distance is, however, I did not see any reference to allowable tolerances. Mine 'activated' at 19 mm! That's around 35% over the "14 mm" distance! :+(
Posted on May 18, 2014
I've had the same issue and tried all of the above to no avail. I have a way older Wacom Graphire 2 - and in desperation I called them today and they were incredibly helpful, didn't seem to care that my tablet was a dinosaur. Wacom said that there's a sensor inside the pen and if it receives rough treatment, maybe by dropping on the floor, the nib gets pushed into the sensor and it gets stuck on. Maybe not their exact words, but that's what's going on. I often kind of throw down my pen if the phone rings or something, have never been too careful with it...
The solution, the lady told me, is to remove the nib and let the pen sit for 24 hours in order to allow the sensor inside it to reset. This seems right because I have a spare pen and used that and it worked fine right off the bat, so it makes sense that the problem is with the pen itself. Then THAT pen started acting up, so I pulled the nib out and pushed it back in more gently and the issue disappeared again. Hope this helps... I'm on a Mac running OS X
Posted on Nov 12, 2013
  • 1 more comment
  • Sharon Kearney Nov 12, 2013
    just to add on - my second pen is still acting up, maybe i have a bad one as i bought it used - but i'm noticing for sure, how far the nib is pushed in, affects how the pen behaves, if someone needs a quick fix
  • Sharon Kearney Nov 18, 2013
    Update again - taking out the nib and letting the pen sit for 24 hours totally worked
  • Sharon Kearney Jan 27, 2014
    Update again - this time the problem reappeared and taking the nib out didn't work. But taking the nib out and putting it back in and not pushing it in so hard did. Sometimes I had to do it a few times. Seems like this issue is definitely related to the sensor inside the pen, although why it happens I don't know as the last time the pen acted up I hadn't handled it roughly. Very frustrating!
I also had this problem. Then I tried changing the frimness of the pen, and now it works perfectly fine.
Go to Pen Tablet preferences, then in the Pen tab, change the softness scale to "Firm" then it should be fine.
Posted on Nov 02, 2008
I am also having this problem. I started doing it radomly, after a couple of weeks it did it all the time - I use the tablet in my office at work and the it has done nothing to fix the problem so I don't know if re-installing the software will help. My supervisor finally used her company card to purchase a new pen online, but that one only worked for a few weeks before the problem came back I'm now onto my 3rd pen. wtf?
Posted on Sep 13, 2010
  • JoMaJo May 27, 2012
    Hey friend!
    you may want to try and tap a number of times on the tablet with the tip.. it worked for me
I had this same problem (on Windows XP) and couldn't fix it with settings or an updated driver. I used a borrowed pen from another tablet, and the problem went away. Try replacing the pen if that's an option for you!
Posted on Mar 12, 2009
Touch sensitivity not working in my pen.
Reasons Why PEN PRESSURE Isn't Working (Viewer ...
? 4:04
https://www.youtube.com/watch?v=lHPRyDgGErY
Feb 1, 2015 - Uploaded by Aaron Rutten
I recently got a new tablet because my old one was broken. ....you find that you have lost pen tablet pressure sensitivity this will fix the problem: ...
pressure sensitivity of Wacom tablet not working anymore - Adobe ...
https://forums.adobe.com/thread/1152988?tstart=0
Adobe Systems
Oct 9, 2015 - 40 posts - ‎26 authors
I have no idea why, but the pressure sensitivity of my tablet won't work anymore. ...The tablet and pen are working within Windows. ..... Control Panel >Pen and Touch > Press and Hold then disabled the check-box Enable ... Wacom pen pressure issue, possible solution. ' Adobe ...
Dec 17, 2015
tablet + pen pressure + illustrator CS5 issue ' Adobe ...
Nov 27, 2015
Bamboo Pen Pressure not working in Illustrator ...
Feb 6, 2013
More results from forums.adobe.com
Why isn't my pen pressure sensitivity working? ' Wacom
Jan 19, 2016 | Genius Computers & Internet
Wacom tablet stopped working, blue light on.
Since you are running Windows Vista on your PC this is the driver you should have downloaded.
Click Here
Serial cables are not hot swappable. The computer and tablet should be turned off before you plug them in.
Apr 10, 2008 | Wacom (PTZ930AC) Graphic Tablet
I am trying to get my CTL-460 Wacom Bamboo Pen Tablet to work on my new computer, a Toshiba Satellite, which uses Windows 8. I have attempted to download the drivers multiple times, including from the
When loading the latest driver for it from Wacoms site, be sure to change the compatibility on the EXE file to "Windows 7". If that doesn't work, you will need to look at purchasing a newer model. The CTL-460 Wacom Bamboo Pen Tablet was only compatible with XP and Windows 7. Newer Microsoft operating systems are not supported on that product from Wacom.
Nov 29, 2017 | Wacom Bamboo Pen Black (CTL460)
Unresponsive tablet and tablet pen
I would try loading a Linux operating system on a flash drive and see if it worked on that. Vista is unsafe to use on the internet, anyhow.
Apr 06, 2017 | Wacom Bamboo Fun 5.8" x 3.7" USB Tablet...
Wacom tablet (Model ET-0405-U) Driver?
Wacom tablet drivers can be found at: Driver Update Software for XP Vista 7 8. Used it many times before. have a nice day
Oct 03, 2009 | Wacom Graphire Grape (ET0405UGRAPE)...
Hi everyone, I have a Lenovo w700 with a built-in wacom tablet running Vista. http://gizmodo.com/5035828/lenovo-thinkpad-w700-has-a-built+in-wacom-tablet-and-professional-grade-screen The issue I have...
The tablet is not a touch-resistive tablet. It's actually using magnets to detect the pen (you can't really use other pens with it). It will always detect it when you hover because that's how it works.
Sep 02, 2009 | Lenovo ThinkPad W700 17.0" widescreen with...
Pen pressure not working on adobe cs3
Download the latest driver of you tablet. Wacom updates the tablet drivers every now and then.
Jul 23, 2009 | Computers & Internet
My Wacom Intuos3 tablet won't switch into pen mode
The winning answer came courtesy of Mr Benedikt Schmitt of Wacom Europe, who offered the following solution: from the Windows Device Manager, disable the “Wacom Virtual Hid Driver” device. (Go to Control Panel > System and Maintenance > Device Manager, find the driver, right-click it and choose “Disable”.) One reboot later (welcome to Windows-land, circa 2008?), everything works as desired. Pressure and tilt sensitivity inside Photoshop still work, and the pen functions just fine in the rest of the Windows desktop. The absolute mapping makes it an absolute pleasure to point quickly and precisely. It makes my laser mouse feel rather clumsy navigating a large 24′ screen!
Feb 04, 2009 | Wacom Intuos3 Graphic Tablet
Serial to usb wacom tablet problem
I just got Vista and it killed my Intuos2 w/serial to usb also, but here's a half solution:
Download Wacom driver 4.78-6 http://www.wacom-europe.com/int/downloads/driver/driver.asp?lang=en. Make sure you remove any other Wacom drivers, tablet, and reboot. Install 4.78-6 driver and select serial port when the choice pops up. Plug in your tablet with the serial to usb adapter, wait a few seconds and click retry. Complete the install and reboot.
Your Wacom tracking should work now, but certain things might not work like pressure sensitivity and you'll get annoying error "reinstall driver" pop-ups.
I think you can aslo buy a PCI-serial card for your computer and skip the serial-usb adapter since Vista doesn't support the adapter for Wacom tablets.. but I'm not sure if there's a working Vista serial Wacom driver either.. or ever will be. The age of XP and Legacy support is at an end my friends.
Dec 03, 2007 | Wacom (PTZ930AC) Graphic Tablet
Loosing pressure sensitivity
I was trying also, didn't work at all, and I'm going to try to close and open Adobe Photoshop CS2. But I need it to work on a few adoptables! I need it NOW!
Nov 29, 2007 | Wacom (PTZ930AC) Graphic Tablet
Wacom (PTZ930AC) Graphic Tablet Logo
11,052 people viewed this question
Top Wacom Computers & Internet Experts
toddmat
Level 1 Expert
jasbo
jasbo
William F. Bryant Jr
Level 1 Expert
Are you a Wacom Computer and Internet Expert? Answer questions, earn points and help others
